[FPGA] NLM(Non Local Means)图像去噪算法IP
2067|2
 楼主| 111_zh 发表于 2016-12-28 15:14 | 显示全部楼层 |阅读模式
我们可以提供NLM(Non Local Means)图像去噪算法IP,我们的NLM去噪IP, 可以用在FPGA上,也可用在ASIC上。
该NLM IP既可以用在still image,也可用在real-time Video. 有需求的可以联系:sales@wwago-inc.com
we offer the NLM IP  to  all  customers who want to get a clean image , the Customers would be anyone who deals with video or still images.
our NLM IP has already successfully been used by an Israel customer and two USA customers.
关于去噪:
Basic image noise reduction algorithms usually clean the noise in the image by way of low-pass filtering of the image. This method gets rid of noisy pixels, but at this cost of blurring the image – all edges are smeared.
More advanced noise reduction algorithms detect edges in the image, and do low pass filtering along lines perpendicular to the edges – this way the edges are preserved. However, the low-pass filtering is not as effective, because it averages fewer pixels.
NLM is Non-Local-Averaging – it looks at patches of pixels in a relatively large area around the pixel, and makes the low pass with pixels which are located in similar patches.
 楼主| 111_zh 发表于 2016-12-28 15:15 | 显示全部楼层
NLM去噪算法IP 技术文档:
feihufuture 发表于 2016-12-29 08:37 | 显示全部楼层
NLM去噪算法IP 技术文档:
