DATASHEET有说明,是我没看仔细:
(1) A pull-up is applied to PF4 during the reset phase. This pin is input floating after reset release.
(2)AIN12 is not selectable in ADC scan mode or with analog watchdog.
(3) In 44-pin package, AIN9 cannot be used by ADC scan mode.
(4) In the open-drain output column, ‘T’ defines a true open-drain I/O (P-buffer and protection diode to VDD are not implemented).
(5)The PD1 pin is in input pull-up during the reset phase and after internal reset release.
