进入中断不成功
3034|1
 楼主| king_sunshine 发表于 2011-5-4 17:42 | 显示全部楼层 |阅读模式
中断服务子程序:
void USART1_IRQHandler(void)
  //接受数据
  if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
    USART_ClearITPendingBit(USART1,USART_IT_RXNE);                              //清楚标记位
    //Read one byte from the receive data register
    RxBuffer[RxCounter++] = USART_ReceiveData(USART1);
    RxCounter = RxCounter % 8;
    while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET)
  //溢出-如果发生溢出需要先读SR,再读DR寄存器则可清除不断入中断的问题
    if(USART_GetFlagStatus(USART1,USART_FLAG_ORE)==SET)
      USART_ClearFlag(USART1,USART_FLAG_ORE);                                   //读SR其实就是清除标志
      USART_ReceiveData(USART1);                                                //读DR
    if(USART_ReceiveData(USART1) == '\0')                                       //判断是否接受完成
      RxBuffer[RxCounter] = '\0';
      // Disable the USART1 Receive interrupt
      USART_ITConfig(USART1, USART_IT_RXNE, DISABLE);
      USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
      GPIO_SetBits(GPIOA,GPIO_Pin_11);                                          //切换到发送模式
      RxCounter = 0;
   //发送 数据
  // USART_ITConfig(USART1, USART_IT_TXE, ENABLE);                                        为什么 就 死了
  if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET)
    USART_ClearITPendingBit(USART1,USART_IT_TXE);                              //清楚标记位
    // Write one byte to the transmit data register
    TxBuffer1[0] = 'A';
    TxBuffer1[1] = 'C';
    TxBuffer1[2] = 'K';
    TxBuffer1[3] = '\0';
    while(TxBuffer1[TxCounter] != '\0')
      USART_SendData(USART1,TxBuffer1[TxCounter]);//发送ACK信息
      while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET)
      TxCounter ++;
    TxCounter = 0;
    Delay(6000000);
    TxBuffer[0] = Charg_Vin;
    TxBuffer[1] = Charg_Vin >> 8;
    TxBuffer[2] = Charg_Voltage;
    TxBuffer[3] = Charg_Voltage >> 8;
    TxBuffer[4] = Charg_Current;
    TxBuffer[5] = Charg_Current >> 8;
    TxBuffer[6] = Charg_Distance;
    TxBuffer[7] = Charg_AutoDoor;
    TxBuffer[8] = Charg_Connect;
    TxBuffer[9] = '\0';
    while(TxBuffer[TxCounter] != '\0')
      USART_SendData(USART1, TxBuffer[TxCounter]);
      TxCounter ++;
    if(TxBuffer[TxCounter] == '\0')                                             //判断是否发送完成
      //Disable the USART1 Transmit interrupt
      USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
      USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
      GPIO_ResetBits(GPIOA,GPIO_Pin_11);                                        //切换到接受模式
      TxCounter = 0;
int main()
   while(1)
初始化如下:
void ChargeCTRL_RS485_Init(void)
  //RCC
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  //RCC_APB1PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); //P208
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
  //GPIO
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  //GPIO_ResetBits(GPIOB,GPIO_Pin_10);
    //485TRN
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  //GPIO_SetBits(GPIOA,GPIO_Pin_11);//PA.11 = 1 处于发送状态
  GPIO_ResetBits(GPIOA,GPIO_Pin_11);//PA.11 = 0 处于接受状态
  //USART
  USART_InitTypeDef USART_InitStructure;
  USART_InitStructure.USART_BaudRate = 9600;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  USART_Init(USART1, &USART_InitStructure);
  //CLOCK
  USART_ClockInitTypeDef USART_ClockInitStructure;
  USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
  USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
  USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
  USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
  USART_ClockInit(USART1,&USART_ClockInitStructure);
  //USART_ClearFlag(USART1, USART_FLAG_TC);
  //USART_ITConfig(USART1, USART_IT_RXNE, DISABLE);
  USART_Cmd(USART1, ENABLE);
   //NVIC
  NVIC_InitTypeDef NVIC_InitStructure;
  #ifdef   VECT_TAB_RAM
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
  #else
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
  #endif
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;               //通道设置为串口1中断
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;      //中断占先等级0
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;               //中断响应优先级0
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                 //打开中断
  NVIC_Init(&NVIC_InitStructure);
 楼主| king_sunshine 发表于 2011-5-4 17:43 | 显示全部楼层
进入中断不成功
望高手指点迷津,刚注册分数不多,请包涵,以后再发帖,再给你补上,呵呵~~
