各位大神,我刚make menuconfig里的配置,修改好保存后make编译出现这种问题一直让选择:
make ARCH=arm CROSS_COMPILE=/home/lzhh/MYSELFE/filesystem/buildroot/buildroot-2018.02/output/host/bin/arm-linux-
scripts/kconfig/conf --silentoldconfig Kconfig
* Restart config...
* Configure standard kernel features (expert users)
Configure standard kernel features (expert users) (EXPERT) [Y/?] y
Enable 16-bit UID system calls (UID16) [Y/n/?] (NEW)
我用的是buildroot里的内核编译的,以前也出现过是make clean清除配置后重新编译才好的,但是重新编译太费事,所以想请大神帮忙解决下。
