 -  * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
 -  * [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
 -  * $Revision: 5 $
 -  * $Date: 15/02/06 10:22a $
 -  * [url=home.php?mod=space&uid=247401]@brief[/url]    Show the usage of GPIO interrupt function.
 -  * @note
 -  * Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
 - #include <stdio.h>
 - #include "M058S.h"
- #define PLL_CLOCK           50000000
 -  * @brief       Port0/Port1 IRQ
 -  * @param       None
 -  * [url=home.php?mod=space&uid=266161]@return[/url]      None
 -  * [url=home.php?mod=space&uid=1543424]@Details[/url]     The Port0/Port1 default IRQ, declared in startup_M058S.s.
 - void GPIOP0P1_IRQHandler(void)
 -     /* To check if P1.3 interrupt occurred */
 -     if(GPIO_GET_INT_FLAG(P1, BIT3))
 -         GPIO_CLR_INT_FLAG(P1, BIT3);
 -         printf("P1.3 INT occurred.\n");
 -     else
 -         /* Un-expected interrupt. Just clear all PORT0, PORT1 interrupts */
 -         P0->ISRC = P0->ISRC;
 -         P1->ISRC = P1->ISRC;
 -         printf("Un-expected interrupts.\n");
 -  * @brief       Port2/Port3/Port4 IRQ
 -  * @param       None
 -  * @return      None
 -  * @details     The Port2/Port3/Port4 default IRQ, declared in startup_M058S.s.
 - void GPIOP2P3P4_IRQHandler(void)
 -     /* To check if P4.5 interrupt occurred */
 -     if(GPIO_GET_INT_FLAG(P4, BIT5))
 -         GPIO_CLR_INT_FLAG(P4, BIT5);
 -         printf("P4.5 INT occurred.\n");
 -     else
 -         /* Un-expected interrupt. Just clear all PORT2, PORT3 and PORT4 interrupts */
 -         P2->ISRC = P2->ISRC;
 -         P3->ISRC = P3->ISRC;
 -         P4->ISRC = P4->ISRC;
 -  * @brief       Port5 IRQ
 -  * @param       None
 -  * @return      None
 -  * @details     The Port5 default IRQ, declared in startup_M058S.s.
 - void GPIOP5_IRQHandler(void)
 -     /* To check if P5.2 interrupt occurred */
 -     if(GPIO_GET_INT_FLAG(P5, BIT2))
 -         GPIO_CLR_INT_FLAG(P5, BIT2);
 -         printf("P5.2 INT occurred.\n");
 -     else
 -         /* Un-expected interrupt. Just clear all PORT5 interrupts */
 -         P5->ISRC = P5->ISRC;
 -  * @brief       Port6/Port7 IRQ
 -  * @param       None
 -  * @return      None
 -  * @details     The Port6/Port7 default IRQ, declared in startup_M058S.s.
 - void GPIOP6P7_IRQHandler(void)
 -     /* To check if P6.1 interrupt occurred */
 -     if(GPIO_GET_INT_FLAG(P6, BIT1))
 -         GPIO_CLR_INT_FLAG(P6, BIT1);
 -         printf("P6.1 INT occurred.\n");
 -     else
 -         /* Un-expected interrupt. Just clear all PORT6 and PORT7 interrupts */
 -         P6->ISRC = P6->ISRC;
 -         P7->ISRC = P7->ISRC;
- void SYS_Init(void)
 -     /* Init System Clock        */
 -     /* Enable Internal RC 22.1184MHz clock */
 -     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
-     /* Waiting for Internal RC clock ready */
 -     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
-     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
 -     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
-     /* Enable external XTAL 12MHz clock */
 -     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
-     /* Waiting for external XTAL clock ready */
 -     CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
-     /* Set core clock as PLL_CLOCK from PLL */
 -     CLK_SetCoreClock(PLL_CLOCK);
-     /* Enable UART module clock */
 -     CLK_EnableModuleClock(UART0_MODULE);
-     /* Select UART module clock source */
 -     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
 -     /* Init I/O Multi-function        */
-     /* Set P3 multi-function pins for UART0 RXD and TXD */
 -     SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
 -     SYS->P3_MFP |= (SYS_MFP_P30_RXD | SYS_MFP_P31_TXD);
- void UART0_Init(void)
 -     /* Init UART        */
 -     /* Reset UART0 */
 -     SYS_ResetModule(UART0_RST);
-     /* Configure UART0 and set UART0 Baudrate */
 -     UART_Open(UART0, 115200);
 - /* MAIN function        */
 - int main(void)
 -     /* Unlock protected registers */
 -     SYS_UnlockReg();
-     /* Init System, peripheral clock and multi-function I/O */
 -     SYS_Init();
-     /* Lock protected registers */
 -     SYS_LockReg();
-     /* Init UART0 for printf */
 -     UART0_Init();
-     printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
 -     printf("+------------------------------------------------------+\n");
 -     printf("|    GPIO P1.3/P4.5/P5.2/P6.1 Interrupt Sample Code    |\n");
 -     printf("+------------------------------------------------------+\n\n");
 -     /* GPIO Interrupt Function Test        */
 -     printf("P1.3/P4.5/P5.2/P6.1 are used to test interrupt ......\n");
-     /* Configure P1.3 as Input mode and enable interrupt by rising edge trigger */
 -     GPIO_SetMode(P1, BIT3, GPIO_PMD_INPUT);
 -     GPIO_EnableInt(P1, 3, GPIO_INT_RISING);
 -     NVIC_EnableIRQ(GPIO_P0P1_IRQn);
-     /*  Configure P4.5 as Quasi-bidirection mode and enable interrupt by falling edge trigger */
 -     GPIO_SetMode(P4, BIT5, GPIO_PMD_QUASI);
 -     GPIO_EnableInt(P4, 5, GPIO_INT_FALLING);
 -     NVIC_EnableIRQ(GPIO_P2P3P4_IRQn);
-     /*  Configure P5.2 as Input mode and enable interrupt by rising and falling edge trigger */
 -     GPIO_SetMode(P5, BIT2, GPIO_PMD_INPUT);
 -     GPIO_EnableInt(P5, 2, GPIO_INT_BOTH_EDGE);
 -     NVIC_EnableIRQ(GPIO_P5_IRQn);
-     /*  Configure P6.1 as Quasi-bidirection mode and enable interrupt by falling edge trigger */
 -     GPIO_SetMode(P6, BIT1, GPIO_PMD_QUASI);
 -     GPIO_EnableInt(P6, 1, GPIO_INT_FALLING);
 -     NVIC_EnableIRQ(GPIO_P6P7_IRQn);
-     /* Waiting for interrupts */
 -     while(1);
- /*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
