| #include"iostm8s003f3.h"
 #define u8 uint8_t
 #define u16 uint16_t
 #define u32 uint32_t
 typedef unsigned char uint8_t;
 typedef unsigned short uint16_t;
 typedef unsigned long uint32_t;
 void delay(u16 Count);
 void main()
 asm("sim");
 delay(10);
 //Preamble_IF=0;
 // recstep=0;
 // N_preamble=0;
 PB_CR1|=0x20;
 PB_CR2|=0x20;
 PB_DDR_DDR5 = 1;
 PB_ODR_ODR5=0;
 CLK_CKDIVR=0x00;
 TIM1_PSCRH = 0x00;
 TIM1_PSCRL = 0x00;
 TIM1_CCER1 &= 0xee;//禁止输入捕获1,2
 TIM1_ARRH=0xbb;
 TIM1_ARRL=0x80; //3ms
 TIM1_CCMR1 |=  0x01;// ch1到ti1fp1
 TIM1_CCER1 &= 0xFD;//ch1 上升沿触发
 TIM1_CCMR2 |=  0x02;// ch2选择 ti1fp2上
 TIM1_CCER1 |= 0x20;//ch2 下降沿触发 ic2
 TIM1_SMCR |= 0x50;//选源触发源和触发方式 复位
 TIM1_SMCR |=0x04;
 TIM1_IER|= 0x06;
 TIM1_SR1&=0xF9;
 TIM1_SR2&=0xFD;
 TIM1_CCER1|=0x11;
 TIM1_CR1 |= 0x05;
 asm("sim");
 while(1)
 #pragma vector=0x0E
 __interrupt void TIM1_CAP_COM_IRQHandler(void)
 u16 High,Cycle;
 //High=0;
 // Cycle=0;
 PB_ODR_ODR5=1;
 if ((TIM1_SR1_CC1IF==1)&&(TIM1_SR1_CC2IF==1))
 TIM1_SR1_CC1IF=0;
 TIM1_SR1_CC2IF=0;
 TIM1_SR2_CC1OF=0;
 TIM1_SR2_CC2OF=0;
 High=(u16)TIM1_CCR2H<<8;
 High|=TIM1_CCR2L;
 Cycle=(u16)TIM1_CCR1H<<8;
 Cycle|=TIM1_CCR1L;
 if(((High>3824)&&(High<4176))&&((Cycle-High)>3824)&&((Cycle-High)<4176))
 PB_ODR_ODR5=1;
 else
 PB_ODR_ODR5=0;
 u8 i,j;
 while (Count--)
 for(i=0;i<50;i++)
 for(j=0;j<20;j++);
 void assert_failed(u8* file, u32 line)
 /* User can add his own implementation to report the file name and line number,
 ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
 /* Infinite loop */
 while (1)
 试过很多遍,没有查到问题,请帮忙看一下,TIM1_CH1捕获上升沿和下降沿,TIM1_SR2=0x06, CC1OF和CC2OF一直为1
