1.<br />Assume a Sigma-Delta ADC has a sampling rate of 1MHz. The interested signal band is<br />from 0 to 8kHz.<br />a. What value of R and C in an RC anti-aliasing filter should be used to assure that the<br />signal distortion within the interested band has less than -80dB.<br />b. Suppose there is a white noise presence between 0 to 1MHz with magnitude of 10uV<br />RMS. With your RC filter, what kind of extra noise level will be seen by the ADC due to<br />the aliasing effect?<br />2 .<br />Suppose a signal is sampled at the sampling rate Fs. Now you want to resample it at half<br />the rate 1/2Fs. From the lecture, one needs to insert a low pass filter with cut off<br />frequency at ¼Fs and beyond before the down sampling. This combined process is called<br />decimation. Please explain why the low pass filter is needed.<br /><br />~~谢谢您通俗的解释. |
