Automotive High Voltage, High Power Motor Drive Reference Design
862|2
 楼主| dirtwillfly 发表于 2018-2-6 19:43 | 显示全部楼层 |阅读模式
TIDA-01418描述
This brushless DC (BLDC) motor reference design controls an automotive HVAC (heating, ventilation, and air conditioning) compressor by using the UCC27712-Q1 high-side and low-side gate driver followed by discrete insulated-gate bipolar transistor (IGBT) half bridges. This reference design uses TI's InstaSPIN software with a three-phase motor control algorithm, which the designer can enable using special libraries in the read-only memory (ROM) of Piccolo microcontrollers (MCUs) and provides expert tools to designers of sensorless (velocity and torque) motor control applications.
特性
  • Low-voltage side survives voltages up to 45V, withstands reverse battery conditions, and withstands load dDump conditions (12V system)
  • Incorporates protection against overcurrent and false turn-on using an active "Miller Clamp" and overcurrent detection circuit
  • Isolated CAN-communication interface
  • Isolated power supply
  • Non-isolated, low-cost, high- and low-side gate drivers with 2.5A peak output
  • InstaSPIN, sensorless torque control algorithm
用户指南:
 楼主| dirtwillfly 发表于 2018-2-6 19:45 | 显示全部楼层
设计文件:
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1200
