28069_RAM_lnk.cmd
959|0
 楼主| MapleSugar 发表于 2017-11-20 10:19 | 显示全部楼层 |阅读模式
RAM, AI, TI, BLE, ge
"../28069_RAM_lnk.cmd", line 113: error #10099-D: program will not fit into available memory.  placement with alignment/blocking fails for section ".text" size 0x2210 page 0.  Available memory ranges:
   RAML0_L3     size: 0x2000       unused: 0x2000       max hole: 0x2000
我应该怎么修改cmd文件比较合适?
如果直接修改 RAML0_L3    : origin = 0x008000, length = 0x002000 中的  length = 0x003000 是否可以?
谢谢
