初始化方法
- void SYS_Init(void)
- /* Init System Clock */
- /* Enable Internal RC 22.1184MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
- /* Waiting for Internal RC clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
- /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
- /* Enable external XTAL 12MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
- /* Waiting for external XTAL clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
- /* Set core clock as PLL_CLOCK from PLL */
- CLK_SetCoreClock(PLL_CLOCK);
- /* Enable UART module clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Select UART module clock source */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
- /* Init I/O Multi-function */
- /* Set GPB multi-function pins for UART0 RXD(PB.0) and TXD(PB.1) */
- SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk);
- SYS->GPB_MFP |= (SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD);
- void UART0_Init(void)
- /* Init UART */
- /* Reset UART0 module */
- SYS_ResetModule(UART0_RST);
- /* Configure UART0 and set UART0 Baudrate */
- UART_Open(UART0, 115200);
