[应用相关] LIS3DH I2C驱动
4816|7
 楼主| 1021256354 发表于 2017-4-15 17:01 | 显示全部楼层 |阅读模式
@香主:LIS3DH 的ST官方I2C驱动链接发我一下,谢谢!!!!!
yujielun 发表于 2017-4-15 23:26 | 显示全部楼层
yujielun 发表于 2017-4-15 23:30 | 显示全部楼层
yiy 发表于 2017-4-16 14:08 | 显示全部楼层
en.stsw-mems006.zip (12.66 KB, 下载次数: 173)
yiy 发表于 2017-4-16 14:09 | 显示全部楼层
  1. /******************** (C) COPYRIGHT 2012 STMicroelectronics ********************
  2. * File Name          : example_main.c
  3. * Author             : MSH Application Team
  4. * Author             : Abhishek Anand,Fabio Tota
  5. * Revision           : $Revision: 1.5 $
  6. * Date               : $Date: 16/06/2011 12:19:08 $
  7. * Description        : Example main file for MKI109V1 board
  8. * HISTORY:
  9. * Date        | Modification                                | Author
  10. * 16/06/2011  | Initial Revision                            | Fabio Tota
  11. * 11/06/2012  |        Support for multiple drivers in the same program |        Abhishek Anand
  12. ********************************************************************************
  13. * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  14. * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
  15. * AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
  16. * INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
  17. * CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
  18. * INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  19. *
  20. * THIS SOFTWARE IS SPECIFICALLY DESIGNED FOR EXCLUSIVE USE WITH ST PARTS.
  21. *
  22. *******************************************************************************/
  23. /* Includes ------------------------------------------------------------------*/
  24. //include files for MKI109V1 board
  25. #include "stm32f10x.h"
  26. #include "usb_lib.h"
  27. #include "usb_desc.h"
  28. #include "hw_config.h"
  29. #include "usb_pwr.h"
  30. #include "led.h"
  31. #include "button.h"
  32. #include "adc_mems.h"
  33. #include "string.h"
  34. #include "spi_mems.h"
  35. #include <stdio.h>
  36. //include MEMS driver
  37. #include "lis3dh_driver.h"
  38. /* Private typedef -----------------------------------------------------------*/
  39. /* Private define ------------------------------------------------------------*/
  40. /* Private macro -------------------------------------------------------------*/
  41. /* Private variables ---------------------------------------------------------*/
  42. uint8_t response;
  43. uint8_t USBbuffer[64];
  44. /* Extern variables ----------------------------------------------------------*/
  45. /* Private function prototypes -----------------------------------------------*/
  46. /* Private functions ---------------------------------------------------------*/
  47. //define for example1 or example2
  48. //#define __EXAMPLE1__H
  49. #define __EXAMPLE2__H
  50. /*******************************************************************************
  51. * Function Name  : main.
  52. * Description    : Main routine.
  53. * Input          : None.
  54. * Output         : None.
  55. * Return         : None.
  56. *******************************************************************************/
  57. int main(void)
  58. {
  59.   uint8_t buffer[26];
  60.   uint8_t position=0, old_position=0;
  61.   AxesRaw_t data;
  62.   //Initialize your hardware here
  63.
  64.   //function for MKI109V1 board
  65.   InitHardware();
  66.   SPI_Mems_Init();
  67.
  68.   EKSTM32_LEDOff(LED1);
  69.   EKSTM32_LEDOff(LED2);
  70.   EKSTM32_LEDOff(LED3);
  71.   //wait until the USB is ready (MKI109V1 board)
  72.   while(bDeviceState != CONFIGURED);
  73.   //Inizialize MEMS Sensor
  74.   //set ODR (turn ON device)
  75.   response = LIS3DH_SetODR(LIS3DH_ODR_100Hz);
  76.   if(response==1){
  77.         sprintf((char*)buffer,"\n\rSET_ODR_OK    \n\r\0");
  78.         USB_SIL_Write(EP1_IN, buffer, 19);
  79.         SetEPTxValid(ENDP1);
  80.   }
  81.   //set PowerMode
  82.   response = LIS3DH_SetMode(LIS3DH_NORMAL);
  83.   if(response==1){
  84.         sprintf((char*)buffer,"SET_MODE_OK     \n\r\0");
  85.         USB_SIL_Write(EP1_IN, buffer, 19);
  86.         SetEPTxValid(ENDP1);
  87.   }
  88.   //set Fullscale
  89.   response = LIS3DH_SetFullScale(LIS3DH_FULLSCALE_2);
  90.   if(response==1){
  91.         sprintf((char*)buffer,"SET_FULLSCALE_OK\n\r\0");
  92.         USB_SIL_Write(EP1_IN, buffer, 19);
  93.         SetEPTxValid(ENDP1);
  94.   }
  95.   //set axis Enable
  96.   response = LIS3DH_SetAxis(LIS3DH_X_ENABLE | LIS3DH_Y_ENABLE | LIS3DH_Z_ENABLE);
  97.   if(response==1){
  98.         sprintf((char*)buffer,"SET_AXIS_OK     \n\r\0");
  99.         USB_SIL_Write(EP1_IN, buffer, 19);
  100.         SetEPTxValid(ENDP1);
  101.   }
  102.
  103. /*********************/
  104. /******Example 1******/
  105. #ifdef __EXAMPLE1__H
  106.   while(1){
  107.   //get Acceleration Raw data
  108.   response = LIS3DH_GetAccAxesRaw(&data);
  109.   if(response==1){
  110.     //print data values
  111.     //function for MKI109V1 board
  112.     EKSTM32_LEDToggle(LED1);
  113.     sprintf((char*)buffer, "X=%6d Y=%6d Z=%6d \r\n", data.AXIS_X, data.AXIS_Y, data.AXIS_Z);
  114.     USB_SIL_Write(EP1_IN, buffer, 29);
  115.     SetEPTxValid(ENDP1);
  116.     old_position = position;
  117.   }
  118. }
  119. #endif /* __EXAMPLE1__H  */
  120. /*********************/
  121. /******Example 2******/
  122. #ifdef __EXAMPLE2__H
  123. //configure Mems Sensor
  124. //set Interrupt Threshold
  125. response = LIS3DH_SetInt1Threshold(20);
  126. if(response==1){
  127.         sprintf((char*)buffer,"SET_THRESHOLD_OK\n\r\0");
  128.         USB_SIL_Write(EP1_IN, buffer, 19);
  129.         SetEPTxValid(ENDP1);
  130.   }
  131. //set Interrupt configuration (all enabled)
  132. response = LIS3DH_SetIntConfiguration(LIS3DH_INT1_ZHIE_ENABLE | LIS3DH_INT1_ZLIE_ENABLE |
  133.        LIS3DH_INT1_YHIE_ENABLE | LIS3DH_INT1_YLIE_ENABLE |
  134.        LIS3DH_INT1_XHIE_ENABLE | LIS3DH_INT1_XLIE_ENABLE );
  135. if(response==1){
  136.         sprintf((char*)buffer,"SET_INT_CONF_OK \n\r\0");
  137.         USB_SIL_Write(EP1_IN, buffer, 19);
  138.         SetEPTxValid(ENDP1);
  139.   }
  140. //set Interrupt Mode
  141. response = LIS3DH_SetIntMode(LIS3DH_INT_MODE_6D_POSITION);
  142. if(response==1){
  143.         sprintf((char*)buffer,"SET_INT_MODE    \n\r\0");
  144.         USB_SIL_Write(EP1_IN, buffer, 19);
  145.         SetEPTxValid(ENDP1);
  146.   }
  147. while(1){
  148.   //get 6D Position
  149.   response = LIS3DH_Get6DPosition(&position);
  150.   if((response==1) && (old_position!=position)){
  151.     EKSTM32_LEDToggle(LED1);
  152.     switch (position){
  153.     case LIS3DH_UP_SX:   sprintf((char*)buffer,"\n\rposition = UP_SX  \n\r\0");   break;
  154.     case LIS3DH_UP_DX:   sprintf((char*)buffer,"\n\rposition = UP_DX  \n\r\0");   break;
  155.     case LIS3DH_DW_SX:   sprintf((char*)buffer,"\n\rposition = DW_SX  \n\r\0");   break;
  156.     case LIS3DH_DW_DX:   sprintf((char*)buffer,"\n\rposition = DW_DX  \n\r\0");   break;
  157.     case LIS3DH_TOP:     sprintf((char*)buffer,"\n\rposition = TOP    \n\r\0");   break;
  158.     case LIS3DH_BOTTOM:  sprintf((char*)buffer,"\n\rposition = BOTTOM \n\r\0");   break;
  159.     default:      sprintf((char*)buffer,"\n\rposition = unknown\n\r\0");   break;
  160.     }
  161.
  162.   //function for MKI109V1 board
  163.   USB_SIL_Write(EP1_IN, buffer, 23);
  164.   SetEPTxValid(ENDP1);
  165.   old_position = position;
  166.   }
  167. }
  168. #endif /*__EXAMPLE2__H */
  169. } // end main
  170. #ifdef USE_FULL_ASSERT
  171. //function for MKI109V1 board
  172. /*******************************************************************************
  173. * Function Name  : assert_failed
  174. * Description    : Reports the name of the source file and the source line number
  175. *                  where the assert_param error has occurred.
  176. * Input          : - file: pointer to the source file name
  177. *                  - line: assert_param error line source number
  178. * Output         : None
  179. * Return         : None
  180. *******************************************************************************/
  181. void assert_failed(uint8_t* file, uint32_t line)
  182. {
  183.   /* User can add his own implementation to report the file name and line number,
  184.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  185.   /* Infinite loop */
  186.   while (1)
  187.   {}
  188. }
  189. #endif
  190. /******************* (C) COPYRIGHT 2012 STMicroelectronics *****END OF FILE****/
232321122 发表于 2017-4-16 17:15 | 显示全部楼层
怎么不使用mpu6050?
232321122 发表于 2017-4-16 17:16 | 显示全部楼层
记得有个F030开发板带有这个例程参考。
 楼主| 1021256354 发表于 2017-4-17 09:21 | 显示全部楼层
有链接么?谢谢
