返回列表 发新帖我要提问本帖赏金: 40.00元(功能说明)
『已完结』『活动』暮春三月,火舞喊你来寻找最美波形
13351|53
guyues1 发表于 2017-3-16 23:06 | 显示全部楼层
地瓜patch 发表于 2017-3-17 22:26 | 显示全部楼层
经鉴定是男版主
多谢捧场本人的确是DS一枚, 快来参加活动!  发表于 2017-3-18 01:51
 楼主| zhanzr21 发表于 2017-3-22 13:14 | 显示全部楼层
自顶一贴!
 楼主| zhanzr21 发表于 2017-3-23 23:12 | 显示全部楼层
人气不旺, 自顶一贴!
 楼主| zhanzr21 发表于 2017-3-24 21:23 | 显示全部楼层
自顶一贴, 很好的活动!
shanan 发表于 2017-3-25 23:39 | 显示全部楼层
#!/bin/python
#Example source code for 21ic
#Default runs in Python 3.5 Environment
#Author: zhanzr21
#Description: This Example demonstrates how to generate raw audio data.
import os
import math
import random
TEST_SAMPLE_RATE = 22050
TEST_SAMPLE_LEN_SEC = 1.5
TEST_SAMPLE_NUM = int(TEST_SAMPLE_RATE * TEST_SAMPLE_LEN_SEC)
CHAN_NO = 1
AUDIO_HZ = 600
AUDIO_CYCLE = (TEST_SAMPLE_RATE/AUDIO_HZ)
PULSE_HZ = 5
PULSE_CYCLE = (TEST_SAMPLE_RATE/PULSE_HZ)
test_amp_gain = 0.75
INT16_MAX = 32767
INT16_MIN = -32768
f=open('test.raw',mode='wb')
for i in range(0, TEST_SAMPLE_NUM):
# Sine Wave
    #test_sample = int(INT16_MAX * test_amp_gain * (math.sin(math.pi*2*(i%AUDIO_CYCLE)/AUDIO_CYCLE)))
# Square Wave
    #test_sample = int(test_amp_gain * (INT16_MAX if ((i%AUDIO_CYCLE)>(AUDIO_CYCLE/2)) else INT16_MIN))
# Saw wave
    #test_sample = int(test_amp_gain * (INT16_MIN + (i%AUDIO_CYCLE)*((INT16_MAX-INT16_MIN)/AUDIO_CYCLE)))
# Triangle wave
    #test_sample = int(test_amp_gain * (INT16_MIN + (i%AUDIO_CYCLE)*(2*(INT16_MAX-INT16_MIN)/AUDIO_CYCLE)) if ((i%AUDIO_CYCLE)<(AUDIO_CYCLE/2)) else (INT16_MAX - (i%AUDIO_CYCLE)*(2*(INT16_MAX-INT16_MIN)/AUDIO_CYCLE)))
# Random Number
    #test_sample = random.randint(INT16_MIN, INT16_MAX)
# Pulse Sine Wave
    #test_sample = int(INT16_MAX * test_amp_gain * (math.sin(math.pi*2*(i%AUDIO_CYCLE)/AUDIO_CYCLE))) if (0==(i//PULSE_CYCLE)%2) else 0
# Ladder Wave from 21ic ID: shanan
    if ((i%AUDIO_CYCLE)>(AUDIO_CYCLE*0.8)):
        test_sample = int(test_amp_gain * INT16_MAX)
    elif ((i%AUDIO_CYCLE)>(AUDIO_CYCLE*0.6)):
        test_sample = int(test_amp_gain * INT16_MAX*0.75)
    elif ((i%AUDIO_CYCLE)>(AUDIO_CYCLE*0.4)):
        test_sample = int(test_amp_gain * INT16_MAX*0.5)
    elif ((i%AUDIO_CYCLE)>(AUDIO_CYCLE*0.2)):
        test_sample = int(test_amp_gain * INT16_MAX*0.25)
    elif ((i%AUDIO_CYCLE)>0):
        test_sample = 0
    else:
        test_sample = 0
    test_ba = bytearray()
    test_ba.append(test_sample&0x00ff)
    test_ba.append((test_sample>>8)&0x00ff)
    f.write(test_ba)
f.close()
test.rar (200 Bytes, 下载次数: 1)
generate_raw_audio.rar (787 Bytes, 下载次数: 3)
打赏榜单
zhanzr21 打赏了 20.00 元 2017-03-27
理由:成功提交代码!
Good, 已经验证!  发表于 2017-3-26 01:35
荣丰宇 发表于 2017-3-27 13:23 | 显示全部楼层
虽然参加活动的人比较少,但是希望楼主可以**做下去,加油~持续关注
 楼主| zhanzr21 发表于 2017-3-27 17:04 | 显示全部楼层
活动阶段性结束, 请期待下次活动!
荣丰宇 发表于 2017-3-31 19:48 | 显示全部楼层
收到第一次活动的额外奖品啦,一个小米耳机
很想参加第二次活动的,手里正好也有个f722,但是呢,没有功放板,也没有喇叭,哎,,,,周末搞搞了~
 楼主| zhanzr21 发表于 2017-4-1 13:57 | 显示全部楼层
很想参加第二次活动的,手里正好也有个f722,但是呢,没有功放 ...
用DAC可以直接驱动你手上这个耳机的
荣丰宇 发表于 2017-4-1 15:14 | 显示全部楼层
用DAC可以直接驱动你手上这个耳机的
嗯嗯,就是声音肯定比较小,外放是不行了
 楼主| zhanzr21 发表于 2017-4-1 17:34 | 显示全部楼层
嗯嗯,就是声音肯定比较小,外放是不行了
实际上声音不小, ST的DAC有buffer,
根据我的实验, buffer打开了,甚至有太吵的感觉
当然跟耳机的阻抗特性有关, 我做实验用的32Ohm的耳机
zsz888 发表于 2017-5-12 10:32 | 显示全部楼层
