用28335的ADC模块对模拟的正弦波形进行采样,发现波形会出现跳变的情况。请问这是什么原因造成的?-  EALLOW;
 -    #if (CPU_FRQ_150MHZ)
 -      #define ADC_MODCLK 0x3
 -    #endif
 -    #if (CPU_FRQ_100MHZ)
 -      #define ADC_MODCLK 0x2
 -    #endif
 -    EDIS;
-    EALLOW;
 -    SysCtrlRegs.HISPCP.all = ADC_MODCLK;        // HSPCLK = SYSCLKOUT/ADC_MODCLK
 -    EDIS;
-    AdcRegs.ADCTRL1.bit.ACQ_PS=0xf;
 -    AdcRegs.ADCTRL3.bit.ADCCLKPS = 0x1;//设置采用2分频
 -    AdcRegs.ADCTRL1.bit.SEQ_CASC=1;
 -    AdcRegs.ADCMAXCONV.bit.MAX_CONV1=2;
 -    AdcRegs.ADCTRL2.bit.EPWM_SOCA_SEQ1=1;
-    AdcRegs.ADCCHSELSEQ1.bit.CONV00=0x0;
 -    AdcRegs.ADCCHSELSEQ1.bit.CONV01=0x1;
 -    AdcRegs.ADCCHSELSEQ1.bit.CONV02=0x2;
-    AdcRegs.ADCTRL1.bit.CONT_RUN=1;
 -    AdcRegs.ADCTRL1.bit.SEQ_OVRD=0;
 -    AdcRegs.ADCTRL2.bit.INT_ENA_SEQ1=1;
 -  //  AdcRegs.ADCTRL2.bit.SOC_SEQ1=1;
-     //设置ePWM1_SOCA为ADC模块的启动信号
 -    EPwm1Regs.ETSEL.bit.SOCAEN = 1;                // 使能A组的启动信号SOCA
 -    EPwm1Regs.ETSEL.bit.SOCASEL = ET_CTR_ZERO;     // 选择SOCA信号产生的时刻为CTR = 0
 -    EPwm1Regs.ETPS.bit.SOCAPRD = ET_1ST;          // 每次触发事件产生一个启动信号
 -    EPwm1Regs.ETCLR.bit.SOCA = 1;
- while(AdcRegs.ADCST.bit.INT_SEQ1==0){};
 -  //AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1;  //清除中断标志位
 - // while (AdcRegs.ADCST.bit.SEQ1_BSY == 1);
-  p->v_spe = 3 * (AdcRegs.ADCRESULT0>>4) /4095.0;
 -  p->v_Ia =  3 * (AdcRegs.ADCRESULT1>>4) /4095.0;
 -  p->v_Ib =  3 * (AdcRegs.ADCRESULT2>>4) /4095.0;
-  p->Speed_tar = p->v_spe /3.0;   //目标转速标幺值
 -  p->Ia = (p->v_Ia - 1.65) * 10;
 -  p->Ib = (p->v_Ib - 1.65) * 10;
-  //AdcRegs.ADCTRL2.bit.RST_SEQ1 = 1;   //复位SEQ1转换序列
 -  AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1;
