-- PCI Compiler Wizard Data
-- DO NOT EDIT FOLLOWING DATA
-- @Altera, IP Toolbench@
-- Warning: If you modify this section, PCI Compiler Wizard may not be able to reproduce your chosen configuration.
-- Retrieval info: <?xml version="1.0"?>
-- Retrieval info: <MEGACORE title="PCI Compiler" version="10.0" build="218" iptb_version="1.3.0 Build 218" format_version="120" >
-- Retrieval info: <NETLIST_SECTION active_core="pci_mt32" >
