[STM32F1] stm32f103串口设置的波特率和实际的不一样
4319|6
 楼主| 肥羊 发表于 2017-12-18 19:00 | 显示全部楼层 |阅读模式
我是用内部的时钟的
下面是时钟函数
  1. void RCC_Configuration(void)
  3.         GPIO_InitTypeDef  GPIO_InitStructure;
  4.     RCC_DeInit();//将外设 RCC寄存器重设为缺省值
  5.
  6.     RCC_HSICmd(ENABLE);//使能HSI
  7.     while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);//等待HSI使能成功
  8.
  9.     RCC_HCLKConfig(RCC_SYSCLK_Div1);
  10.     RCC_PCLK1Config(RCC_HCLK_Div1);
  11.     RCC_PCLK2Config(RCC_HCLK_Div1);
  12.     //RCC_ADCCLKConfig(RCC_PCLK2_Div6);
  13.     //设置 PLL 时钟源及倍频系数
  14.     //经过测试这里最多设置成RCC_PLLMul_13高了就会死机
  15.         /*
  16.         These bits represent the ratio of the SYSCLK (system clock) period to the Flash access
  17.         time.
  18.         000 Zero wait state, if 0 < SYSCLK≤ 24 MHz
  19.         001 One wait state, if 24 MHz < SYSCLK ≤ 48 MHz
  20.         010 Two wait states, if 48 MHz < SYSCLK ≤ 72 MHz
  21.         */
  22.
  23.         /* Enable refetch Buffer */
  24.         //FLASH->ACR |= FLASH_ACR_PRFTBE;
  25.         /* Flash 2 wait state */
  26.         //FLASH->ACR &= (u32)((u32)~FLASH_ACR_LATENCY);
  27.         //FLASH->ACR |= (u32)FLASH_ACR_LATENCY_2;
  28.         FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
  29.     FLASH_SetLatency(FLASH_Latency_2);
  30.
  31.     RCC_PLLConfig(RCC_PLLSource_HSI_Div2, RCC_PLLMul_9);//使能或者失能 PLL,这个参数可以取:ENABLE或者DISABLE
  32.     RCC_PLLCmd(ENABLE);//如果PLL被用于系统时钟,那么它不能被失能
  33.     //等待指定的 RCC 标志位设置成功 等待PLL初始化成功
  34.     while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  35.
  36.     //设置系统时钟(SYSCLK) 设置PLL为系统时钟源
  37.     RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//选择想要的系统时钟
  38.     //等待PLL成功用作于系统时钟的时钟源
  39.     //  0x00:HSI 作为系统时钟
  40.     //  0x04:HSE作为系统时钟
  41.     //  0x08:PLL作为系统时钟
  42.     while(RCC_GetSYSCLKSource() != 0x08);//需与被选择的系统时钟对应起来,RCC_SYSCLKSource_PLL
  43.     /*
  44.           GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  45.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  46.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  47.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  48.         RCC_MCOConfig(RCC_MCO_HSI);
  49.     */
  50. }
下面是串口的初始化
  1. //初始化IO 串口1
  2. //bound:波特率
  3. void uart_init(u32 bound){
  4.     //GPIO端口设置
  5.     GPIO_InitTypeDef GPIO_InitStructure;
  6.         USART_InitTypeDef USART_InitStructure;
  7.         NVIC_InitTypeDef NVIC_InitStructure;
  8.
  9.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO, ENABLE);        //使能USART2,GPIOA时钟
  10.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);
  11.         USART_DeInit(USART2);
  12.          //USART2_TX   PA.2
  13.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //PA.2
  14.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  15.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;        //复用推挽输出
  16.     GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化PA9
  17.
  18.     //USART2_RX          PA.3
  19.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
  20.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
  21.     GPIO_Init(GPIOA, &GPIO_InitStructure);  //初始化PA3
  22.    //Usart2 NVIC 配置
  23.     NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
  24.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3
  25.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;                //子优先级3
  26.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
  27.         NVIC_Init(&NVIC_InitStructure);        //根据指定的参数初始化VIC寄存器
  28.
  29.    //USART 初始化设置
  30.          USART_InitStructure.USART_BaudRate = bound;//一般设置为9600;
  31.          USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
  32.          USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
  33.          USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
  34.          USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
  35.          USART_InitStructure.USART_Mode = USART_Mode_Rx|USART_Mode_Tx ;        //收发模式
  36.          //
  37.     USART_Init(USART2, &USART_InitStructure); //初始化串口
  38.     USART_ITConfig(USART2, USART_IT_TC, ENABLE);//开启中断
  39.     USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);//开启中断
  40.     USART_Cmd(USART2, ENABLE);                    //使能串口
  41. }
mmuuss586 发表于 2017-12-18 21:35 | 显示全部楼层
不一样,差多少呢?
gejigeji521 发表于 2017-12-18 23:00 | 显示全部楼层
想 要多少,实际多少?
tomzbj 发表于 2017-12-19 09:16 | 显示全部楼层
PLL 13倍频死机?
这两行的注释去掉没有, 要是没去掉肯定要死机啊
 楼主| 肥羊 发表于 2017-12-19 09:21 | 显示全部楼层
我用外部时钟就可以
 楼主| 肥羊 发表于 2017-12-19 09:22 | 显示全部楼层
但是用内部时钟就不行了
 楼主| 肥羊 发表于 2017-12-19 10:44 | 显示全部楼层
PLL 13倍频死机?
和你说得刚刚相反,去掉会去掉会死机
