复杂pwm波的生成方法
923|8
 楼主| 拉克丝 发表于 2018-6-27 19:56 | 显示全部楼层 |阅读模式
请问28335怎么生成一个复杂的pwm波?
它的高低电平情况是:
1111000 1111000 1111000 1111000 1111000 1111000 1111000 0001111 0001111 0001111 0001111 0001111 0001111 0001111
lefeng 发表于 2018-6-27 20:35 | 显示全部楼层
加个变频的代码
CaLipton 发表于 2018-6-27 21:34 | 显示全部楼层
ePWM模块,看你需要哪种调制方式,都能输出啊
Rospiers 发表于 2018-6-27 21:47 | 显示全部楼层
变换这么多次  也能用pwm模块吗
Lewisnx 发表于 2018-6-27 21:59 | 显示全部楼层
不是只有zro prd cmpa  cmpb可以用来动作吗?
CCompton 发表于 2018-6-27 22:27 | 显示全部楼层
是在pwm模块定时中断里面加吗?
Richardd 发表于 2018-6-27 22:39 | 显示全部楼层
interrupt void epwm3_timer_isr(void)
        EPwm3TimerIntCount++;
    switch(EPwm3Regs.CMPA.half.CMPA)
        case 1435:
                     EPwm3Regs.CMPA.half.CMPA=3348;
        break;
        case 3348:
                EPwm3Regs.CMPA.half.CMPA=4783;
        break;
        case 4783:
                EPwm3Regs.CMPA.half.CMPA=6696;
        break;
        case 6696:
                EPwm3Regs.CMPA.half.CMPA=8131;
        break;
        case 8131:
                EPwm3Regs.CMPA.half.CMPA=10044;
        break;
        case 10044:
                    EPwm3Regs.CMPA.half.CMPA=11479;
        break;
        case 11479:
                EPwm3Regs.CMPA.half.CMPA=13392;
        break;
        case 13392:
                    EPwm3Regs.CMPA.half.CMPA=14827;
        break;
        case 14827:
                EPwm3Regs.CMPA.half.CMPA=16740;
        break;
        case 16740:
                EPwm3Regs.CMPA.half.CMPA=18175;
        break;
        case 18175:
                EPwm3Regs.CMPA.half.CMPA=20088;
        break;
        case 20088:
                EPwm3Regs.CMPA.half.CMPA=21522;
        break;
        case 21522:
                    EPwm3Regs.CMPA.half.CMPA=25349;
        break;
        case 25349:
                EPwm3Regs.CMPA.half.CMPA=26783;
        break;
        case 26783:
                    EPwm3Regs.CMPA.half.CMPA=28697;
        break;
        case 28697:
                EPwm3Regs.CMPA.half.CMPA=30131;
        break;
        case 30131:
                EPwm3Regs.CMPA.half.CMPA=32045;
        break;
        case 32045:
                EPwm3Regs.CMPA.half.CMPA=33479;
        break;
        case 33479:
                EPwm3Regs.CMPA.half.CMPA=35392;
        break;
        case 35392:
                    EPwm3Regs.CMPA.half.CMPA=36827;
        break;
        case 36827:
                EPwm3Regs.CMPA.half.CMPA=38740;
        break;
        case 38740:
                EPwm3Regs.CMPA.half.CMPA=40175;
        break;
        case 40175:
                EPwm3Regs.CMPA.half.CMPA=42088;
        break;
        case 42088:
                EPwm3Regs.CMPA.half.CMPA=43523;
        break;
    case 43523:
            EPwm3Regs.CMPA.half.CMPA=45436;
        break;
        case 45436:
                EPwm3Regs.CMPA.half.CMPA=1435;
        break;
            default:
            break;
    EPwm3Regs.ETCLR.bit.INT = 1;
    PieCtrlRegs.PIEACK.all = PIEACK_GROUP3;
Mattheww 发表于 2018-6-27 22:56 | 显示全部楼层
EPwm3Regs.AQCTLA.bit.ZRO=AQ_SET;
    EPwm3Regs.AQCTLA.bit.CAU=AQ_TOGGLE;
    EPwm3Regs.ETSEL.bit.INTSEL = ET_CTRU_CMPA;
    EPwm3Regs.ETSEL.bit.INTEN = PWM3_INT_ENABLE;
    EPwm3Regs.ETPS.bit.INTPRD = ET_1ST;
这是我pwmsetup里的  是增计数模式
zhangmangui 发表于 2018-6-27 23:20 | 显示全部楼层
给一个合适的比较表吧
