ARM面向学校开放FULL RTL版M0和M3
2072|3
 楼主| gxliu08 发表于 2017-9-22 13:08 | 显示全部楼层 |阅读模式
ARM, RTL, TE, AN, AC
We are very pleased to inform you that we recently launched a new and simplified way to access fully configurable versions of the Arm Cortex-M0 and Cortex-M3 processors.  The Cortex-M0 and Cortex-M3 DesignStart Pro Academic packages are now available for approved academics and researchers to download via a simple click-through license agreement.  Researchers with approved projects will have the ability to quickly access a fully configurable, full RTL Cortex-M CPU, subsystem and system IP. You can even manufacture up to a 1000 test chips for your research or teaching.
 楼主| gxliu08 发表于 2017-9-22 13:09 | 显示全部楼层
ARM公司给俺的信,终于不是加密的IP核了。
你好,可以给一份pro版本的开发包吗?我的邮箱是[email]304067446@qq.com[/email] 。自己感兴趣但我所在的公司不是芯片行业内公司,所以只申请到了eval版本,想研究一下pro版本的代码,先谢谢了!  发表于 2019-8-6 12:34
forevercyc 发表于 2019-8-6 12:33 | 显示全部楼层
你好,可以给一份pro版本的开发包吗?我的邮箱是304067446@qq.com 。自己感兴趣但我所在的公司不是芯片行业内公司,所以只申请到了eval版本,想研究一下pro版本的代码,先谢谢了!
