| 范例:opencore组织RISCMCU IP Core全套最新代码 _alu | ----------------------------------------------------------------------------
---- WISHBONE RISCMCU IP Core ----
---- This file is part of the RISCMCU project ----
---- http://www.opencores.org/projects/riscmcu/ ----
---- Description ----
---- Implementation of a RISC Microcontroller based on Atmel AVR ----
---- AT90S1200 instruction set and features with Altera Flex10k20 FPGA. ----
---- Author(s): ----
---- - Yap Zi He, yapzihe@hotmail.com ----
---- Copyright (C) 2001 Authors and OPENCORES.ORG ----
---- This source file may be used and distributed without ----
---- restriction provided that this copyright statement is not ----
---- removed from the file and that any derivative work contains ----
---- the original copyright notice and the associated disclaimer. ----
---- This source file is free software; you can redistribute it ----
---- and/or modify it under the terms of the GNU Lesser General ----
---- Public License as published by the Free Software Foundation; ----
---- either version 2.1 of the License, or (at your option) any ----
---- later version. ----
---- This source is distributed in the hope that it will be ----
---- useful, but WITHOUT ANY WARRANTY; without even the implied ----
---- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR ----
---- PURPOSE. See the GNU Lesser General Public License for more ----
---- details. ----
---- You should have received a copy of the GNU Lesser General ----
---- Public License along with this source; if not, download it ----
---- from http://www.opencores.org/lgpl.shtml ----
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
library lpm;
use lpm.lpm_components.all;
entity v_alu is
port( reg_rd, reg_rr, imm_value : in std_logic_vector(7 downto 0);
c2a, c2b : in std_logic;
asel : in integer range 0 to 1;
bsel : in integer range 0 to 3;
bitsel : in integer range 0 to 7;
set : in std_logic;
c_flag, t_flag : in std_logic;
add, subcp, logic, right, dir, bld, cbisbi, pass_a : in std_logic;
cpse, skiptest : in std_logic;
wcarry : in std_logic;
logicsel : in integer range 0 to 3;
rightsel : in integer range 0 to 2;
dirsel : in integer range 0 to 1;
clk, clrn : in std_logic;
c : buffer std_logic_vector(7 downto 0);
tosr : buffer std_logic_vector (6 downto 0);
skip : out std_logic
end v_alu;
architecture alu of v_alu is
signal a, b : std_logic_vector(7 downto 0);
signal sr : std_logic_vector(6 downto 0);
signal cin, overflow, cout : std_logic;
signal sum, logic_out, right_out, dir_out, bldcbi_out : std_logic_vector(7 downto 0);
begin
-- Operand Fetch Unit --
process(clrn, clk)
begin
if clrn = '0' then
a <= "00000000";
b <= "00000000";
elsif clk'event and clk = '1' then
case asel is
when 0 =>
if c2a = '1' then
a <= c;
else
a <= reg_rd;
end if;
when 1 =>
a <= "00000000";
end case;
case bsel is
when 0 =>
if c2b = '1' then
b <= c;
else
b <= reg_rr;
end if;
when 1 =>
b <= reg_rd;
when 2 =>
b <= imm_value;
when 3 =>
b <= "00000001";
end case;
end if;
end process;
-- Execution Unit --
cin <= c_flag when add = '1' and wcarry = '1' else
'0' when add = '1' and wcarry = '0' else
not c_flag when wcarry = '1' else
'1';
-- Adder-Subtracter
adder1 : lpm_add_sub
generic map(lpm_width => 8)
port map (dataa => a, datab => b, cin => cin, add_sub => add, result => sum, cout => cout, overflow => overflow);
-- Logic Unit
with logicsel select
logic_out <= a and b when 0, -- and, andi
a or b when 1, -- or, ori
a xor b when 2, -- eor
not a when 3; -- com
-- Shifter
right_out(6 downto 0) <= a(7 downto 1);
with rightsel select
right_out(7) <= '0' when 0, -- lsr
c_flag when 1, -- ror
a(7) when 2; -- asr
-- Direct Unit
with dirsel select
dir_out <= b when 0, -- ldi, mov
(a(3 downto 0) & a(7 downto 4)) when 1; -- swap
-- Bit Loader
process(bld, bitsel, a, t_flag, set)
begin
for i in 0 to 7 loop
if i /= bitsel then
bldcbi_out(i) <= a(i);
elsif bld = '1' then
bldcbi_out(i) <= t_flag;
else
bldcbi_out(i) <= set;
end if;
end loop;
end process;
-- Results to Data Bus
process(add, subcp, logic, right, dir, bld, cbisbi, pass_a, sum, logic_out, right_out, dir_out, bldcbi_out, a)
begin
c <= "ZZZZZZZZ";
-- add, adc, inc, sub, sbc, subi, sbci, cp, cpc, cpi, dec, neg
if add = '1' or subcp = '1' then
c <= sum;
end if;
-- and, andi, or, ori, eor, com
if logic = '1' then
c <= logic_out;
end if;
-- lsr, lsr, asr
if right = '1' then
c <= right_out;
end if;
-- ldi, mov, swap
if dir = '1' then
c <= dir_out;
end if;
-- bld, cbisbi
if bld = '1' or cbisbi = '1' then
c <= bldcbi_out;
end if;
-- out, st z, st z+, st -z
if pass_a = '1' then
c <= a;
end if;
end process;
-- Skip Evaluation Unit --
process(cpse, skiptest, a, b, set, bitsel, c)
begin
skip <= '0';
-- cpse
if cpse = '1' then
if a = b then
skip <= '1';
end if;
-- sbrc, sbrs
elsif skiptest = '1' then
if (set = '1' and a(bitsel) = '1') or (set = '0' and a(bitsel) = '0') then
skip <= '1';
end if;
end if;
end process;
-- Flags Evaluation Unit --
process(add, subcp, cout, right, a, logic, a, b, sum, logic_out, right_out, c, overflow, sr, bitsel)
begin
-- C sr(0)
if add = '1' then
sr(0) <= cout;
elsif right = '1' then
sr(0) <= a(0);
elsif logic = '1' then -- com
sr(0) <= '1';
else -- subcp
sr(0) <= not cout;
--sr(0) <= (not a(7) and b(7)) or (b(7) and c(7)) or (c(7) and not a(7));
end if;
-- Z sr(1)
if (add = '1' or subcp = '1') and sum = "00000000" then
sr(1) <= '1';
elsif logic = '1' and logic_out = "00000000" then
sr(1) <= '1';
elsif right = '1' and right_out = "00000000" then
sr(1) <= '1';
else
sr(1) <= '0';
end if;
-- N sr(2)
if (add = '1' or subcp = '1') and sum(7) = '1' then
sr(2) <= '1';
elsif logic = '1' and logic_out(7) = '1' then
sr(2) <= '1';
elsif right = '1' and right_out(7) = '1' then
sr(2) <= '1';
else
sr(2) <= '0';
end if;
-- V sr(3)
if right = '1' then
sr(3) <= right_out(7) xor a(0);
sr(3) <= '0';
else
sr(3) <= overflow;
end if;
-- S sr(4)
sr(4) <= sr(2) xor sr(3);
-- H sr(5)
if add = '1' then
sr(5) <= (a(3) and b(3)) or (b(3) and not sum(3)) or (not sum(3) and a(3));
else -- subcp
sr(5) <= (not a(3) and b(3)) or (b(3) and sum(3)) or (sum(3) and not a(3));
end if;
-- T sr(6)
sr(6) <= a(bitsel);
end process;
tosr <= sr;
end alu;
