[STM8] 串口3发送问题
611|2
 楼主| Cjy_JDxy 发表于 2018-1-31 12:41 | 显示全部楼层 |阅读模式
我用STM8S207C8T6写程序,开发环境IAR。
串口3往外发数据。
void Uart3_Initial(void)
    UART3_DeInit();
    UART3_Init((u32)115200, UART3_WORDLENGTH_8D, UART3_STOPBITS_1, \
    UART3_PARITY_NO , UART3_MODE_TXRX_ENABLE);
    UART3_ITConfig(UART3_IT_RXNE_OR,ENABLE  );
    UART3_Cmd(ENABLE );
void UART3_SendByte(u8 data)
    UART3_SendData8((unsigned char)data);
  /* Loop until the end of transmission */
  while (UART3_GetFlagStatus(UART3_FLAG_TXE) == RESET);
void main(void)
  //asm("sim");         //先关闭总中断
  u32 i;
  u8 flag;
  CLK_Config();
  GPIO_DeInit(GPIOE);
  GPIO_Init(GPIOE,GPIO_PIN_6 | GPIO_PIN_7,GPIO_MODE_OUT_PP_HIGH_SLOW);
  GPIO_DeInit(GPIOA);
  GPIO_Init(GPIOA,GPIO_PIN_3 | GPIO_PIN_6 ,GPIO_MODE_OUT_PP_HIGH_SLOW);
  GPIO_DeInit(GPIOB);
  GPIO_Init(GPIOB,GPIO_PIN_6 | GPIO_PIN_7,GPIO_MODE_IN_PU_NO_IT);
  GPIO_DeInit(GPIOD);
  GPIO_Init(GPIOD,GPIO_PIN_3 | GPIO_PIN_2,GPIO_MODE_OUT_PP_HIGH_SLOW);
  Tim1_Init();
  //__enable_interrupt();
  //Uart1_Initial();
  Uart3_Initial();
  /* Infinite loop */
  //asm("rim");         //打开总中断
  while (1)
    //Connect_NewData();                                        //?D??ê?·?μ?×?D?êy?Yé?′?ê±???úμ?
    UART3_SendByte(0x55);
    for(i=0;i<300000;i++);
本来发的是0x55,可是串口助手收到的却是1.
高手给看看,怎么回事?谢谢!
mintspring 发表于 2018-1-31 17:02 | 显示全部楼层
这是什么串口助手啊,换个试试,看看是不是波特吧没设置一致。
 楼主| Cjy_JDxy 发表于 2018-1-31 18:23 | 显示全部楼层
不是助手的问题,时钟配置有误!
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
