[DemoCode下载] M051的FMC读写操作
1416|2
 楼主| 幸福小强 发表于 2018-3-6 16:03 | 显示全部楼层 |阅读模式
  1. /******************************************************************************
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
  4. * $Revision: 8 $
  5. * $Date: 14/02/10 2:43p $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    FMC erase/program/read sample program for M051 series MCU
  7. *
  8. * @note
  9. * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
  10. *****************************************************************************/
  11. #include <stdio.h>
  12. #include "M051Series.h"
  13. #define PLLCON_SETTING      CLK_PLLCON_50MHz_HXT
  14. #define PLL_CLOCK           50000000
  15. #define APROM_TEST_BASE             0x3000
  16. #define APROM_TEST_END              0x10000
  17. #define DATA_FLASH_TEST_BASE        (FMC->DFBADR)
  18. #define DATA_FLASH_TEST_END         (FMC->DFBADR + 0x1000)
  19. #define TEST_PATTERN                0x5A5A5A5A
  20. void SYS_Init(void)
  21. {
  22.     /*---------------------------------------------------------------------------------------------------------*/
  23.     /* Init System Clock        */
  24.     /*---------------------------------------------------------------------------------------------------------*/
  25.     /* Enable External XTAL (4~24 MHz) */
  26.     CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk;
  27.     CLK->PLLCON = PLLCON_SETTING;
  28.     /* Waiting for clock ready */
  29.     CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk);
  30.     /* Switch HCLK clock source to PLL */
  31.     CLK->CLKSEL0 = CLK_CLKSEL0_HCLK_S_PLL;
  32.     /* Enable IP clock */
  33.     CLK->APBCLK = CLK_APBCLK_UART0_EN_Msk;
  34.     /* Select IP clock source */
  35.     CLK->CLKSEL1 = CLK_CLKSEL1_UART_S_HXT;
  36.     /* Update System Core Clock */
  37.     /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
  38.     //SystemCoreClockUpdate();
  39.     PllClock        = PLL_CLOCK;            // PLL
  40.     SystemCoreClock = PLL_CLOCK / 1;        // HCLK
  41.     CyclesPerUs     = PLL_CLOCK / 1000000;  // For SYS_SysTickDelay()
  42.     /*---------------------------------------------------------------------------------------------------------*/
  43.     /* Init I/O Multi-function        */
  44.     /*---------------------------------------------------------------------------------------------------------*/
  45.     /* Set P3 multi-function pins for UART0 RXD and TXD  */
  46.     SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
  47. }
  48. void UART_Init()
  49. {
  50.     /*---------------------------------------------------------------------------------------------------------*/
  51.     /* Init UART        */
  52.     /*---------------------------------------------------------------------------------------------------------*/
  53.     UART_Open(UART0, 115200);
  54. }
  55. static int  SetDataFlashBase(uint32_t u32DFBA)
  56. {
  57.     uint32_t au32Config[1];
  58.     /* Read current User Configuration */
  59.     FMC_ReadConfig(au32Config, 1);
  60.     /* Just return when Data Flash has been enabled */
  61.     if(!(au32Config[0] & 0x1))
  62.         return 0;
  63.     /* Enable User Configuration Update */
  64.     FMC_EnableConfigUpdate();
  65.     /* Erase User Configuration */
  66.     FMC_Erase(FMC_CONFIG_BASE);
  67.     /* Write User Configuration to Enable Data Flash */
  68.     au32Config[0] &= ~0x1;
  69.     if(FMC_WriteConfig(au32Config, 1))
  70.         return -1;
  71.     printf("\nSet Data Flash base as 0x%x.\n", FMC_ReadDataFlashBaseAddr());
  72.     /* Perform chip reset to make new User Config take effect */
  73.     SYS->IPRSTC1 |= SYS_IPRSTC1_CHIP_RST_Msk;
  74.     return 0;
  75. }
  76. int32_t FillDataPattern(uint32_t u32StartAddr, uint32_t u32EndAddr, uint32_t u32Pattern)
  77. {
  78.     uint32_t u32Addr;
  79.     for(u32Addr = u32StartAddr; u32Addr < u32EndAddr; u32Addr += 4)
  80.     {
  81.         FMC_Write(u32Addr, u32Pattern);
  82.     }
  83.     return 0;
  84. }
  85. int32_t  VerifyData(uint32_t u32StartAddr, uint32_t u32EndAddr, uint32_t u32Pattern)
  86. {
  87.     uint32_t    u32Addr;
  88.     uint32_t    u32Data;
  89.     for(u32Addr = u32StartAddr; u32Addr < u32EndAddr; u32Addr += 4)
  90.     {
  91.         u32Data = FMC_Read(u32Addr);
  92.         if(u32Data != u32Pattern)
  93.         {
  94.             printf("\nFMC_Read data verify failed at address 0x%x, read=0x%x, expect=0x%x\n", u32Addr, u32Data, u32Pattern);
  95.             return -1;
  96.         }
  97.     }
  98.     return 0;
  99. }
  100. int32_t  FlashTest(uint32_t u32StartAddr, uint32_t u32EndAddr, uint32_t u32Pattern)
  101. {
  102.     uint32_t    u32Addr;
  103.     for(u32Addr = u32StartAddr; u32Addr < u32EndAddr; u32Addr += FMC_FLASH_PAGE_SIZE)
  104.     {
  105.         printf("    Flash test address: 0x%x    \r", u32Addr);
  106.         // Erase page
  107.         FMC_Erase(u32Addr);
  108.         // Verify if page contents are all 0xFFFFFFFF
  109.         if(VerifyData(u32Addr, u32Addr + FMC_FLASH_PAGE_SIZE, 0xFFFFFFFF) < 0)
  110.         {
  111.             printf("\nPage 0x%x erase verify failed!\n", u32Addr);
  112.             return -1;
  113.         }
  114.         // Write test pattern to fill the whole page
  115.         if(FillDataPattern(u32Addr, u32Addr + FMC_FLASH_PAGE_SIZE, u32Pattern) < 0)
  116.         {
  117.             printf("Failed to write page 0x%x!\n", u32Addr);
  118.             return -1;
  119.         }
  120.         // Verify if page contents are all equal to test pattern
  121.         if(VerifyData(u32Addr, u32Addr + FMC_FLASH_PAGE_SIZE, u32Pattern) < 0)
  122.         {
  123.             printf("\nData verify failed!\n ");
  124.             return -1;
  125.         }
  126.         FMC_Erase(u32Addr);
  127.         // Verify if page contents are all 0xFFFFFFFF
  128.         if(VerifyData(u32Addr, u32Addr + FMC_FLASH_PAGE_SIZE, 0xFFFFFFFF) < 0)
  129.         {
  130.             printf("\nPage 0x%x erase verify failed!\n", u32Addr);
  131.             return -1;
  132.         }
  133.     }
  134.     printf("\r    Flash Test Passed.          \n");
  135.     return 0;
  136. }
  137. int main()
  138. {
  139.     uint32_t i, u32Data;
  140.     /* Unlock protected registers */
  141.     SYS_UnlockReg();
  142.     SYS_Init();
  143.     UART_Init();
  144.     /*
  145.         This sample code is used to show how to use StdDriver API to implement ISP functions.
  146.     */
  147.     printf("\n\n");
  148.     printf("+----------------------------------------+\n");
  149.     printf("|          M051 FMC Sample Code          |\n");
  150.     printf("+----------------------------------------+\n");
  151.     SYS_UnlockReg();
  152.     /* Enable FMC ISP function */
  153.     FMC_Open();
  154.     if(SetDataFlashBase(DATA_FLASH_TEST_BASE) < 0)
  155.     {
  156.         printf("Failed to set Data Flash base address!\n");
  157.         goto lexit;
  158.     }
  159.     /* Read BS */
  160.     printf("  Boot Mode ............................. ");
  161.     if(FMC_GetBootSource() == 0)
  162.         printf("[APROM]\n");
  163.     else
  164.     {
  165.         printf("[LDROM]\n");
  166.         printf("  WARNING: The driver sample code must execute in AP mode!\n");
  167.         goto lexit;
  168.     }
  169.     u32Data = FMC_ReadCID();
  170.     printf("  Company ID ............................ [0x%08x]\n", u32Data);
  171.     u32Data = FMC_ReadDID();
  172.     printf("  Device ID ............................. [0x%08x]\n", u32Data);
  173.     u32Data = FMC_ReadPID();
  174.     printf("  Product ID ............................ [0x%08x]\n", u32Data);
  175.     for(i = 0; i < 3; i++)
  176.     {
  177.         u32Data = FMC_ReadUID(i);
  178.         printf("  Unique ID %d ........................... [0x%08x]\n", i, u32Data);
  179.     }
  180.     for(i = 0; i < 4; i++)
  181.     {
  182.         u32Data = FMC_ReadUCID(i);
  183.         printf("  Unique Customer ID %d .................. [0x%08x]\n", i, u32Data);
  184.     }
  185.     /* Read User Configuration */
  186.     printf("  User Config 0 ......................... [0x%08x]\n", FMC_Read(FMC_CONFIG_BASE));
  187.     printf("  User Config 1 ......................... [0x%08x]\n", FMC_Read(FMC_CONFIG_BASE + 4));
  188.     /* Read Data Flash base address */
  189.     u32Data = FMC_ReadDataFlashBaseAddr();
  190.     printf("  Data Flash Base Address ............... [0x%08x]\n", u32Data);
  191.     printf("\n\nLDROM test =>\n");
  192.     FMC_EnableLDUpdate();
  193.     if(FlashTest(FMC_LDROM_BASE, FMC_LDROM_BASE + FMC_LDROM_SIZE, TEST_PATTERN) < 0)
  194.     {
  195.         printf("\n\nLDROM test failed!\n");
  196.         goto lexit;
  197.     }
  198.     FMC_DisableLDUpdate();
  199.     printf("\n\nAPROM test =>\n");
  200.     FMC_EnableAPUpdate();
  201.     if(FlashTest(APROM_TEST_BASE, APROM_TEST_END, TEST_PATTERN) < 0)
  202.     {
  203.         printf("\n\nAPROM test failed!\n");
  204.         goto lexit;
  205.     }
  206.     FMC_DisableAPUpdate();
  207.     printf("\n\nData Flash test =>\n");
  208.     if(FlashTest(DATA_FLASH_TEST_BASE, DATA_FLASH_TEST_END, TEST_PATTERN) < 0)
  209.     {
  210.         printf("\n\nData Flash test failed!\n");
  211.         goto lexit;
  212.     }
  213. lexit:
  214.     /* Disable FMC ISP function */
  215.     FMC_Close();
  216.     /* Lock protected registers */
  217.     SYS_LockReg();
  218.     printf("\nFMC Sample Code Completed.\n");
  219.     while(1);
  220. }
  221. /*** (C) COPYRIGHT 2014 Nuvoton Technology Corp. ***/
这个功能用的还是很多的
huangcunxiake 发表于 2018-3-6 17:15 | 显示全部楼层
只会照着抄了。
