[STM32L4] stm32l476液晶驱动的问题
2871|15
 楼主| tuezhibang 发表于 2018-3-15 19:51 | 显示全部楼层 |阅读模式
HAL_LCD_Write(LCD_HandleTypeDef *hlcd, uint32_t RAMRegisterIndex, uint32_t RAMRegisterMask, uint32_t Data)
在库函数中找到上述程序,请问RAMRegisterMask是指我红色标注, Data是指我绿色标注的吗?
 楼主| tuezhibang 发表于 2018-3-15 20:25 | 显示全部楼层
HAL_StatusTypeDef HAL_LCD_Write(LCD_HandleTypeDef *hlcd, uint32_t RAMRegisterIndex, uint32_t RAMRegisterMask, uint32_t Data)
  uint32_t tickstart = 0x00;
  if((hlcd->State == HAL_LCD_STATE_READY) || (hlcd->State == HAL_LCD_STATE_BUSY))
    /* Check the parameters */
    assert_param(IS_LCD_RAM_REGISTER(RAMRegisterIndex));
    if(hlcd->State == HAL_LCD_STATE_READY)
      /* Process Locked */
      __HAL_LOCK(hlcd);
      hlcd->State = HAL_LCD_STATE_BUSY;
      /* Get timeout */
      tickstart = HAL_GetTick();
      /*!< Wait Until the LCD is ready */
      while(__HAL_LCD_GET_FLAG(hlcd, LCD_FLAG_UDR) != RESET)
        if((HAL_GetTick() - tickstart ) > LCD_TIMEOUT_VALUE)
          hlcd->ErrorCode = HAL_LCD_ERROR_UDR;
          /* Process Unlocked */
          __HAL_UNLOCK(hlcd);
          return HAL_TIMEOUT;
    /* Copy the new Data bytes to LCD RAM register */
    MODIFY_REG(hlcd->Instance->RAM[RAMRegisterIndex], ~(RAMRegisterMask), Data);
    return HAL_OK;
  else
    return HAL_ERROR;
幸福小强 发表于 2018-3-15 21:16 | 显示全部楼层
看原函数的注释,以及这个表的头。
 楼主| tuezhibang 发表于 2018-3-15 21:36 | 显示全部楼层
看原函数的注释,以及这个表的头。
  * @brief  Write a word in the specific LCD RAM.
  * @param  hlcd: LCD handle
  * @param  RAMRegisterIndex: specifies the LCD RAM Register.
  *   This parameter can be one of the following values:
  *     @arg LCD_RAM_REGISTER0: LCD RAM Register 0
  *     @arg LCD_RAM_REGISTER1: LCD RAM Register 1
  *     @arg LCD_RAM_REGISTER2: LCD RAM Register 2
  *     @arg LCD_RAM_REGISTER3: LCD RAM Register 3
  *     @arg LCD_RAM_REGISTER4: LCD RAM Register 4
  *     @arg LCD_RAM_REGISTER5: LCD RAM Register 5
  *     @arg LCD_RAM_REGISTER6: LCD RAM Register 6
  *     @arg LCD_RAM_REGISTER7: LCD RAM Register 7
  *     @arg LCD_RAM_REGISTER8: LCD RAM Register 8
  *     @arg LCD_RAM_REGISTER9: LCD RAM Register 9
  *     @arg LCD_RAM_REGISTER10: LCD RAM Register 10
  *     @arg LCD_RAM_REGISTER11: LCD RAM Register 11
  *     @arg LCD_RAM_REGISTER12: LCD RAM Register 12
  *     @arg LCD_RAM_REGISTER13: LCD RAM Register 13
  *     @arg LCD_RAM_REGISTER14: LCD RAM Register 14
  *     @arg LCD_RAM_REGISTER15: LCD RAM Register 15
  * @param  RAMRegisterMask: specifies the LCD RAM Register Data Mask.
  * @param  Data: specifies LCD Data Value to be written.
  * @retval None
 楼主| tuezhibang 发表于 2018-3-15 21:39 | 显示全部楼层
他的注释感觉不是很具体
幸福小强 发表于 2018-3-15 22:16 | 显示全部楼层
确实,STM32,比较难学。
捉虫天师 发表于 2018-3-15 22:57 | 显示全部楼层
不知道能否找到个例子,看看例子里那个调用的时候是用的什么参数。
 楼主| tuezhibang 发表于 2018-3-15 23:00 | 显示全部楼层
嗯,感谢回复,只是我在官网该芯片的各类文档中并未找到例程
sanxingnote7 发表于 2018-3-16 11:46 | 显示全部楼层
这个是跟硬件关联的吧
backlugin 发表于 2018-3-16 11:47 | 显示全部楼层
他的注释感觉不是很具体
你驱动什么液晶?
sanxingnote7 发表于 2018-3-16 11:49 | 显示全部楼层
软件设计的接口驱动芯片一样吗?
backlugin 发表于 2018-3-16 11:49 | 显示全部楼层
他的注释感觉不是很具体
还不如自己编写程序呢。
 楼主| tuezhibang 发表于 2018-3-19 09:58 | 显示全部楼层
你驱动什么液晶?
段码屏
软件设计的接口驱动芯片一样吗?
是使用stm32内置的lcd驱动器
软件设计的接口驱动芯片一样吗?
是使用stm32内置的lcd驱动器
 楼主| tuezhibang 发表于 2018-3-19 09:59 | 显示全部楼层
还不如自己编写程序呢。
哈哈哈,是这个理。
