嵌入式DSP开发---dm642的视频口输出
void VP1_EDMA(int displayMode,unsigned int w,unsigned int h)
unsigned int i=0,k=0;
EDMA_Handle handle;
EDMA_Handle handle2;
EDMA_Config myEdmaConfig;
handle= EDMA_open(EDMA_CHA_VP1EVTYA, EDMA_OPEN_RESET);
handle2 = EDMA_allocTable(-1);
if(displayMode==DISPLAY_640_480)
for(i=0;i<h;i++)
for(k=0;k<w;k++)
if(i<(h/2))
if(k<(w/2))
*(unsigned int*)(0x81000000 + (w*i+k)*4 )=0xfc000;//0xfc000
else
*(unsigned int*)(0x81000000 + (w*i+k)*4 )=0x3fc0;//0xfc000
else
if(k<(w/2))
*(unsigned int*)(0x81000000 + (w*i+k)*4 )=0x3f;//0xfc000
else
*(unsigned int*)(0x81000000 + (w*i+k)*4 )=0xfffc0;//0xfc000
//// PRI ESIZE 2DS SUM 2DD DUM link FS
myEdmaConfig.opt = 2<<29|0<<27|1<<26|1<<24|0<<23|0<<21|1<<1|0;
myEdmaConfig.src = (Uint32)(0x81000000);
myEdmaConfig.cnt = 0x01df0280;//FRMCNT ELECNT (480*640)
myEdmaConfig.dst = 0X78000020;//DST
myEdmaConfig.idx = 0x0a000000;//FRMIDX ELEIDX
myEdmaConfig.rld = handle2;//ELERLD LINK
EDMA_config(handle,&myEdmaConfig);
EDMA_config(handle2,&myEdmaConfig);
//EDMA_setChannel(handle);// *(unsigned int*)(0X01A0FFbC)=0x01000000;//触发通道56 第一次发送数据ESR
EDMA_setEvtPolarity(handle,EDMA_EVT_HIGHLOW);//*(unsigned int*)(0X01A0FF9c)=0x01000000; //EPRh Event polarity low register 1 falling edge ;0 rising edge
EDMA_enableChaining(handle); //*(unsigned int*)(0X01A0FFac)=0x01000000;//EDMA Channel Chain Enable high Register (CCERh) Field Descriptions
EDMA_intEnable(handle); //*(unsigned int*)(0X01A0FFa8)=0x01000000; //Channel interrupt enable high register
EDMA_enableChannel(handle); // *(unsigned int*)(0X01A0FFb4)=0x01000000;//EERH EDMA Event Enable high Register
void VP1_Display(int displayMode)
int h_total, v_total, h_actv, v_actv;
h_total=800; v_total =525; h_actv = 640; v_actv = 480;
// h_total=1056; v_total=628; h_actv = 800; v_actv = 600;
// h_total=1344; v_total=806; h_actv = 1024; v_actv = 768;
// GetCLK_307(25);
*(unsigned int*)(0x01b3f018) = 0x10c0010c;//解锁
*(unsigned int*)(0x01b3f000) = 0x28;//open vp1 使能位 bit6 vp2 bit5 vp1 bit4 vp0 bit3 i2c
*(unsigned int*)(0x01b3f018) = 0x0;//锁定
delay_loop3(0x2000);//延迟必须
*(unsigned int*)(0x01C44000 + 0x004) = 0x05;//PCR 使能位bit2 vp1 enable bit0 free run
*(unsigned int*)(0x01C44000 + 0x024) = 0x00711511;//PDIR配置视频24个管脚输出 1 output 0缺省 input
*(unsigned int*)(0x01C44000 + 0x038) = 0x00200000; //Video Port Pin Interrupt Enable Register
*(unsigned int*)(0x01C44000 + 0x03c) = 0x00200000; //Video Port Pin Interrupt Polarity Register
*(unsigned int*)(0x01C44000 + 0x0c8) = 0x17cf9; //VPIE
*(unsigned int*)(0x01C44000 + 0x0c0) = 0x4032;/// VPCTL) bit7DCLK 4 HS 5 VS 极性 1 enable
*(unsigned int*)(0x01C44000 + 0x204) = 0x80000000;//vd reset
delay_loop3(0x10000);
*(unsigned int*)(0x01C44000 + 0x208) = ((v_total<<16)|h_total); //VDFRMSZ 525行 800个像素
*(unsigned int*)(0x01C44000 + 0x20c) = (((h_total-1)<<16)|(h_actv-1));//VDHBLNK 800-640 -1 end start
*(unsigned int*)(0x01C44000 + 0x210) = (((v_actv-2)<<16)|0);//VDVBLKS1 478 0 start
*(unsigned int*)(0x01C44000 + 0x214) = (((v_total-1)<<16)|0);//VDVBLKE1 524 0 end
*(unsigned int*)(0x01C44000 + 0x220) = ((0<<16)|0);//VDIMGOFF1
*(unsigned int*)(0x01C44000 + 0x224) = ((v_actv<<16)|h_actv);//VDIMGSZ1 图像有效区域480 640
*(unsigned int*)(0x01C44000 + 0x23c) = (((h_total-1)<<16)|(h_actv-1));//VDHSYNC 639-799
*(unsigned int*)(0x01C44000 + 0x240) = (((v_actv-2)<<16)|0);//VDVSYNS1 478
*(unsigned int*)(0x01C44000 + 0x244) = (((v_total-1)<<16)|0);//VDVSYNE1 524
VP1_EDMA( displayMode,h_actv,v_actv);
*(unsigned int*)(0x01C44000 + 0x230) = 0x00000000;//VDFLDT1
*(unsigned int*)(0x01C44000 + 0x238) = 0x00001000|(h_actv/2);//VDTHRLD 50
*(unsigned int*)(0x01C44000 + 0x254) = 0x00000000|(v_actv);//VDDISPEVT 1
*(unsigned int*)(0x01C44000 + 0x260) = 0x00008006; //VDVINT
*(unsigned int*)(0x01C44000 + 0x25c) = 0x3fc0;//VDDEFVAL 缺省数据设置 red 20位 6:8:6
*(unsigned int*)(0x01C44000 + 0x204) = 0x400080c7;//VDCTL VCTL filed 选择 输出模式选择bit2-0
delay_loop3(0x80000);//延迟必须
*(unsigned int*)(0x01C44000 + 0x204) = 0x000080d7;
*(unsigned int*)(0x01C44000 + 0x204) = 0x000080c7;
///////////////////////////////////////////暂停重新开始
*(unsigned int*)(0X01A0FFb4)=0x00000000;//EERH EDMA Event Enable high Register
