[总线接口] AM335X 的GPMC怎么接多个设备,GPIB谁用过
1270|0
 楼主| sy971586331 发表于 2017-6-27 09:24 | 显示全部楼层 |阅读模式
最近公司做的一个电源设备,要做成LXI设备,支持GPIB,USB和LAN,LAN已经解决了,USB有现成的,GPIB初步打算使用TNT882或NAT9914,在网上找到了很多51驱动这两个芯片的资料,直接用IO口模拟时序,但我们使用的主控是TI AM335X,可以把TNT882或NAT9914接到AM335X的GPMC上,现在GPMC已经接了NAND,如果再接上NAT9914 CS和中断脚不同,其他脚都和NAND复用,但驱动要怎么修改呢?附上NAND驱动的入口
  1. static void evm_nand_init(int evm_id, int profile)
  3.     struct omap_nand_platform_data *pdata;
  4.     struct gpmc_devices_info gpmc_device[2] = {
  5.         { NULL, 0 },
  6.         { NULL, 0 },
  7.     };
  8.     setup_pin_mux(nand_pin_mux);
  9.     pdata = omap_nand_init(am335x_nand_partitions,
  10.         ARRAY_SIZE(am335x_nand_partitions), 0, 0,
  11.         &am335x_nand_timings);
  12.     if (!pdata)
  13.         return;
  14.     pdata->ecc_opt =OMAP_ECC_BCH8_CODE_HW;
  15.     pdata->elm_used = true;
  16.     gpmc_device[0].pdata = pdata;
  17.     gpmc_device[0].flag = GPMC_DEVICE_NAND;
  18.     omap_init_gpmc(gpmc_device, sizeof(gpmc_device));
  19.     omap_init_elm();
  20. }
  1. /* Pin mux for nand flash module */
  2. static struct pinmux_config nand_pin_mux[] = {
  3.     {"gpmc_ad0.gpmc_ad0",     OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
  4.     {"gpmc_ad1.gpmc_ad1",     OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
  5.     {"gpmc_ad2.gpmc_ad2",     OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
  6.     {"gpmc_ad3.gpmc_ad3",     OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
  7.     {"gpmc_ad4.gpmc_ad4",     OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
  8.     {"gpmc_ad5.gpmc_ad5",     OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
  9.     {"gpmc_ad6.gpmc_ad6",     OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
  10.     {"gpmc_ad7.gpmc_ad7",     OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
  11.     {"gpmc_wait0.gpmc_wait0", OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
  12.     {"gpmc_wpn.gpmc_wpn",     OMAP_MUX_MODE7 | AM33XX_PIN_INPUT_PULLUP},
  13.     {"gpmc_csn0.gpmc_csn0",   OMAP_MUX_MODE0 | AM33XX_PULL_DISA},
  14.     {"gpmc_advn_ale.gpmc_advn_ale",  OMAP_MUX_MODE0 | AM33XX_PULL_DISA},
  15.     {"gpmc_oen_ren.gpmc_oen_ren",    OMAP_MUX_MODE0 | AM33XX_PULL_DISA},
  16.     {"gpmc_wen.gpmc_wen",     OMAP_MUX_MODE0 | AM33XX_PULL_DISA},
  17.     {"gpmc_ben0_cle.gpmc_ben0_cle",  OMAP_MUX_MODE0 | AM33XX_PULL_DISA},
  18.     {NULL, 0},
  19. };
