To access the setup wizard, right click the USB User Module Icon in the device editor and click the USB Setup Wizard... menu item.
When the Device Descriptor tree is fully expanded, you see all the wizard options. The left side displays the name of the descriptor, the center displays the data, and the left displays the operation that may be performed for a particular descriptor. In some instances, a Descriptor has a pull-down menu that presents available options.
