大家好,这两天在调试tft屏上带的触控功能ic---ADS7843,但是无论用STM32F107的GPIO模拟spi或是SPI3,读出来的数据都是oxfff,请大家帮忙解答一下.....
TPCS --->PB8
TPCLK -->PC10
TPMOSI -->PC12
TPMISO -->PC11
TPIRQ -->PC5
/*******************************GPIO模拟方式*********************************/
/************* H 文件 **************/
#ifndef ADS7843_H
#define ADS7843_H
CS :PB8
SCK :PC10
MOSI :PC12
MISO :PC11
INT :PC5
extern u16 TP_x,TP_y;
#define TP_CS() GPIO_ResetBits(GPIOB,GPIO_Pin_8)
#define TP_DCS() GPIO_SetBits(GPIOB,GPIO_Pin_8)
#define TP_DCLK2L() GPIO_ResetBits(GPIOC,GPIO_Pin_10)
#define TP_DCLK2H() GPIO_SetBits(GPIOC,GPIO_Pin_10)
#define TP_DOUT2L() GPIO_ResetBits(GPIOC,GPIO_Pin_12)
#define TP_DOUT2H() GPIO_SetBits(GPIOC,GPIO_Pin_12)
#define TP_RD_DIN() GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_11)
#define TP_RD_INT() GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_5)
void ADS7843_GPIO_Config(void) ;
void spistar(void);
void WriteCharTo7843(unsigned char num);
unsigned int ReadFromCharFrom7843(void) ;
void AD7843(void) ; //获取横坐标和纵坐标
#endif
/************* C 文件 **************/
#include "stm32f10x.h"
#include "ads7842_gpio.h"
//SPI3 Periph clock enable
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3,ENABLE);
//SPI2 Periph clock enable
// RCC_APB1PeriphClockCmd( RCC_APB1Periph_SPI2, ENABLE ) ;
//Configure SPI3 pins: SCK, MISO and MOSI
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_12;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 SCK MOSI
GPIO_Init(GPIOC,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 TP__CS
GPIO_Init(GPIOB,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //上拉输入 MISO
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //上拉输入 TP__PEN IRQ INT
void spistar() //SPI开始
TP_CS(); //CS=1;
TP_DCLK2H();//DCLK=1;
TP_DOUT2H();//DIN=1;
void WriteCharTo7843(unsigned char num) //SPI写数据
unsigned char count=0;
unsigned char tp_in=0;
TP_DCLK2L();//DCLK=0;
for(count=0;count<8;count++)
tp_in=num&0x80;
if(tp_in==1) TP_DOUT2H(); //DIN=CY;
if(tp_in==0) TP_DOUT2L();
num<<=1;
__nop();__nop();__nop(); //上升沿有效
unsigned int ReadFromCharFrom7843() //SPI 读数据
unsigned int Num=0;
for(count=0;count<16;count++)
Num<<=1;
__nop();__nop();__nop(); //下降沿有效
if(TP_RD_DIN())Num++; //if(DOUT) Num++;
Num=Num>>3;
return(Num);
void AD7843(void) //获取横坐标和纵坐标
TP_DCS();//CS=0;
//delayms(1); //中断后延时以消除抖动,使得采样数据更准确
//while(BUSY); //如果BUSY信号不好使可以删除不用
//delayms(1);
WriteCharTo7843(0x90); //送控制字 10010000 即用差分方式读X坐标 详细请见有关资料
//delayms(1);
__nop();__nop();__nop();__nop();
TP_y=ReadFromCharFrom7843();
WriteCharTo7843(0xD0); //送控制字 11010000 即用差分方式读Y坐标 详细请见有关资料
TP_x=ReadFromCharFrom7843();
TP_CS();//CS=1;
/*********************************** SPI3 ***************************************/
#ifndef ADS7843_H
#define ADS7843_H
#define TP_CS() GPIO_ResetBits(GPIOA,GPIO_Pin_4)
#define TP_DCS() GPIO_SetBits(GPIOA,GPIO_Pin_4)
// GPIO_PinRemapConfig(GPIO_Remap_SPI1, ENABLE );
void SPI_Config(void) ;
unsigned char SPI_WriteByte(unsigned char data);
void SpiDelay(unsigned int DelayCnt);
u16 TPReadX(void);
u16 TPReadY(void);
#endif
#include "ads7843_wht.h"
SPI_InitTypeDef SPI_InitStructure;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 SCK MOSI
GPIO_PinRemapConfig(GPIO_Remap_SPI3, ENABLE ); //外设端口重映射 开启
// SPI3 Config
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //SPI_NSS_Hard
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI3,&SPI_InitStructure);
// SPI1 enable
SPI_Cmd(SPI3,ENABLE);
unsigned char Data = 0;
//Wait until the transmit buffer is empty
while(SPI_I2S_GetFlagStatus(SPI3,SPI_I2S_FLAG_TXE)==RESET);
// Send the byte
SPI_I2S_SendData(SPI3,data);
//Wait until a data is received
while(SPI_I2S_GetFlagStatus(SPI3,SPI_I2S_FLAG_RXNE)==RESET);
// Get the received data
Data = SPI_I2S_ReceiveData(SPI3);
// Return the shifted data
return Data;
unsigned int i;
for(i=0;i<DelayCnt;i++);
u16 TPReadX(void)
u16 x=0;
TP_CS();
SpiDelay(10);
SPI_WriteByte(0x90);
SpiDelay(10);
x=SPI_WriteByte(0x00);
x<<=8;
x+=SPI_WriteByte(0x00);
SpiDelay(10);
TP_DCS();
x = x>>3;
return (x);
u16 TPReadY(void)
u16 y=0;
TP_CS();
SpiDelay(10);
SPI_WriteByte(0xD0);
SpiDelay(10);
y=SPI_WriteByte(0x00);
y<<=8;
y+=SPI_WriteByte(0x00);
SpiDelay(10);
TP_DCS();
y = y>>3;
return (y);
GPIO和外设的始终在main文件中已经使能。SPI3是重映射后的引脚。 |
