| | 范例:opencore组织RISCMCU IP Core全套最新代码 _alu |  | ---------------------------------------------------------------------------- ---- ----
 ---- WISHBONE RISCMCU IP Core ----
 ---- This file is part of the RISCMCU project ----
 ---- http://www.opencores.org/projects/riscmcu/ ----
 ---- Description ----
 ---- Implementation of a RISC Microcontroller based on Atmel AVR ----
 ---- AT90S1200 instruction set and features with Altera Flex10k20 FPGA. ----
 ---- Author(s): ----
 ---- - Yap Zi He, yapzihe@hotmail.com ----
 ---- Copyright (C) 2001 Authors and OPENCORES.ORG ----
 ---- This source file may be used and distributed without ----
 ---- restriction provided that this copyright statement is not ----
 ---- removed from the file and that any derivative work contains ----
 ---- the original copyright notice and the associated disclaimer. ----
 ---- This source file is free software; you can redistribute it ----
 ---- and/or modify it under the terms of the GNU Lesser General ----
 ---- Public License as published by the Free Software Foundation; ----
 ---- either version 2.1 of the License, or (at your option) any ----
 ---- later version. ----
 ---- This source is distributed in the hope that it will be ----
 ---- useful, but WITHOUT ANY WARRANTY; without even the implied ----
 ---- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR ----
 ---- PURPOSE. See the GNU Lesser General Public License for more ----
 ---- details. ----
 ---- You should have received a copy of the GNU Lesser General ----
 ---- Public License along with this source; if not, download it ----
 ---- from http://www.opencores.org/lgpl.shtml ----
 library ieee;
 use ieee.std_logic_1164.all;
 use ieee.std_logic_arith.all;
 use ieee.std_logic_unsigned.all;
 library lpm;
 use lpm.lpm_components.all;
 entity v_alu is
 port( reg_rd, reg_rr, imm_value : in std_logic_vector(7 downto 0);
 c2a, c2b : in std_logic;
 asel : in integer range 0 to 1;
 bsel : in integer range 0 to 3;
 bitsel : in integer range 0 to 7;
 set : in std_logic;
 c_flag, t_flag : in std_logic;
 add, subcp, logic, right, dir, bld, cbisbi, pass_a : in std_logic;
 cpse, skiptest : in std_logic;
 wcarry : in std_logic;
 logicsel : in integer range 0 to 3;
 rightsel : in integer range 0 to 2;
 dirsel : in integer range 0 to 1;
 clk, clrn : in std_logic;
 c : buffer std_logic_vector(7 downto 0);
 tosr : buffer std_logic_vector (6 downto 0);
 skip : out std_logic
 end v_alu;
 architecture alu of v_alu is
 signal a, b : std_logic_vector(7 downto 0);
 signal sr : std_logic_vector(6 downto 0);
 signal cin, overflow, cout : std_logic;
 signal sum, logic_out, right_out, dir_out, bldcbi_out : std_logic_vector(7 downto 0);
 begin
 -- Operand Fetch Unit --
 process(clrn, clk)
 begin
 if clrn = '0' then
 a <= "00000000";
 b <= "00000000";
 elsif clk'event and clk = '1' then
 case asel is
 when 0 =>
 if c2a = '1' then
 a <= c;
 else
 a <= reg_rd;
 end if;
 when 1 =>
 a <= "00000000";
 end case;
 case bsel is
 when 0 =>
 if c2b = '1' then
 b <= c;
 else
 b <= reg_rr;
 end if;
 when 1 =>
 b <= reg_rd;
 when 2 =>
 b <= imm_value;
 when 3 =>
 b <= "00000001";
 end case;
 end if;
 end process;
 -- Execution Unit --
 cin <= c_flag when add = '1' and wcarry = '1' else
 '0' when add = '1' and wcarry = '0' else
 not c_flag when wcarry = '1' else
 '1';
 -- Adder-Subtracter
 adder1 : lpm_add_sub
 generic map(lpm_width => 8)
 port map (dataa => a, datab => b, cin => cin, add_sub => add, result => sum, cout => cout, overflow => overflow);
 -- Logic Unit
 with logicsel select
 logic_out <= a and b when 0, -- and, andi
 a or b when 1, -- or, ori
 a xor b when 2, -- eor
 not a when 3; -- com
 -- Shifter
 right_out(6 downto 0) <= a(7 downto 1);
 with rightsel select
 right_out(7) <= '0' when 0, -- lsr
 c_flag when 1, -- ror
 a(7) when 2; -- asr
 -- Direct Unit
 with dirsel select
 dir_out <= b when 0, -- ldi, mov
 (a(3 downto 0) & a(7 downto 4)) when 1; -- swap
 -- Bit Loader
 process(bld, bitsel, a, t_flag, set)
 begin
 for i in 0 to 7 loop
 if i /= bitsel then
 bldcbi_out(i) <= a(i);
 elsif bld = '1' then
 bldcbi_out(i) <= t_flag;
 else
 bldcbi_out(i) <= set;
 end if;
 end loop;
 end process;
 -- Results to Data Bus
 process(add, subcp, logic, right, dir, bld, cbisbi, pass_a, sum, logic_out, right_out, dir_out, bldcbi_out, a)
 begin
 c <= "ZZZZZZZZ";
 -- add, adc, inc, sub, sbc, subi, sbci, cp, cpc, cpi, dec, neg
 if add = '1' or subcp = '1' then
 c <= sum;
 end if;
 -- and, andi, or, ori, eor, com
 if logic = '1' then
 c <= logic_out;
 end if;
 -- lsr, lsr, asr
 if right = '1' then
 c <= right_out;
 end if;
 -- ldi, mov, swap
 if dir = '1' then
 c <= dir_out;
 end if;
 -- bld, cbisbi
 if bld = '1' or cbisbi = '1' then
 c <= bldcbi_out;
 end if;
 -- out, st z, st z+, st -z
 if pass_a = '1' then
 c <= a;
 end if;
 end process;
 -- Skip Evaluation Unit --
 process(cpse, skiptest, a, b, set, bitsel, c)
 begin
 skip <= '0';
 -- cpse
 if cpse = '1' then
 if a = b then
 skip <= '1';
 end if;
 -- sbrc, sbrs
 elsif skiptest = '1' then
 if (set = '1' and a(bitsel) = '1') or (set = '0' and a(bitsel) = '0') then
 skip <= '1';
 end if;
 end if;
 end process;
 -- Flags Evaluation Unit --
 process(add, subcp, cout, right, a, logic, a, b, sum, logic_out, right_out, c, overflow, sr, bitsel)
 begin
 -- C sr(0)
 if add = '1' then
 sr(0) <= cout;
 elsif right = '1' then
 sr(0) <= a(0);
 elsif logic = '1' then -- com
 sr(0) <= '1';
 else -- subcp
 sr(0) <= not cout;
 --sr(0) <= (not a(7) and b(7)) or (b(7) and c(7)) or (c(7) and not a(7));
 end if;
 -- Z sr(1)
 if (add = '1' or subcp = '1') and sum = "00000000" then
 sr(1) <= '1';
 elsif logic = '1' and logic_out = "00000000" then
 sr(1) <= '1';
 elsif right = '1' and right_out = "00000000" then
 sr(1) <= '1';
 else
 sr(1) <= '0';
 end if;
 -- N sr(2)
 if (add = '1' or subcp = '1') and sum(7) = '1' then
 sr(2) <= '1';
 elsif logic = '1' and logic_out(7) = '1' then
 sr(2) <= '1';
 elsif right = '1' and right_out(7) = '1' then
 sr(2) <= '1';
 else
 sr(2) <= '0';
 end if;
 -- V sr(3)
 if right = '1' then
 sr(3) <= right_out(7) xor a(0);
 sr(3) <= '0';
 else
 sr(3) <= overflow;
 end if;
 -- S sr(4)
 sr(4) <= sr(2) xor sr(3);
 -- H sr(5)
 if add = '1' then
 sr(5) <= (a(3) and b(3)) or (b(3) and not sum(3)) or (not sum(3) and a(3));
 else -- subcp
 sr(5) <= (not a(3) and b(3)) or (b(3) and sum(3)) or (sum(3) and not a(3));
 end if;
 -- T sr(6)
 sr(6) <= a(bitsel);
 end process;
 tosr <= sr;
 end alu;
