示例代码,实现了在进入关机模式之前测试系统状态的功能。如果系统在断电模式下比预期消耗更多的电量,则可以使用此功能检查是否存在可能导致电源泄漏的系统设置。
- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V1.00
- * $Revision: 4 $
- * $Date: 15/12/29 2:56p $
- * [url=home.php?mod=space&uid=247401]@brief[/url] Sample code which implements a function to test system state before
- * entering power-down mode. If a system consumes more power than
- * expected in power-down mode, this function can be used to check if
- * there is any system setting that may cause power leakage.
- * @note
- * Copyright (C) 2015 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include <stdlib.h>
- #include <string.h>
- #include <stdint.h>
- #include "Nano103.h"
- #include "sys.h"
- #ifdef __DEBUG_MSG
- #define DEBUG_MSG printf
- #else
- #define DEBUG_MSG(...)
- #endif
- /* External functions */
- /* Global variables */
- __IO int32_t _Wakeup_Flag = 0; /* 1 indicates system wake up from power down mode */
- __IO uint32_t _Pin_Setting[11]; /* store Px_H_MFP and Px_L_MFP */
- __IO uint32_t _PullUp_Setting[6]; /* store GPIOx_PUEN */
- * @brief Store original setting of multi-function pin selection.
- * @param None.
- * [url=home.php?mod=space&uid=266161]@return[/url] None.
- void SavePinSetting()
- /* Save Pin selection setting */
- _Pin_Setting[0] = SYS->GPA_MFPL;
- _Pin_Setting[1] = SYS->GPA_MFPH;
- _Pin_Setting[2] = SYS->GPB_MFPL;
- _Pin_Setting[3] = SYS->GPB_MFPH;
- _Pin_Setting[4] = SYS->GPC_MFPL;
- _Pin_Setting[5] = SYS->GPC_MFPH;
- _Pin_Setting[6] = SYS->GPD_MFPL;
- _Pin_Setting[7] = SYS->GPD_MFPH;
- _Pin_Setting[8] = SYS->GPE_MFPL;
- _Pin_Setting[9] = SYS->GPF_MFPL;
- /* Save Pull-up setting */
- _PullUp_Setting[0] = PA->PUEN;
- _PullUp_Setting[1] = PB->PUEN;
- _PullUp_Setting[2] = PC->PUEN;
- _PullUp_Setting[3] = PD->PUEN;
- _PullUp_Setting[4] = PE->PUEN;
- _PullUp_Setting[5] = PF->PUEN;
- * @brief Save multi-function pin setting and then go to power down.
- * @param None.
- * @return None.
- void Enter_PowerDown()
- SavePinSetting(); /* Back up original setting */
- /* Set function pin to GPIO mode */
- SYS->GPA_MFPL = 0;
- SYS->GPA_MFPH = 0;
- SYS->GPB_MFPL = (SYS_GPB_MFPL_PB0MFP_UART0_RXD | SYS_GPB_MFPL_PB1MFP_UART0_TXD); // exclude debug port;
- SYS->GPB_MFPH = 0;
- SYS->GPC_MFPL = 0;
- SYS->GPC_MFPH = 0;
- SYS->GPD_MFPL = 0;
- SYS->GPD_MFPH = 0;
- SYS->GPE_MFPL = 0;
- //SYS->GPE_MFPH = 0;
- //SYS->GPF_MFPL = 0x0000FF00; // exclude GPF3:HXT_OUT, GPF2:HXT_IN
- SYS->GPF_MFPL = 0x00FFFF00; // exclude GPF5:ICE_DAT, GPF4:ICE_CLK, GPF3:HXT_OUT, GPF2:HXT_IN
- /* Enable GPIO pull up */
- PA->PUEN = 0xFFFF;
- PB->PUEN = 0xFFFF;
- PC->PUEN = 0xFFFF;
- PD->PUEN = 0xFFFF;
- PE->PUEN = 0xFFFF;
- //PF->PUEN = 0x0033; /* exclude GPF3 and GPF2 which are HXT OUT/IN */
- PF->PUEN = 0x0003; /* exclude GPF5:ICE_DAT, GPF4:ICE_CLK, GPF3:HXT_OUT, GPF2:HXT_IN */
- //CLK->PWRCTL |= CLK_PWRCTL_PDWKIEN_Msk; /* Enable wake up interrupt source */
- //NVIC_EnableIRQ(PDWU_IRQn); /* Enable IRQ request for PDWU interrupt */
- SYS_UnlockReg(); /* Unlock protected registers */
- SCB->SCR = SCB_SCR_SLEEPDEEP_Msk; /* Set Deep sleep */
- CLK->PWRCTL |= (CLK_PWRCTL_PDEN_Msk | CLK_PWRCTL_PDWKDLY_Msk ); /* Enable Power down and wake up */
- //__WFI(); /* system really enter power down here ! */
- * @brief Power Down check function.
- * @param None.
- * @return None.
- void PowerDown_Check()
- uint32_t i,j;
- volatile uint32_t Tmp_NVIC_ISER;
- uint32_t gpio_error_count = 0;
- char *symbo_gpio[6] = {"A", "B", "C", "D", "E", "F"};
- GPIO_T *tGPIO;
- uint32_t SYS_MFP = 0xffffffff;
- printf("\n/***** PowerDown Check *****/");
- printf("\n/***** GPIO Check: *****/");
- Tmp_NVIC_ISER = NVIC->ISER[0]; //save NVIC setting
- NVIC->ICER[0] = 0xFFFFFFFF; //disables a device-specific interrupt in the NVIC interrupt controller
- for(j = 0; j < 11; j++) { /* Check MFP is set GPIO mode or not */
- SYS_MFP = *((volatile unsigned int *)(SYS_BASE + 0x30 + (j *4)));
- for(i = 0; i < 8; i++) {
- if(SYS_MFP & (0x7 << (i*4))) {
- gpio_error_count++;
- printf("\nGP%s Pin %d not set GPIO !!", symbo_gpio[(j/2)], (i+(8*(j%2))) );
- if( (SYS->GPF_MFPL & SYS_GPF_MFPL_PF3MFP_XT1_IN) != SYS_GPF_MFPL_PF3MFP_XT1_IN) { /* Check HXT_OUT pin */
- printf("\nGPF Pin 2 not set HXT_OUT !!!");
- printf("\nPlease Check GPF Pin 2 not connect crystal !!!");
- if( (SYS->GPF_MFPL & SYS_GPF_MFPL_PF2MFP_XT1_OUT) != SYS_GPF_MFPL_PF2MFP_XT1_OUT) { /* Check HXT_IN pin */
- printf("\nGPF Pin 3 not set HXT_IN !!!");
- printf("\nPlease Check GPF Pin 3 not connect crystal !!!");
- for(j = 0; j < 6; j++) {
- tGPIO =(GPIO_T*)((uint32_t)PA + (j * (0x40)));
- for(i = 0; i < 16; i++) {
- if((j == 4) & (i > 9)) // GPE
- break;
- if((j == 5) & (i > 5)) // GPF
- break;
- if(!(tGPIO->PIN & (1 << i))) { /* Check Pin status */
- printf("\nGP%s Pin %d can not pull high!!", symbo_gpio[j], i);
- if(gpio_error_count)
- printf("\nGPIO Check fail !!");
- else
- printf("\nGPIO Check pass");
- printf("\n");
- printf("\n/***** Clock Check: *****/");
- if(CLK->PWRCTL & CLK_PWRCTL_HXT_EN) /* Check HXT_EN */
- printf("\nHXT Enable");
- else
- printf("\nHXT Disable");
- if(CLK->PWRCTL & CLK_PWRCTL_LXT_EN) /* Check LXT_EN */
- printf("\nLXT Enable");
- else
- printf("\nLXT Disable");
- if(CLK->PWRCTL & CLK_PWRCTL_HIRC0_EN) /* Check HIRCO_EN */
- printf("\nHIRC Enable");
- else
- printf("\nHIRC Disable");
- if(CLK->PWRCTL & CLK_PWRCTL_LIRC_EN) /* Check LICR_EN */
- printf("\nLIRC Enable");
- else
- printf("\nLIRC Disable");
- printf("\n");
- printf("\n/***** Power Down setting check: *****/");
- if(CLK->PWRCTL & CLK_PWRCTL_PWRDOWN_EN) /* Check Power Down Enable */
- printf("\nChip Power-down mode Enable ");
- else
- printf("\nChip Power-down mode Disable !!!");
- if(SCB->SCR & 0x04) /* Check SCB configuration */
- printf("\nSCB->SCR set (0x%x) : ok", SCB->SCR);
- else
- printf("\nSCB->SCR set (0x%x) : error", SCB->SCR);
- //Restore NVIC->ISER setting
- NVIC->ISER[0] = Tmp_NVIC_ISER;
- printf("\n");
- printf("\n/***** Wake-up setting check: *****/");
- if(CLK->PWRCTL & CLK_PWRCTL_DELY_EN) /* Check Wake up delay */
- printf("\nWake-up Delay Counter Enable");
- else
- printf("\nWake-up Delay Counter Disable");
- if(CLK->PWRCTL & CLK_PWRCTL_WAKEINT_EN) /* Check Wake up interrupt */
- printf("\nPower-down Mode Wake-up Interrupt Enable");
- else
- printf("\nPower-down Mode Wake-up Interrupt Disable");
- if( NVIC->ISER[0] & (1 << ((uint32_t)(PDWU_IRQn) & 0x1F)) ) /* Check NVIC IRQ */
- printf("\nEnable PDWU_IRQn request for PDWU interrupt");
- else
- printf("\nDisable PDWU_IRQn request for PDWU interrupt");
- printf("\n");
- printf("\n/***** ISR check: *****/");
- if(NVIC_GetPendingIRQ(PDWU_IRQn)) /* Check Wake up interrupt pending */
- printf("\nPowerDown WakeUp Interrupt status is pending. (check fail)");
- else
- printf("\nPowerDown WakeUp Interrupt status is not pending. (check ok)");
- if(CLK->WKINTSTS & 0x1) /* Check Wake up status */
- printf("\nWake-up Interrupt Status is set. (check fail)");
- else
- printf("\nWake-up Interrupt Status is not set. (check ok)");
- printf("\n");
- printf("\n/***** PowerDown Check End *****/");
- * @brief Init system clock and I/O multi function .
- * @param None
- * @return None
- void SYS_Init(void)
- /* Init System Clock */
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Enable IP clock */
- CLK->APBCLK |= CLK_APBCLK_UART0_EN; // UART0 Clock Enable
- /* Select IP clock source */
- CLK->CLKSEL1 &= ~CLK_CLKSEL1_UART0SEL_Msk;
- CLK->CLKSEL1 |= CLK_CLKSEL1_UART0SEL_HIRC;// Clock source from HIRC
- /* Update System Core Clock */
- /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
- SystemCoreClockUpdate();
- /* Init I/O Multi-function */
- /* Set PB multi-function pins for UART0 RXD and TXD */
- SYS->GPB_MFPL &= ~(SYS_GPB_MFPL_PB0MFP_Msk|SYS_GPB_MFPL_PB1MFP_Msk);
- SYS->GPB_MFPL |= (SYS_GPB_MFPL_PB0MFP_UART0_RXD|SYS_GPB_MFPL_PB1MFP_UART0_TXD);
- /* Lock protected registers */
- SYS_LockReg();
- * @brief Config UART0.
- * @param None
- * @return None
- void UART0_Init()
- UART_Open(UART0, 115200); /* set UART baudrate is 115200 */
- * @brief Main routine.
- * @param None.
- * @return None.
- int32_t main(void)
- /* Init System, IP clock and multi-function I/O */
- SYS_Init();
- /* Init UART0 for printf */
- UART0_Init();
- /* Prepare to enter power down mode, to demo the usage of PowerDown_Check(),
- this function does not actually put this system to power down mode */
- Enter_PowerDown();
- /* Check system state before enter power down mode */
- PowerDown_Check();
- while(1);
- /*** (C) COPYRIGHT 2015 Nuvoton Technology Corp. ***/
