[文档下载] 在KEIL中印出BIN檔的大小
1422|5
 楼主| a_ziliu 发表于 2017-8-29 11:11 | 显示全部楼层 |阅读模式
利用批次檔的作法,把BUILD出來的BIN檔大小,打印在KEIL的輸出視窗。
Setup keil compare size.zip (423.84 KB, 下载次数: 22)
mintspring 发表于 2017-8-29 19:39 | 显示全部楼层
没懂是什么意思,Keil输出的时候下面消息窗口不是打印的有相关内容吗
gujiamao12345 发表于 2017-8-29 19:58 | 显示全部楼层
你指的是Code=76062 RO-data=7438 RW-data=1176 ZI-data=6248
*** Using Compiler 'V5.06 update 5 (build 528)', folder: 'D:\Keil_v5\ARM\ARMCC\Bin'
Rebuild target 'rtthread-stm32'
compiling application.c...
compiling startup.c...
compiling canapp.c...
compiling board.c...
compiling stm32f10x_it.c...
compiling led.c...
compiling usart.c...
compiling gpio.c...
compiling bxcan.c...
compiling system_stm32f10x.c...
compiling stm32f10x_crc.c...
compiling stm32f10x_rcc.c...
compiling stm32f10x_wwdg.c...
compiling stm32f10x_pwr.c...
compiling stm32f10x_exti.c...
compiling stm32f10x_bkp.c...
compiling stm32f10x_i2c.c...
compiling stm32f10x_adc.c...
compiling stm32f10x_dac.c...
compiling stm32f10x_rtc.c...
compiling stm32f10x_fsmc.c...
compiling stm32f10x_tim.c...
compiling stm32f10x_iwdg.c...
compiling stm32f10x_spi.c...
compiling stm32f10x_flash.c...
compiling stm32f10x_sdio.c...
compiling stm32f10x_gpio.c...
compiling stm32f10x_usart.c...
compiling stm32f10x_dbgmcu.c...
compiling stm32f10x_dma.c...
compiling stm32f10x_can.c...
compiling stm32f10x_cec.c...
compiling misc.c...
assembling startup_stm32f10x_hd.s...
compiling clock.c...
compiling components.c...
compiling device.c...
compiling idle.c...
compiling ipc.c...
compiling irq.c...
compiling kservice.c...
compiling mem.c...
compiling mempool.c...
compiling object.c...
compiling scheduler.c...
compiling thread.c...
compiling timer.c...
compiling cpuport.c...
assembling context_rvds.S...
compiling backtrace.c...
compiling div0.c...
compiling showmem.c...
compiling can.c...
compiling pin.c...
compiling serial.c...
compiling completion.c...
compiling dataqueue.c...
compiling pipe.c...
compiling portal.c...
compiling ringbuffer.c...
compiling workqueue.c...
compiling shell.c...
compiling symbol.c...
compiling cmd.c...
compiling finsh_compiler.c...
compiling finsh_error.c...
compiling finsh_heap.c...
compiling finsh_init.c...
compiling finsh_node.c...
compiling finsh_ops.c...
compiling finsh_parser.c...
compiling finsh_var.c...
compiling finsh_vm.c...
compiling finsh_token.c...
linking...
Program Size: Code=76062 RO-data=7438 RW-data=1176 ZI-data=6248
After Build - User command #1: fromelf --bin .\build\rtthread-stm32.axf --output rtthread.bin
After Build - User command #2: F:\code\bsp\stm32f10x\test.bat
File is >= 12000 bytes
File  83812 bytes
".\build\rtthread-stm32.axf" - 0 Error(s), 0 Warning(s).
Build Time Elapsed:  00:00:30
gujiamao12345 发表于 2017-8-29 20:00 | 显示全部楼层
多谢,话说bat你是参考哪里的?
mintspring 发表于 2017-8-29 21:44 | 显示全部楼层
噢,明白了,多谢楼主。
xinpian101 发表于 2017-8-29 22:00 | 显示全部楼层
瞧瞧怎么做的。
