c语言问题
2020|2
 楼主| areshan 发表于 2010-8-25 11:03 | 显示全部楼层 |阅读模式
#ifndef OSAL_TASKS_H
#define OSAL_TASKS_H
#ifdef __cplusplus
extern "C"
#endif
* INCLUDES
* MACROS
* CONSTANTS
#define TASK_NO_TASK      0xFF
* TYPEDEFS
* Event handler function prototype
typedef unsigned short (*pTaskEventHandlerFn)( unsigned char task_id, unsigned short event );
* GLOBAL VARIABLES
extern const pTaskEventHandlerFn tasksArr[];
extern const uint8 tasksCnt;
extern uint16 *tasksEvents;
* FUNCTIONS
* Call each of the tasks initailization functions.
extern void osalInitTasks( void );
#ifdef __cplusplus
#endif
#endif /* OSAL_TASKS_H */
高手帮我看看这种C的写法,我不知道什么意思:
1;extern "C"
      } //上面的"C"是什么呢?
2;typedef unsigned short (*PTaskEventHandlerFn)(unsigned char task_id,unsigned short event);
//这句是用后面的指向函数指针类型来替换前面的unsigned short类型吗???
ayb_ice 发表于 2010-8-25 11:07 | 显示全部楼层
C++声明C程序里的东东
 楼主| areshan 发表于 2010-8-25 17:22 | 显示全部楼层
谢谢,明白了,extern "C"是在c++文件中加入c。
typedef unsigned short (*PTaskEventHandlerFn)(unsigned char task_id,unsigned short event);//这个是函数指针的类型定义,看看这句就知道了extern const pTaskEventHandlerFn tasksArr[];
