二极管一直亮着
870|14
 楼主| zwll 发表于 2017-12-17 15:40 | 显示全部楼层 |阅读模式
定时器Terminalcountout中断控制  一个发光二极管每一秒钟闪烁一次,但是程序下进后二极管一直亮着
chuxh 发表于 2017-12-17 15:43 | 显示全部楼层
是不是没有响应中断啊?
 楼主| zwll 发表于 2017-12-17 15:45 | 显示全部楼层
不知道啊
juventus9554 发表于 2017-12-17 15:48 | 显示全部楼层
程序代码呢
 楼主| zwll 发表于 2017-12-17 15:50 | 显示全部楼层
#include <m8c.h>        // part specific constants and macros
#include "PSoCAPI.h"    // PSoC API definitions for all User Modules
#pragma interrupt_handler Timer8_ISR_C
extern void Timer8_EnableInt(void);
extern void Timer8_DisableInt(void);
extern void Timer8_Start(void);
extern void Timer8_Stop(void);
extern BYTE Timer8_bReadTimer(void);
extern BYTE Timer8_bReadTimerSaveCV(void);
extern void Timer8_WritePeriod(BYTE bPeriod);
extern BYTE Timer8_bReadCompareValue(void);
extern void Timer8_WriteCompareValue(BYTE bCompareValue);
void main()
     // Insert your main routine code here.
         //Timer8_WritePeriod(183);
         M8C_EnableGInt;
         Timer8_EnableInt();
         Timer8_Start();
        while(1);
void Timer8_ISR_C()
    PRT0DR^ =0x02;
芯片配置
Global Resources
CPU_Clock =12 MHz
VC1 =16             Divide 24 MHz SysClock by 16.
VC2 =16             Divide VC1 by 16.
VC3 Source =VC2     Set the source for VC3 as VC2.
VC3 Divider =256    Divide VC2 by 256 (to produce a 366 Hz clock)
User Module Parameters
    Timer8_1   Clock =VC3              Input 366 Hz clock from VC3.
    Capture =Low Not used.
   TerminalCountOut =Row_0_Output_0    For routing to Pin2[3].
   CompareOut =None                    Not used.
   Period =182                         Set to 182 and count down.
    Compare Value =0                    Not used.
   Compare Type  =Less Than            Not used.
   Interrupt Type =Terminal Count      To generate interrupt after the down counter reaches 0.
   Clock Sync =Sync                    To SysClk Synchronize to system clock.
    TC_PulseWidth =Full width           Generate a full pulse width at every terminal count. InvertCapture =Normal Not used.
stly 发表于 2017-12-17 15:53 | 显示全部楼层
没明白你得问题
 楼主| zwll 发表于 2017-12-17 15:54 | 显示全部楼层
那个中断服务程序的框架在硬件配置好后Designer会自动生成吗?
llljh 发表于 2017-12-17 15:57 | 显示全部楼层
框架生成了吗
 楼主| zwll 发表于 2017-12-17 15:59 | 显示全部楼层
dingy 发表于 2017-12-17 16:02 | 显示全部楼层
是不是构建Project的时候出了问题
pengf 发表于 2017-12-17 16:04 | 显示全部楼层
你好歹亮和暗间加个延时啊
renyaq 发表于 2017-12-17 16:07 | 显示全部楼层
是啊,不然它闪太快,在你看来就是一直亮了。。。。
 楼主| zwll 发表于 2017-12-17 16:08 | 显示全部楼层
怎么搞
supernan 发表于 2017-12-17 16:11 | 显示全部楼层
PRT0DR^ =0x02;在这句
 楼主| zwll 发表于 2017-12-17 16:16 | 显示全部楼层
哦,好,我知道了
