STM32新手的疑问,望高手们不吝赐教。
2329|0
 楼主| mxh0506 发表于 2010-8-16 10:10 | 显示全部楼层 |阅读模式
这是Cortex-M3 Technical Reference中的一段:
Vector table entries are ARM/Thumb interworking compatible.
This causes bit [0] of the vector value to load into the EPSR T-bit on exception entry. Creating a table entry with bit [0] clear generates an INVSTATE fault on the first instruction of the handler corresponding to this vector.
应该怎么理解呢?向量表项的Bit[0]不能为0?否则会引发INVSTATE错误?
如果Bit[0]不是零,怎么实现半字或整字对齐呢
