W600可以运行VSF后,第一个加上的应用就是vsfvm脚本系统。基本上不需要移植,直接可以编译通过,针对W600做了一个应用demo。
项目位于:https://gitee.com/versaloon/vsf_open
工程位于:vsf\example\vsfaio\proj\EWARM_W600
开发板为TB-01,vsfvm的demo还是只是简单的串口答应,和点亮LED,不过脚本里使用了数组、线程等。
串口输出,之后板载的LED就会按照规律闪动:
脚本代码(已内置于源代码中):
- print("led toggle demo...\r\n");
- const LED0_PORT = 1, LED0_PIN = 14;
- const LED1_PORT = 1, LED1_PIN = 15;
- const LED2_PORT = 1, LED2_PIN = 16;
- const LED3_PORT = 1, LED3_PIN = 17;
- const LED4_PORT = 1, LED4_PIN = 18;
- const LED_NUM = 5;
- var ledarr = array_create(2, 1, LED_NUM, 2);
- ledarr.set(0, 0,
- LED0_PORT, LED0_PIN,
- LED1_PORT, LED1_PIN,
- LED2_PORT, LED2_PIN,
- LED3_PORT, LED3_PIN,
- LED4_PORT, LED4_PIN);
- led_toggle(gpio led, delay)
- led.config(GPIO_OUTPP).set();
- while (1)
- led.toggle();
- timer_delayms(delay);
- var idx = 0;
- while (idx < 5)
- thread(led_toggle, gpio_create(ledarr.get(idx, 0), ledarr.get(idx, 1)), 100 * (1 + idx));
- idx = idx + 1;
源代码:
- * Copyright (C) 2009 - 2010 by Simon Qian <SimonQian@SimonQian.com> *
- * This program is free software; you can redistribute it and/or modify *
- * it under the terms of the GNU General Public License as published by *
- * the Free Software Foundation; either version 2 of the License, or *
- * (at your option) any later version. *
- * This program is distributed in the hope that it will be useful, *
- * but WITHOUT ANY WARRANTY; without even the implied warranty of *
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
- * GNU General Public License for more details. *
- * You should have received a copy of the GNU General Public License *
- * along with this program; if not, write to the *
- * Free Software Foundation, Inc., *
- * 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. *
- #include "vsf.h"
- #include "usrapp.h"
- #include "vsfvm_objdump.h"
- struct usrapp_param_t
- char *src;
- } static const usrapp_param =
- .src = "\
- print("led toggle demo...\\r\\n");\r\n\
- const LED0_PORT = 1, LED0_PIN = 14;\r\n\
- const LED1_PORT = 1, LED1_PIN = 15;\r\n\
- const LED2_PORT = 1, LED2_PIN = 16;\r\n\
- const LED3_PORT = 1, LED3_PIN = 17;\r\n\
- const LED4_PORT = 1, LED4_PIN = 18;\r\n\
- const LED_NUM = 5;\r\n\
- var ledarr = array_create(2, 1, LED_NUM, 2);\r\n\
- ledarr.set(0, 0, \r\n\
- LED0_PORT, LED0_PIN,\r\n\
- LED1_PORT, LED1_PIN,\r\n\
- LED2_PORT, LED2_PIN,\r\n\
- LED3_PORT, LED3_PIN,\r\n\
- LED4_PORT, LED4_PIN);\r\n\
- \r\n\
- led_toggle(gpio led, delay)\r\n\
- {\r\n\
- led.config(GPIO_OUTPP).set();\r\n\
- while (1)\r\n\
- {\r\n\
- led.toggle();\r\n\
- timer_delayms(delay);\r\n\
- }\r\n\
- }\r\n\
- \r\n\
- var idx = 0;\r\n\
- while (idx < 5)\r\n\
- {\r\n\
- thread(led_toggle, gpio_create(ledarr.get(idx, 0), ledarr.get(idx, 1)), 100 * (1 + idx));\r\n\
- idx = idx + 1;\r\n\
- }\r\n\
- static const char *vsfvmc_errcode_str[] =
- TO_STR(VSFVMC_ERRCODE_NONE),
- // common error
- TO_STR(VSFVMC_BUG),
- TO_STR(VSFVMC_BYTECODE_TOOLONG),
- TO_STR(VSFVMC_NOT_ENOUGH_RESOURCES),
- TO_STR(VSFVMC_FATAL_ERROR),
- TO_STR(VSFVMC_NOT_SUPPORT),
- // lexer error
- TO_STR(VSFVMC_LEXER_NOT_SUPPORT),
- TO_STR(VSFVMC_LEXER_INVALID_OP),
- TO_STR(VSFVMC_LEXER_INVALID_STRING),
- TO_STR(VSFVMC_LEXER_INVALID_ESCAPE),
- TO_STR(VSFVMC_LEXER_SYMBOL_TOO_LONG),
- // parser error
- TO_STR(VSFVMC_PARSER_UNEXPECTED_TOKEN),
- TO_STR(VSFVMC_PARSER_ALREADY_DEFINED),
- TO_STR(VSFVMC_PARSER_INVALID_CLOSURE),
- TO_STR(VSFVMC_PARSER_INVALID_EXPR),
- TO_STR(VSFVMC_PARSER_UNINITED_CONST),
- TO_STR(VSFVMC_PARSER_INVALID_CONST),
- TO_STR(VSFVMC_PARSER_DIV0),
- TO_STR(VSFVMC_PARSER_EXPECT_FUNC_PARAM),
- TO_STR(VSFVMC_PARSER_TOO_MANY_FUNC_PARAM),
- TO_STR(VSFVMC_PARSER_MEMFUNC_NOT_FOUND),
- // compiler error
- TO_STR(VSFVMC_COMPILER_INVALID_MODULE),
- TO_STR(VSFVMC_COMPILER_INVALID_FUNC),
- TO_STR(VSFVMC_COMPILER_INVALID_FUNC_PARAM),
- TO_STR(VSFVMC_COMPILER_FAIL_USRLIB),
- static int usrapp_vm_set_bytecode(void *param, uint32_t code, uint32_t pos)
- struct usrapp_t *app = (struct usrapp_t *)param;
- if (pos >= dimof(app->vsfvm.token))
- return -1;
- app->vsfvm.token[pos] = code;
- return 0;
- struct usrapp_t usrapp =
- .debug.uart_stream.index = DEBUG_UART_INDEX,
- .debug.uart_stream.mode = VSFHAL_USART_STOPBITS_1 | VSFHAL_USART_PARITY_NONE,
- .debug.uart_stream.int_priority = 0xFF,
- .debug.uart_stream.baudrate = 115200,
- .debug.uart_stream.stream_tx = &usrapp.debug.stream_tx.stream,
- .debug.uart_stream.stream_rx = &usrapp.debug.stream_rx.stream,
- .debug.stream_tx.stream.op = &vsf_fifostream_op,
- .debug.stream_tx.mem.buffer.buffer = (uint8_t *)&usrapp.debug.txbuff,
- .debug.stream_tx.mem.buffer.size = sizeof(usrapp.debug.txbuff),
- .debug.stream_rx.stream.op = &vsf_fifostream_op,
- .debug.stream_rx.mem.buffer.buffer = (uint8_t *)&usrapp.debug.rxbuff,
- .debug.stream_rx.mem.buffer.size = sizeof(usrapp.debug.rxbuff),
- .vsfvm.vmc.dart.op = &vsfvmc_lexer_op_dart,
- void usrapp_srt_init(struct usrapp_t *app)
- VSFSTREAM_INIT(&app->debug.stream_rx);
- VSFSTREAM_INIT(&app->debug.stream_tx);
- vsf_usart_stream_init(&app->debug.uart_stream);
- vsfdbg_init((struct vsf_stream_t *)&app->debug.stream_tx);
- void usrapp_srt_poll(struct usrapp_t *app){}
- static void usrapp_vm_compile(struct usrapp_t *app)
- struct vsfvmc_t *vmc = &app->vsfvm.vmc.vmc;
- int err;
- vsfdbg_prints("start compiling ..." VSFCFG_DEBUG_LINEEND);
- vsfvmc_init(vmc, &usrapp, NULL, usrapp_vm_set_bytecode);
- vsfvmc_register_lexer(vmc, &app->vsfvm.vmc.dart);
- err = vsfvmc_script(vmc, "main.dart");
- if (err < 0) goto err_return;
- err = vsfvmc_input(vmc, usrapp_param.src);
- if (err < 0)
- err_return:
- err = -err;
- vsfdbg_printf("command line compile error: %s" VSFCFG_DEBUG_LINEEND,
- (err >= VSFVMC_ERRCODE_END) ? "unknwon error" : vsfvmc_errcode_str[err]);
- vsfdbg_printf("compile error around line %d column %d" VSFCFG_DEBUG_LINEEND,
- vmc->script.lexer.curctx.line + 1, vmc->script.lexer.curctx.col + 1);
- compile_end:
- vsfvmc_fini(vmc);
- return;
- err = vsfvmc_input(vmc, "\xFF");
- if (err) goto compile_end;
- vsfdbg_printf("compiled OK, token number : %d" VSFCFG_DEBUG_LINEEND,
- vmc->bytecode_pos);
- app->vsfvm.token_num = vmc->bytecode_pos;
- vsfdbg_prints("objdump:" VSFCFG_DEBUG_LINEEND);
- vsfvm_objdump(app->vsfvm.token, app->vsfvm.token_num);
- static void usrapp_vm_run(struct usrapp_t *app)
- struct vsfvm_t *vm = &app->vsfvm.vm.vm;
- struct vsfvm_script_t *script = &app->vsfvm.vm.script;
- memset(vm, 0, sizeof(*vm));
- memset(script, 0, sizeof(*script));
- vm->thread_pool.pool_size = 16;
- script->token = app->vsfvm.token;
- script->token_num = app->vsfvm.token_num;
- vsfvm_init(vm);
- vsfvm_script_init(vm, script);
- void usrapp_nrt_init(struct usrapp_t *app)
- vsfvm_ext_register_std();
- vsfvm_ext_register_vsf();
- vsfdbg_prints("source code:" VSFCFG_DEBUG_LINEEND);
- vsfdbg_prints(usrapp_param.src);
- vsfdbg_prints(VSFCFG_DEBUG_LINEEND);
- usrapp_vm_compile(app);
- usrapp_vm_run(app);
- void usrapp_nrt_poll(struct usrapp_t *app)
- vsfvm_poll(&app->vsfvm.vm.vm);
- bool usrapp_cansleep(struct usrapp_t *app)
- return app->vsfvm.vm.vm.appendlist.next == NULL;
- void usrapp_initial_init(struct usrapp_t *app){}
