做一个很简单的测试
在ISE的SCH里调用EDK的symbol,EDK的功能也很简单,就是CPU通过串品打印一串字符
首先,我建一个ISE工程
再建一source sch类型,并设置为顶层,取名为top.sch
再建一source 类型为Embedded processor,取名为mycpu
然后EDK自动打开,我根据向导添加外设,设置时钟,直到finish
然后在edk下generate netlist, generate lib and bsp,builder all user app。
再回到ISE下,选中mycpu, create schematic symbol,并将该symbol添加到top.sch中
再添加端口,约束管脚
最后综合,生成bit
但到Translate 时,就通不过了
报如下错误
不知是何故,网上搜了很久,还是未解决
软件为12.2版本
Processing BMM file "edkBmmFile.bmm" ...
ERROR:NgdBuild:989 - Failed to process BMM information edkBmmFile.bmm
Checking expanded design ...
ERROR:NgdBuild:604 - logical block 'microblaze_0/proc_sys_reset_0' with type
'proc_sys_reset_0_wrapper' could not be resolved. A pin name misspelling can
cause this, a missing edif or ngc file, case mismatch between the block name
and the edif or ngc file name, or the misspelling of a type name. Symbol
'proc_sys_reset_0_wrapper' is not supported in target 'spartan3a'.
ERROR:NgdBuild:604 - logical block 'microblaze_0/mdm_0' with type
'mdm_0_wrapper' could not be resolved. A pin name misspelling can cause this,
a missing edif or ngc file, case mismatch between the block name and the edif
or ngc file name, or the misspelling of a type name. Symbol 'mdm_0_wrapper'
ERROR:NgdBuild:604 - logical block 'microblaze_0/clock_generator_0' with type
'clock_generator_0_wrapper' could not be resolved. A pin name misspelling can
'clock_generator_0_wrapper' is not supported in target 'spartan3a'.
ERROR:NgdBuild:604 - logical block 'microblaze_0/RS232' with type
'rs232_wrapper' could not be resolved. A pin name misspelling can cause this,
or ngc file name, or the misspelling of a type name. Symbol 'rs232_wrapper'
ERROR:NgdBuild:604 - logical block 'microblaze_0/lmb_bram' with type
'lmb_bram_wrapper' could not be resolved. A pin name misspelling can cause
this, a missing edif or ngc file, case mismatch between the block name and
'lmb_bram_wrapper' is not supported in target 'spartan3a'.
ERROR:NgdBuild:604 - logical block 'microblaze_0/ilmb_cntlr' with type
'ilmb_cntlr_wrapper' could not be resolved. A pin name misspelling can cause
'ilmb_cntlr_wrapper' is not supported in target 'spartan3a'.
ERROR:NgdBuild:604 - logical block 'microblaze_0/dlmb_cntlr' with type
'dlmb_cntlr_wrapper' could not be resolved. A pin name misspelling can cause
'dlmb_cntlr_wrapper' is not supported in target 'spartan3a'.
ERROR:NgdBuild:604 - logical block 'microblaze_0/dlmb' with type 'dlmb_wrapper'
could not be resolved. A pin name misspelling can cause this, a missing edif
or ngc file, case mismatch between the block name and the edif or ngc file
name, or the misspelling of a type name. Symbol 'dlmb_wrapper' is not
ERROR:NgdBuild:604 - logical block 'microblaze_0/ilmb' with type 'ilmb_wrapper'
name, or the misspelling of a type name. Symbol 'ilmb_wrapper' is not
ERROR:NgdBuild:604 - logical block 'microblaze_0/mb_plb' with type
'mb_plb_wrapper' could not be resolved. A pin name misspelling can cause
'mb_plb_wrapper' is not supported in target 'spartan3a'.
ERROR:NgdBuild:604 - logical block 'microblaze_0/microblaze_0' with type
'microblaze_0_wrapper' could not be resolved. A pin name misspelling can
'microblaze_0_wrapper' is not supported in target 'spartan3a'.
Partition Implementation Status
No Partitions were found in this design.
NGDBUILD Design Results Summary:
Number of errors: 12
Number of warnings: 0
Total REAL time to NGDBUILD completion: 3 sec
Total CPU time to NGDBUILD completion: 3 sec
One or more errors were found during NGDBUILD. No NGD file will be written.
Writing NGDBUILD log file "top.bld"...
Process "Translate" failed
工程
知道的朋友帮我看一下,谢谢 |
