已知c语言程序,画出程序流程图,求大神
1323|4
 楼主| YfaiSy 发表于 2017-6-15 18:26 | 显示全部楼层 |阅读模式
        #include<stc12.h>                 //库文件
  //#include <intrins.H>
//typedef unsigned char BYTE;
//typedef unsigned int WORD;
#define uchar unsigned char//宏定义无符号字符型
#define uint unsigned int  //宏定义无符号整型
/* define constants */
#define SYSclk 12000000L
#define MODE1T //Timer clock mode, comment this line is 12T mode, uncomment is 1T mode
#ifdef MODE1T
#define T1MS (65536-SYSclk/1000) //1ms timer calculation method in 1T mode
#else
#define T1MS (65536-SYSclk/12/1000) //1ms timer calculation method in 12T mode
#endif
                            I/O定义
sbit MAX  =P3^0;//低电平有效
sbit MIN  =P3^1;//低电平有效
sbit GATE =P3^5;//低电平有效
sbit UP   =P3^3;//高电平有效
sbit DOWN =P3^4;//高电平有效
#define DELAY_TIME       5    //单位100mS
#define DELAY_TIME2      5    //单位100mS
//-------------------变量定义------------------------------
volatile uint  tcnt_100ms = 0;
volatile uint  tcnt_1ms = 0;
volatile uint  t_delay_cnt = 0;
bit GATE_old;
void Delay100ms()                //12.000MHz
        uchar i, j, k;
//        _nop_();
        i = 5;
        j = 144;
        k = 71;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
void Delay1000ms()                //@12.000MHz
        unsigned char i, j, k;
        //_nop_();
        //_nop_();
        i = 46;
        j = 153;
        k = 245;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
                            定时中断服务函数
void t0(void) interrupt 1 using 0 //定时中断服务函数
        tcnt_1ms++;
  if(tcnt_1ms>=100)
        tcnt_1ms = 0;
        tcnt_100ms++;
     if(t_delay_cnt<50)
            t_delay_cnt++;
                            主函数
/* main program */
void main()
        //开机空运行300mS,等待时间稳定。
        Delay100ms();
        Delay100ms();
        Delay100ms();
#ifdef MODE1T
AUXR = 0x80;  //使用1T模式
//timer0 work in 1T mode
#endif
TMOD = 0x00;
//set timer0 as mode0 (16-bit auto-reload)
TL0 = T1MS;
//initial timer0 low byte
TH0 = T1MS >> 8;
//initial timer0 high byte
TR0 = 1;
//timer0 start running
ET0 = 1;
//enable timer0 interrupt
EA = 1;
//open global interrupt switch
        P3M0 = 0x1C;   //         P3.2,P3.3,P3.4是强推挽输出
  P3M1 = 0x00;
while(1)
                 if(GATE != GATE_old)
                  t_delay_cnt = 0;
                        GATE_old = GATE;
                 if(!GATE)//开锁状态(低)--默认为高
                        if(MAX)//限位打开
                                if(t_delay_cnt >= DELAY_TIME)
                                 UP=0;
                                 DOWN=0;//停止
                                else
                                 UP=1;
                                 DOWN=0;//正转
                        else//限位闭合
                                UP=0;
                                DOWN=0;//停止
                 else
                        if(MIN)//限位打开
        if(t_delay_cnt >= DELAY_TIME2)
                                 UP=0;
                                 DOWN=0;//停止
                                else
                                 DOWN=1;
                                 UP=0;//反转
                        else//限位闭合
                                DOWN=0;
                                UP=0;//停止
                              结束
liuwanwei 发表于 2017-6-16 08:07 | 显示全部楼层
程序简单,但估计没人愿意花时间做这个流程图,所以靠自己吧
renxiaolin 发表于 2017-6-16 08:35 | 显示全部楼层
  我可以有偿帮你画,一个图1000$
前功尽弃 发表于 2017-6-16 09:12 | 显示全部楼层
你怎么反其道而行
xymxym 发表于 2017-6-16 09:32 | 显示全部楼层
百度搜索下有个“C语言流程生成器”的软件
