The first problem is if you choose resistive divider, there is no PSRR compare to real bandgap reference.
Assuming these two resistors has the same temperature coefficient and long term drift, then the only time and temperature depedence is from OPA.
Since OPA has almost infinity PSRR compare to resistive divider in low frequency, this is not so important, but you should consider the input bisa current, offset voltage/current, sure the time/temp drift is the main parameter which will effect your measurement. The offset can be measured and compensated, but drift can not be.
Voffset,out=A*Voffset,in
for most CMOS OPA, with nominal input offset voltage, the output voltage is saturated.
