- \#include "stm32f10x.h"
- \#include "stm32f10x_usart.h"
- \#include "misc.h"
- unsigned char dat[18];
- //FINGERPRINT通信协议定义
- unsigned char FP_Pack_Head[6] = {0xEF,0x01,0xFF,0xFF,0xFF,0xFF}; //协议包头
- unsigned char FP_Get_Img[6] = {0x01,0x00,0x03,0x01,0x0,0x05}; //获得指纹图像
- unsigned char FP_Templete_Num[6] ={0x01,0x00,0x03,0x1D,0x00,0x21 }; //获得模版总数
- unsigned char FP_Search[11]={0x01,0x0,0x08,0x04,0x01,0x0,0x0,0x03,0xA1,0x0,0xB2}; //搜索指纹搜索范围0 - 929
- unsigned char FP_Search_0_9[11]={0x01,0x0,0x08,0x04,0x01,0x0,0x0,0x0,0x13,0x0,0x21};//搜索0-9号指纹
- unsigned char FP_Img_To_Buffer1[7]={0x01,0x0,0x04,0x02,0x01,0x0,0x08}; //将图像放入到BUFFER1
- unsigned char FP_Img_To_Buffer2[7]={0x01,0x0,0x04,0x02,0x02,0x0,0x09}; //将图像放入到BUFFER2
- unsigned char FP_Reg_Model[6]={0x01,0x0,0x03,0x05,0x0,0x09}; //将BUFFER1跟BUFFER2合成特征模版
- unsigned char FP_Delet_All_Model[6]={0x01,0x0,0x03,0x0d,0x00,0x11}; //删除指纹模块里所有的模版
- unsigned char FP_Save_Finger[9]={0x01,0x00,0x06,0x06,0x01,0x00,0x0B,0x00,0x19}; //将BUFFER1中的特征码存放到指定的位置
- unsigned char FP_Delete_Model[10]={0x01,0x00,0x07,0x0C,0x0,0x0,0x0,0x1,0x0,0x0}; //删除指定的模版
- //从 USART1 发送一个字节
- void USART1_SendByte(unsigned char temp)
- USART_SendData(USART1, temp);
- while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
- //从 USART1 读取一个字节
- unsigned char USART1_ReceivByte()
- unsigned char recev;
- while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET);
- recev = USART_ReceiveData(USART1);
- return recev;
- //FINGERPRINT命令字
- //FINGERPRINT_获得指纹图像命令
- void FINGERPRINT_Cmd_Get_Img(void)
- unsigned char i;
- for(i=0;i<6;i++) //发送包头
- USART1_SendByte(FP_Pack_Head[i]);
- for(i=0;i<6;i++) //发送命令 0x1d
- USART1_SendByte(FP_Get_Img[i]);
- for(i=0;i<12;i++)//读回应答信息
- dat[i]=USART1_ReceivByte();
- //删除所有指纹模版
- void FINGERPRINT_Cmd_Delete_All_Model(void)
- unsigned char i;
- USART1_SendByte(FP_Delet_All_Model[i]);
- //讲图像转换成特征码存放在Buffer1中
- void FINGERPRINT_Cmd_Img_To_Buffer1(void)
- unsigned char i;
- for(i=0;i<7;i++) //发送命令 将图像转换成 特征码 存放在 CHAR_buffer1
- USART1_SendByte(FP_Img_To_Buffer1[i]);
- for(i=0;i<12;i++)//读应答信息
- dat[i]=USART1_ReceivByte();//把应答数据存放到缓冲区
- //将图像转换成特征码存放在Buffer2中
- void FINGERPRINT_Cmd_Img_To_Buffer2(void)
- unsigned char i;
- USART1_SendByte(FP_Img_To_Buffer2[i]);
- for(i=0;i<12;i++)
- dat[i]=USART1_ReceivByte();//读回应答信息
- //将BUFFER1 跟 BUFFER2 中的特征码合并成指纹模版
- void FINGERPRINT_Cmd_Reg_Model(void)
- unsigned char i;
- for(i=0;i<6;i++) //包头
- for(i=0;i<6;i++) //命令合并指纹模版
- USART1_SendByte(FP_Reg_Model[i]);
- for(i=0;i<12;i++)
- //存储模版到特定地址
- void FINGERPRINT_Cmd_Save_Finger( unsigned char ucH_Char, unsigned char ucL_Char)
- unsigned long temp = 0;
- unsigned char i;
- FP_Save_Finger[5] = ucH_Char;
- FP_Save_Finger[6] = ucL_Char;
- for(i=0;i<7;i++) //计算校验和
- temp = temp + FP_Save_Finger[i];
- FP_Save_Finger[7]=(temp & 0x00FF00) >> 8; //存放校验数据
- FP_Save_Finger[8]= temp & 0x0000FF;
- for(i=0;i<6;i++)
- USART1_SendByte(FP_Pack_Head[i]); //发送包头
- for(i=0;i<9;i++)
- USART1_SendByte(FP_Save_Finger[i]); //发送命令 将图像转换成 特征码 存放在 CHAR_buffer1
- for(i=0;i<12;i++)
- //获得指纹模板数量
- void FINGERPRINT_Cmd_Get_Templete_Num(void)
- unsigned int i;
- //发送命令 0x1d
- for(i=0;i<6;i++)
- USART1_SendByte(FP_Templete_Num[i]);
- for(i=0;i<12;i++)
- //搜索全部用户999枚
- void FINGERPRINT_Cmd_Search_Finger(void)
- unsigned char i;
- //发送命令搜索指纹库
- for(i=0;i<6;i++)
- for(i=0;i<11;i++)
- USART1_SendByte(FP_Search[i]);
- for(i=0;i<16;i++)
- //搜索用户0~9枚
- void FINGERPRINT_Cmd_Search_Finger_Admin(void)
- unsigned char i;
- for(i=0;i<6;i++) //发送命令搜索指纹库
- for(i=0;i<11;i++)
- USART1_SendByte(FP_Search_0_9[i]);
- for(i=0;i<12;i++)
- //添加一个新的指纹
- unsigned char FP_add_new_user(unsigned char ucH_user,unsigned char ucL_user)
- do
- FINGERPRINT_Cmd_Get_Img(); //获得指纹图像
- } while ( dat[9]!=0x0 ); //检测是否成功的按了指纹
- FINGERPRINT_Cmd_Img_To_Buffer1(); //将图像转换成特征码存放在Buffer1中
- do
- } while( dat[9]!=0x0 );
- FINGERPRINT_Cmd_Img_To_Buffer2(); //将图像转换成特征码存放在Buffer2中
- FINGERPRINT_Cmd_Reg_Model(); //转换成特征码
- FINGERPRINT_Cmd_Save_Finger(ucH_user,ucL_user);
- return 0;
第2个 FPM10A.h
- \#ifndef _FPM10A_H
- \#define _FPM10A_H
- \#include <stdint.h>
- extern unsigned char dat[18];
- extern void FINGERPRINT_Cmd_Get_Img();
- extern void FINGERPRINT_Cmd_Img_To_Buffer1();
- extern void FINGERPRINT_Cmd_Img_To_Buffer2();
- extern void FINGERPRINT_Cmd_Reg_Model();
- extern void FINGERPRINT_Cmd_Delete_All_Model(void);
- extern void FINGERPRINT_Cmd_Search_Finger(void);
- extern void FINGERPRINT_Cmd_Get_Templete_Num(void);
- extern void FINGERPRINT_Cmd_Search_Finger_Admin(void);
- extern void FINGERPRINT_Cmd_Save_Finger( unsigned char ucH_Char, unsigned char ucL_Char);
- extern unsigned char FP_add_new_user(unsigned char ucH_user,unsigned char ucL_user);
- extern void USART1_SendByte(unsigned char temp);
- extern unsigned char USART1_ReceivByte();
- extern void Delay_ms1(uint32_t nCount);
- void Delay_nus1(uint32_t nCount)
- uint32_t j;
- while(nCount--)
- j=8;
- while(j--);
- void Delay_ms1(uint32_t nCount)
- while(nCount--)
- Delay_nus1(1100);
- unsigned char test_fig()//检测指纹模块录入指纹情况,返回00表示录入成功;02无手指;03录入失败
- unsigned char fig_dat;
- Delay_ms1(20);
- fig_dat=dat[9];
- return(fig_dat);
- \#endif
有了这两个东西,加入到你的工程中,就可以直接调用啦!
