[ARM入门] 串口接收中断
2195|3
 楼主| 小白咚 发表于 2018-4-24 21:55 | 显示全部楼层 |阅读模式
一个串口接收中断程序,运行后还没发送数据就一直不停的进入中断,主程序和中断服务程序如下..
// UART1 Interrupt Service Routine
void
am_uart1_isr(void)
    uint32_t status;
    uint32_t rxSize, txSize;
    status = am_hal_uart_int_status_get(1, false);
    am_hal_uart_int_clear(1, status);
    if (status & (AM_HAL_UART_INT_RX_TMOUT | AM_HAL_UART_INT_TX | AM_HAL_UART_INT_RX))
        am_hal_uart_service_buffered_timeout_save(1, status);
    if (status & (AM_HAL_UART_INT_RX_TMOUT))
        g_ui8RxTimeoutFlag = 1;
        am_util_stdio_printf("\nTMOUT, ");
    am_hal_uart_get_status_buffered(1, &rxSize, &txSize);
    if (status & (AM_HAL_UART_INT_RX))
        am_util_stdio_printf(", RX ");
    if (status & (AM_HAL_UART_INT_TXCMP))
        am_util_stdio_printf(", TXCMP");
    if (rxSize >= UART_BUFFER_SIZE / 2)
        g_ui8BufferFullFlag = 1;
        am_util_stdio_printf(", RXF");
// Main function.
int
main(void)
    uint32_t ui32Module = AM_BSP_UART_PRINT_INST;
    char pcTempBuf[UART_BUFFER_SIZE + 1];
    uint32_t ui32Length;
    // Set the clock frequency.
    am_hal_clkgen_sysclk_select(AM_HAL_CLKGEN_SYSCLK_MAX);
    // Set the default cache configuration
    am_hal_cachectrl_enable(&am_hal_cachectrl_defaults);
    // Configure the board for low power operation.
    am_bsp_low_power_init();
//    // Initialize the printf interface for UART output.
    am_util_stdio_printf_init((am_util_stdio_print_char_t) am_bsp_itm_string_print);
    am_bsp_pin_enable(ITM_SWO);
    am_bsp_debug_printf_enable();
    am_hal_itm_enable();
    am_util_stdio_printf_init((am_util_stdio_print_char_t)am_bsp_uart_string_print);
    // Initialize and Enable the UART.
    uart_init(ui32Module);
    uart_enable(ui32Module);
    am_hal_interrupt_master_enable();
    // Print the banner.
    am_util_stdio_printf("UART FIFO Example\n");
    am_util_stdio_printf("Note - the UART terminal operates at 115,200 BAUD, 8 bit, no parity.\n");
    uart_transmit_delay(ui32Module);
    am_util_stdio_printf("\n\tEcho back the UART received data.\n");
    am_util_stdio_printf("\t");
    // Loop forever writing chars to the stimulus register.
    while (1)
        // Need to retrieve and echo received date for loopback
        // if either all the data has been received, or if we are in danger
        // of overflowing the receive buffer
        if (g_ui8RxTimeoutFlag || g_ui8BufferFullFlag)
            g_ui8RxTimeoutFlag = 0;
            g_ui8BufferFullFlag = 0;
            memset(pcTempBuf, 0x00, sizeof(pcTempBuf));
            ui32Length = am_hal_uart_char_receive_buffered(ui32Module, pcTempBuf, UART_BUFFER_SIZE);
            if (ui32Length)
                if ( pcTempBuf[0] == '\n' )
                    am_util_stdio_printf("START_TX (char='\\n')");
                else
                    am_util_stdio_printf("START_TX (char='%c')", pcTempBuf[0]);
                // We have overallocated the pcTempBuf, to make sure ui32Length==UART_BUFFER_SIZE is ok
                pcTempBuf[ui32Length] = 0;
                am_hal_uart_string_transmit_buffered(ui32Module, pcTempBuf);
ayb_ice 发表于 2018-4-25 08:45 | 显示全部楼层
应该是有标志没有清除
669686lf 发表于 2018-5-18 11:25 | 显示全部楼层
我的通讯也不正常
kingkits 发表于 2018-5-21 13:05 | 显示全部楼层
懂得串口通讯的都知道:
串口中断里不应有printf函数(除非有极特殊的处理方法)
另外,如果打开TXE中断,在没有数据传送时,应该及时关闭TXE
