| EE_BeagleBone_Cape之矩阵键盘
 1.        概述
 这篇文档是关于EE_BeagleBone_Cape  4x4矩阵键盘的设计相关,欢迎大伙拍砖
 2.        矩阵键盘硬件连接
 具体使用了以下几个管脚: gpio0[15]        Row1gpio3[21]        Row2
 gpio0[14]        Row3
 gpio3[19]        Row4
 gpio3[17]        Col1
 gpio3[15]        Col2
 gpio3[16]        Col3
 gpio3[14]        Col4
 复制代码
 3.        矩阵键盘设计点滴
 1.        注意我这个4x4的矩阵键盘没有外接电阻哦,所以作为输入的引脚做好拉地,配置成AM33XX_PIN_INPUT_PULLDOWN
 2.        注意Row和Col的引脚输入输出关系不要定义反了,Row为input,Col为output。我开始的时候定义反了搞死都出不来结果。
 4.        代码相关
 4.1        Pinmux
 看看4x4键盘涉及到的几个管脚的定义吧,如下所示:
 /* Matrix GPIO Keypad Support for profile-0 only: TODO */
 /* pinmux for keypad device */
 static struct pinmux_config matrix_keypad_pin_mux[] = {
 {"uart1_txd.gpio0_15",        OMAP_MUX_MODE7 | AM33XX_PIN_INPUT_PULLDOWN},
 {"mcasp0_ahclkx.gpio3_21",    OMAP_MUX_MODE7 | AM33XX_PIN_INPUT_PULLDOWN},
 {"uart1_rxd.gpio0_14",        OMAP_MUX_MODE7 | AM33XX_PIN_INPUT_PULLDOWN},
 {"mcasp0_fsr.gpio3_19",       OMAP_MUX_MODE7 | AM33XX_PIN_INPUT_PULLDOWN},
 {"mcasp0_ahclkr.gpio3_17",    OMAP_MUX_MODE7 | AM33XX_PIN_OUTPUT},
 {"mcasp0_fsx.gpio3_15",       OMAP_MUX_MODE7 | AM33XX_PIN_OUTPUT},
 {"mcasp0_axr0.gpio3_16",      OMAP_MUX_MODE7 | AM33XX_PIN_OUTPUT},
 {"mcasp0_aclkx.gpio3_14",     OMAP_MUX_MODE7 | AM33XX_PIN_OUTPUT},
 {NULL, 0},
 /* Keys mapping */
 static const uint32_t am335x_evm_matrix_keys[] = {
 KEY(0, 0, KEY_A),
 KEY(1, 0, KEY_3),
 KEY(2, 0, KEY_2),
 KEY(3, 0, KEY_1),
 KEY(0, 1, KEY_B),
 KEY(1, 1, KEY_6),
 KEY(2, 1, KEY_5),
 KEY(3, 1, KEY_4),
 KEY(0, 2, KEY_C),
 KEY(1, 2, KEY_9),
 KEY(2, 2, KEY_8),
 KEY(3, 2, KEY_7),
 KEY(0, 3, KEY_D),
 KEY(1, 3, KEY_OK),
 KEY(2, 3, KEY_0),
 KEY(3, 3, KEY_DELETE),
 const struct matrix_keymap_data am335x_evm_keymap_data = {
 .keymap      = am335x_evm_matrix_keys,
 .keymap_size = ARRAY_SIZE(am335x_evm_matrix_keys),
 static const unsigned int am335x_evm_keypad_row_gpios[] = {
 GPIO_TO_PIN(0, 15), GPIO_TO_PIN(3, 21), GPIO_TO_PIN(0, 14), GPIO_TO_PIN(3, 19)
 static const unsigned int am335x_evm_keypad_col_gpios[] = {
 GPIO_TO_PIN(3, 17), GPIO_TO_PIN(3, 15), GPIO_TO_PIN(3, 16), GPIO_TO_PIN(3, 14)
 static struct matrix_keypad_platform_data am335x_evm_keypad_platform_data = {
 .keymap_data       = &am335x_evm_keymap_data,
 .row_gpios         = am335x_evm_keypad_row_gpios,
 .num_row_gpios     = ARRAY_SIZE(am335x_evm_keypad_row_gpios),
 .col_gpios         = am335x_evm_keypad_col_gpios,
 .num_col_gpios     = ARRAY_SIZE(am335x_evm_keypad_col_gpios),
 .active_low        = false,
 .debounce_ms       = 5,
 .col_scan_delay_us = 2,
 static struct platform_device am335x_evm_keyboard = {
 .name  = "matrix-keypad",
 .id    = -1,
 .dev   = {
 .platform_data = &am335x_evm_keypad_platform_data,
 static void matrix_keypad_init(int evm_id, int profile)
 int err;
 setup_pin_mux(matrix_keypad_pin_mux);
 err = platform_device_register(&am335x_evm_keyboard);
 if (err) {
 pr_err("failed to register matrix keypad (4x4) device\n");
 复制代码4.2        初始化
 /* Beaglebone Rev A3 and after */static struct evm_dev_cfg beaglebone_dev_cfg[] = {
 {tps65217_init,        DEV_ON_BASEBOARD, PROFILE_NONE},
 {mii1_init,        DEV_ON_BASEBOARD, PROFILE_NONE},
 {usb0_init,        DEV_ON_BASEBOARD, PROFILE_NONE},
 {usb1_init,        DEV_ON_BASEBOARD, PROFILE_NONE},
 {mmc0_init,        DEV_ON_BASEBOARD, PROFILE_NONE},
 {i2c1_init,     DEV_ON_BASEBOARD, PROFILE_NONE},
 {i2c2_init,        DEV_ON_BASEBOARD, PROFILE_NONE},
 {lcdc_init,        DEV_ON_BASEBOARD, (PROFILE_0 | PROFILE_1 |
 PROFILE_2 | PROFILE_7) },
 {evm_nand_init, DEV_ON_BASEBOARD,
 (PROFILE_ALL & ~PROFILE_2 & ~PROFILE_3)},
 {matrix_keypad_init, DEV_ON_BASEBOARD, PROFILE_0},
 {NULL, 0, 0},
 复制代码
 看看include\linux\Input.h关于键值的定义吧
 #define KEY_1                        2#define KEY_2                        3
 #define KEY_3                        4
 #define KEY_4                        5
 #define KEY_5                        6
 #define KEY_6                        7
 #define KEY_7                        8
 #define KEY_8                        9
 #define KEY_9                        10
 #define KEY_0                        11
 复制代码
 4.3        测试程序
 从网络上找个一个测试程序,能用!
 #include
 #include
 #include
 #include
 #include
 #include
 int fd;
 int loop_flag = 1;
 void exit_loop()
 loop_flag--;
 void deal_int(int signum)
 if(fd > 0)
 close(fd);
 exit_loop();
 int main()
 struct input_event evt;
 fd = open("/dev/input/event0",O_RDWR);
 if(fd < 0)
 printf("Can not open\n");
 while(loop_flag > 0)
 read(fd,&evt,sizeof(struct input_event));
 switch(evt.type)
 case EV_KEY:
 printf("Key -->\nCode: %d\nValue: %d\n",evt.code,evt.value);
 break;
 case EV_MSC:
 printf("MSC -->\nCode: %d\nValue: %d\n",evt.code,evt.value);
 break;
 case EV_SYN:
 printf("<-- \n");
 default:
 printf("...\n");
 return 0;
 复制代码
 4.4        测试结果
 MSC -->Code: 4
 Value: 12
 Key -->
 Code: 2       //  1
 Value: 1
 MSC -->
 Code: 4
 Value: 12
 Key -->
 Code: 2
 Value: 0
 MSC -->
 Code: 4
 Value: 9
 Key -->
 Code: 6      //  5
 Value: 1
 MSC -->
 Code: 4
 Value: 9
 Key -->
 Code: 6
 Value: 0
 MSC -->
 Code: 4
 Value: 6
 Key -->
 Code: 10    //  9
 Value: 1
 MSC -->
 Code: 4
 Value: 6
 Key -->
 Code: 10
 Value: 0
