帮忙看看cmx865读写程序,怎么就不行呢?!期待解决。手册
3429|3
 楼主| zhl100 发表于 2010-10-21 22:31 | 显示全部楼层 |阅读模式
#include <stm32f10x_lib.h>              /* STM32F10x Library Definitions      */
typedef   unsigned char  uchar ;
typedef unsigned int uint ;
/*  cmx868 Register Address Definitions  */
#define  GENRESET  0x01
#define  GENCTRL_ADDR 0xE0
#define  TXMODE_ADDR  0xE1
#define  RXMODE_ADDR  0xE2
#define  TXDATA_ADDR  0xE3
#define  RXDATA_ADDR  0xE5
#define  STAT_ADDR  0xE6
#define  PROG_ADDR  0xE8
  //定义寄存器
uint   genctrl;
uint   rxmode;
uint    stat;
uint   txmode;
uchar   txdata;
uchar  rxdata;
uint   prog;
uchar   int_func;
#define      CDATA1    GPIO_SetBits(GPIOD, GPIO_Pin_0)
#define     CDATA0    GPIO_ResetBits(GPIOD, GPIO_Pin_0)
#define     SPICLK1    GPIO_SetBits(GPIOD, GPIO_Pin_1)
#define     SPICLK0    GPIO_ResetBits(GPIOD, GPIO_Pin_1)
#define     RDATA1    GPIO_SetBits(GPIOD, GPIO_Pin_2)
#define     RDATA0    GPIO_ResetBits(GPIOD, GPIO_Pin_2)
#define     CSN1     GPIO_SetBits(GPIOD, GPIO_Pin_3)
#define     CSN0     GPIO_ResetBits(GPIOD, GPIO_Pin_3)
#define     IRQ1      GPIO_SetBits(GPIOD, GPIO_Pin_4)
#define     IRQ0     GPIO_ResetBits(GPIOD, GPIO_Pin_4)
void  write_8bit(uchar  come)
  uchar  i,j;
   CSN1;
       for(j=0;j<100;j++){;}
   CSN0;    for(j=0;j<100;j++){;}
  for(i=0;i<8;i++)
    if((come&0x80)!=0)
       CDATA1 ;
    else
    CDATA0 ;
       SPICLK0 ;
    for(j=0;j<100;j++)     {;}
     SPICLK1  ; for(j=0;j<100;j++)     {;}
come=come<<1;
uchar read_8bitoo(void)
uchar  i;
uchar  j;
uchar  k;
RDATA1;
j=0;
for(i=0;i<8;i++)
  SPICLK0; for(j=0;j<100;j++)     {;}
  j=j<<1;
  k=GPIO_ReadOutputDataBit(GPIOD, GPIO_Pin_2);
  if(k)
  j^=0x01;
  SPICLK1;for(j=0;j<100;j++)     {;}
return(j);
  uchar read_8bit(void)
uchar  i;
uchar  j;
uchar  k;
RDATA1;
j=0;
CSN1;
for(i=0;i<8;i++)
  j=j<<1;
  if(k)
  j^=0x01;
return(j);
uchar read_16bit(void)
{  uchar i;
  write_8bit(PROG_ADDR) ;
   i=read_8bitoo();
  i=i<<0x08;
  i+=read_8bitoo();
  return(i);
  void  write_8bitOO(uchar  come)
  uchar  i,j;
  for(i=0;i<8;i++)
    if((come&0x80)!=0)
       CDATA1 ;
    else
    CDATA0 ;
       SPICLK0 ;
come=come<<1;
   void  write(uchar addr ,uchar wdata)
       write_8bit(addr);
       write_8bitOO(wdata);
   void  writedata(uchar addr ,uchar wdatal,uchar wdatah)
   write_8bit(addr) ;
     write_8bitOO(wdatal) ;
  write_8bitOO(wdatah) ;
  void  init_cmx865(void)
  int j;
  write_8bit(GENRESET);
  writedata(GENCTRL_ADDR,0x09,0X00);
    for(j=0;j<100000;j++){;}
   writedata(TXMODE_ADDR,0X3E,0X1A);
void writedata1(uchar a)
     int  i;
     i=a;
write( TXDATA_ADDR ,i);}
cmx865ads.pdf
751.37 KB, 下载次数: 54
cmx865a
 楼主| zhl100 发表于 2010-10-21 23:01 | 显示全部楼层
帮忙看看,初学,第一次写相关C-BUS的程序,也是第一次用stm32独立写程序,请多给点建议
 楼主| zhl100 发表于 2010-10-22 23:42 | 显示全部楼层
1。 先复位
2。 配置写数据模式
3。 接下来我开始写数据 0
这样操作之后我用示波器在TXA和TXAN端接收信号,是不是会收到2.2K的正弦信号???
爱你滴翔 发表于 2012-11-11 15:38 | 显示全部楼层
配置成编程音频输出在正常情况下是有输出信号的。仔细看下datasheet。
