嵌入式DSP开发---dm642的中断
579|0
 楼主| dnux57fds 发表于 2017-8-13 15:42 | 显示全部楼层 |阅读模式
嵌入式DSP开发---dm642的中断
void fifoint_isr();
extern far void vectors();
void int_init()
IRQ_resetAll();
IRQ_setVecs(vectors);
IRQ_nmiEnable();
IRQ_globalEnable();
IRQ_reset(IRQ_EVT_EXTINT4);
IRQ_enable(IRQ_EVT_EXTINT4);
*(Uint32*)(0x019c0008) = 1;//中断条件 0上升,1下降
*(unsigned short*)EPLE_TEST = 0X0;
IRQ_clear(IRQ_EVT_EXTINT4);
interrupt void fifoint_isr()
IRQ_disable(IRQ_EVT_EXTINT4);
  com_isr232();
//修改vector.asm
   .global _vectors
   .global _c_int00
   .global _vector1
   .global _vector2
   .global _vector3
   .global _fifoint_isr
   .global _vector5
   .global _vector6
   .global _vector7
   .global _vector8
   .global _vector9
   .global _vector10
   .global _vector11
   .global _vector12
   .global _vector13
   .global _vector14
   .global _vector15
_vectors:
_vector0:   VEC_ENTRY _c_int00    ;RESET
_vector1:   VEC_ENTRY _vec_dummy  ;NMI
_vector2:   VEC_ENTRY _vec_dummy  ;RSVD
_vector3:   VEC_ENTRY _vec_dummy
_vector4:   VEC_ENTRY _fifoint_isr
_vector5:   VEC_ENTRY _vec_dummy
_vector6:   VEC_ENTRY _vec_dummy
_vector7:   VEC_ENTRY _vec_dummy
_vector8:   VEC_ENTRY _vec_dummy
_vector9:   VEC_ENTRY _vec_dummy
_vector10:  VEC_ENTRY _vec_dummy
_vector11:  VEC_ENTRY _vec_dummy
_vector12:  VEC_ENTRY _vec_dummy
_vector13:  VEC_ENTRY _vec_dummy
_vector14:  VEC_ENTRY _vec_dummy
_vector15:  VEC_ENTRY _vec_dummy
