我使用的时DSPc6455芯片,使用的软件是ccsv6,编译器为7.4.8版本。
我把以前的3.3版本的工程倒入进来之后,出现这样的问题:当我将.cmd文件中-1 fastrts64x.lib不注释掉,让其编译的时候出现这样的错误:
#10056 symbol "_fixfi" redefined in "c:/ti/ccsv6/tools/compiler/c6400_7.4.8/lib/rts64plus.lib<fixfi.obj>";redefined in ".../fastrts64x.lib<spint.obj>"
#10056 symbol "_fltif" redefined in "c:/ti/ccsv6/tools/compiler/c6400_7.4.8/lib/rts64plus.lib<fixfi.obj>";redefined in ".../fastrts64x.lib<intsp.obj>"
#10056 symbol "_mpyf" redefined in "c:/ti/ccsv6/tools/compiler/c6400_7.4.8/lib/rts64plus.lib<fixfi.obj>";redefined in ".../fastrts64x.lib<mpyf.obj>"
如果将.cmd文件中的-1 fastrts64x.lib注释掉,不让其编译的话又出现这样的错误:
unresolved symbol _intsp,first referenced in .../....obj
unresolved symbol _mpysp,first referenced in .../....obj
unresolved symbol _spint,first referenced in .../....obj
这怎么解决啊,求大神指点啊
