FPGAIPlisence
661|0
 楼主| 半路杀出程咬金 发表于 2017-10-25 11:13 | 显示全部楼层 |阅读模式
出现这个错误Error (204012): Can't generate netlist output files because the file "D:/altera/LYQFPGAexample/FirIpCore3/FirIPCore/fir_compiler-library/auk_dspip_lib_pkg_fir_121.vhd" is an OpenCore Plus time-limited file
怎么解决?
网上都是把仿真改为none.但改为none怎么仿真
