我现在刚接触这款单片机,通讯弄不起来,我是用中断方式的,现在数据都有问题,我我是收完发送回一个数据给上位机,但是现在不好使,并且单收单发也有问题,现在把程序粘上来,请各位帮帮忙,感激不尽
#define USART_GLOBALS
#include "include.h"
//串行口
//uchar time_uar_period; /*两次接收成功之间的间隔*/
//uchar time_rece_byte; /*接收两个字节之间的间隔*/
volatile uchar cnt_rece_num;//接收到的字节个数
volatile uchar cnt_tras_num;//发送字节个数
volatile uchar checkoutError; //接收数据错误
uchar uar_tras_buf[40]; /*连续发送40个字节*/
uchar uar_rece_buf[30]; /*连续接收30个字节*/
uchar uar_tras_succeed;
uchar uar_rece_succeed;
uchar fg_now_receive;
uchar sendPosi; //发送位
void deal_usart(void);
uint getRegisterVal(uint addr);
uint setCoilVal(uint addr,uint tempData);
uint setRegisterVal(uint addr,uint tempData);
/* CRC 高位字节值表 */
const uchar auchCRCHi[] = {
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
/* CRC低位字节值表*/
const uchar auchCRCLo[] = {
0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06,
0x07, 0xC7, 0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD,
0x0F, 0xCF, 0xCE, 0x0E, 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09,
0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9, 0x1B, 0xDB, 0xDA, 0x1A,
0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC, 0x14, 0xD4,
0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3,
0xF2, 0x32, 0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4,
0x3C, 0xFC, 0xFD, 0x3D, 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A,
0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38, 0x28, 0xE8, 0xE9, 0x29,
0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF, 0x2D, 0xED,
0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60,
0x61, 0xA1, 0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67,
0xA5, 0x65, 0x64, 0xA4, 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F,
0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB, 0x69, 0xA9, 0xA8, 0x68,
0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA, 0xBE, 0x7E,
0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71,
0x70, 0xB0, 0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92,
0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,
0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B,
0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89, 0x4B, 0x8B,
0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42,
0x43, 0x83, 0x41, 0x81, 0x80, 0x40
//串行口
void uart0_init(void)
USART1_BRR2 = 0x00; //disable while setting baud rate
USART1_BRR1 = 0x00;
//UCSRC = 0xA6; //异步 8位数据 1停止位 偶校验
//UBRRL = 0x33; //set baud rate as 9600
//UBRRH = 0x00;
USART1_CR3 = 0x00;
switch (data_value)
case 0:
USART1_CR1 = 0x00; //异步 8位数据 1停止位 无校验
break;
case 2:
USART1_CR1 = 0x06; //异步 8位数据 1停止位 奇校验
break;
case 1:
USART1_CR1 = 0x04; //异步 8位数据 1停止位 偶校验
break;
default:
break;
//8000000/9600=0x0341
//8000000/4800 = 0x0682
switch (baud_value)
case 0:
USART1_BRR2 = 0x02; //set baud rate as 4800
USART1_BRR1 = 0x68;
break;
case 1:
USART1_BRR2 = 0x01; //set baud rate as 9600
USART1_BRR1 = 0x34;
break;
default:
break;
//UART1_CR2 = 0xD8; //允许接收发送及中断,数据位为8位
USART1_CR2_TCIEN=1;
USART1_CR2_RIEN=1;
USART1_CR2_TEN=1;
USART1_CR2_REN=1;
USART1_CR1 &= 0xDF;
RECE_485;//485接收允许
cnt_tras_num=0;
cnt_rece_num=0;
uar_rece_succeed=0;
uar_tras_succeed=0;
fg_now_receive=0;
checkoutError = 0;
#pragma vector=USART_R_RXNE_vector
__interrupt void uart0_rx_isr(void)
//uart has received a character in UDR
uchar temp;
if ((USART1_SR_FE==1)||(USART1_SR_OR==1)||(USART1_SR_PE==1))
checkoutError = 1;
//接收错误 //未用到
fg_now_receive = 1;
temp = USART1_DR;
uar_rece_buf[cnt_rece_num] = temp;
checkoutError = 0;
//地址不正确,扔掉数据
if (uar_rece_buf[0] != addr_value)
cnt_rece_num = 0;
checkoutError = 1;
else if (cnt_rece_num<30)
cnt_rece_num++;//防止数组越界
#pragma vector = USART_T_TXE_vector
__interrupt void uart0_tx_isr(void)
//character has been transmitted
if (++sendPosi<cnt_tras_num)
while (!USART1_SR_TXE) ;
USART1_DR = uar_tras_buf[sendPosi];
else
uar_tras_succeed = 1;
uar_rece_succeed = 0;
RECE_485;//485接收允许
cnt_rece_num = 0;//清接收地址偏移寄存器
checkoutError = 0;
USART1_SR_TC = 0;
//crc16校验程序
uint crc16(uchar *puchMsg, uint usDataLen)
uchar uchCRCHi = 0xFF ; /* 高CRC字节初始化 */
uchar uchCRCLo = 0xFF ; /* 低CRC 字节初始化 */
unsigned long uIndex ; /* CRC循环中的索引 */
while (usDataLen--) /* 传输消息缓冲区 */
uIndex = uchCRCHi ^ *puchMsg++ ; /* 计算CRC */
uchCRCHi = uchCRCLo ^ auchCRCHi[uIndex] ;
uchCRCLo = auchCRCLo[uIndex] ;
return (uchCRCHi << 8 | uchCRCLo) ;
//开始发送
void beginSend(void)
SEND_485; //设为发送
while (USART1_SR_TXE==0) ; //发送数据寄存器空
sendPosi = 0;
//读寄存器
void readRegisters(void)
uint addr;
uint tempAddr;
uint crcData;
uint readCount;
uint byteCount;
uint i;
uint tempData = 0;
//起始地址
addr = (uar_rece_buf[2]<<8) + uar_rece_buf[3];
tempAddr = addr & 0xffff;
//寄存器数量
readCount = (uar_rece_buf[4]<<8) + uar_rece_buf[5]; //要读的个数
byteCount = readCount * 2;
for(i=0; i<byteCount; i+=2,tempAddr++)
tempData = getRegisterVal(tempAddr);
uar_tras_buf[i+3] = tempData >> 8;
uar_tras_buf[i+4] = tempData & 0xff;
uar_tras_buf[0] = addr_value;
uar_tras_buf[1] = 0x03;
uar_tras_buf[2] = byteCount;
byteCount += 3;
crcData = crc16(uar_tras_buf,byteCount);
uar_tras_buf[byteCount] = crcData >> 8;
byteCount++;
uar_tras_buf[byteCount] = crcData & 0xff;
cnt_tras_num = byteCount + 1;
beginSend();
//强制单个线圈
void forceSingleCoil(void)
uint addr;
uint tempAddr;
uint tempData;
uint onOff;
uchar i;
onOff = (uar_rece_buf[4]<<8) + uar_rece_buf[5];
if(onOff == 0xff00)
{ //设为ON
tempData = 1;
else if(onOff == 0x0000)
{ //设为OFF
tempData = 0;
setCoilVal(tempAddr,tempData);
for(i=0;i<cnt_rece_num;i++)
uar_tras_buf = uar_rece_buf;
cnt_tras_num = cnt_rece_num;
beginSend();
//设置单个寄存器
void presetSingleRegisters(void)
uint addr;
uint tempAddr;
uint crcData;
uint tempData;
addr = (uar_rece_buf[2]<<8) +uar_rece_buf[3];
tempData = (uar_rece_buf[4]<<8) + uar_rece_buf[5];
setRegisterVal(tempAddr,tempData);
uar_tras_buf[1] = 0x06;
uar_tras_buf[2] = addr >> 8;
uar_tras_buf[3] = addr & 0xff;
uar_tras_buf[4] = tempData >> 8;
uar_tras_buf[5] = tempData & 0xff;
crcData = crc16(uar_tras_buf,6);
uar_tras_buf[6] = crcData >> 8;
uar_tras_buf[7] = crcData & 0xff;
cnt_tras_num = 8;
beginSend();
//设置多个寄存器
void presetMultipleRegisters(void)
uint addr;
uint tempAddr;
//uchar byteCount;
uint setCount;
uint crcData;
uint tempData;
uchar i;
setCount = (uar_rece_buf[4]<<8) + uar_rece_buf[5];
//byteCount = uar_rece_buf[6];
for(i=0;i<setCount;i++,tempAddr++)
tempData = (uar_rece_buf[i*2+7]<<8) + uar_rece_buf[i*2+8];
uar_tras_buf[1] = 16;
uar_tras_buf[4] = setCount >> 8;
uar_tras_buf[5] = setCount & 0xff;
cnt_tras_num = 8;
beginSend();
//检查uart0数据
void checkComm0Modbus(void)
uint crcData;
uint tempData;
if(cnt_rece_num> 4)
switch(uar_rece_buf[1])
//case 1://读取线圈状态(读取点 16位以内)
case 3://读取保持寄存器(一个或多个)
case 5://强制单个线圈
case 6://设置单个寄存器
if(cnt_rece_num >= 8)
{//接收完成一组数据
//应该关闭接收中断
if((uar_rece_buf[0]==addr_value) && (checkoutError==0))
crcData = crc16(uar_rece_buf,6);
if(crcData == uar_rece_buf[7]+(uar_rece_buf[6]<<8))
{//校验正确
if(uar_rece_buf[1] == 3)
{//读取保持寄存器(一个或多个)
readRegisters();
else if(uar_rece_buf[1] == 5)
{//强制单个线圈
forceSingleCoil();
else if(uar_rece_buf[1] == 6)
presetSingleRegisters();
cnt_rece_num = 0;
checkoutError = 0;
break;
//case 15://设置多个线圈
// break;
case 16://设置多个寄存器
tempData = tempData * 2; //数据个数
tempData += 9;
if(cnt_rece_num >= tempData)
if(uar_rece_buf[0]==addr_value && checkoutError==0)
crcData = crc16(uar_rece_buf,tempData-2);
if(crcData == (uar_rece_buf[tempData-2]<<8)+ uar_rece_buf[tempData-1])
presetMultipleRegisters();
cnt_rece_num = 0;
checkoutError = 0;
break;
default:
break;
//设定线圈状态 返回0表示成功
uint result = 0;
uint tempAddr;
switch(tempAddr & 0xff)
case 0:
if (tempData==0x00FF)
RELAY_H;
else if (tempData==0xFF00)
RELAY_L;
break;
case 1:
RELAY1_H;
RELAY1_L;
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
case 7:
break;
case 8:
break;
case 9:
break;
case 10:
break;
case 11:
break;
case 12:
break;
case 13:
break;
case 14:
break;
case 15:
break;
//break;
default:
break;
return result;
//取寄存器值 返回0表示成功
uint tempAddr;
uint tempData;
//uint testRegister[2];
tempAddr = addr & 0xff ;
switch(tempAddr&0xFF)
case 0:
break;
default:
break;
return tempData;
//设置寄存器值 返回0表示成功
uint result = 0;
uint tempAddr;
tempAddr = addr & 0xff;
case 0:
break;
default:
break;
return result;
