请香版主和各位指点下 STM32 AD采样 偏差很大
4756|6
 楼主| ql1007 发表于 2011-8-15 15:49 | 显示全部楼层 |阅读模式
情况是这样的, STM32 的采样 我现在PC0-PC3 PA1,5个通道采样
其他四个PC口的都正常,但是PA1的通道始终不对,电压我量了 到片子这边的是1.2V 比如,但我读出来PA1的 才0.7几V差的太远了 不知道什么原因啊 ,量了 1.2的确是进到单片机了,软件配置查了 一样的配置 其他通道 都正常,PA1用的是通道1 也是固件库里用的,您给分析下什么毛病啊
部分配置如下:
DMA_DeInit(DMA1_Channel1);
  DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_value;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  DMA_InitStructure.DMA_BufferSize = 100;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel1, &DMA_InitStructure);
   DMA_ITConfig(DMA1_Channel1, DMA_IT_TC, ENABLE); //DMA通道1传输完成中断
  /* Enable DMA1 channel1 */
  //DMA_Cmd(DMA1_Channel1, ENABLE);//以前在这里启用DMA,出现通道错乱
     /* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel = 5;//通道的数目
  ADC_Init(ADC1, &ADC_InitStructure);
   /* ADC1 regular channel14 configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_55Cycles5);//VDD1
  ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 2, ADC_SampleTime_55Cycles5); //udrvs
  ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 3, ADC_SampleTime_55Cycles5); //VDD
  ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 4, ADC_SampleTime_55Cycles5); //vdch
  ADC_RegularChannelConfig(ADC1, ADC_Channel_1,  6, ADC_SampleTime_55Cycles5);//UR2 ADC_Channel1 是1通道的
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
   /* Enable ADC1 reset calibaration register */
  ADC_ResetCalibration(ADC1);
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
  /* Start ADC1 calibaration */
  ADC_StartCalibration(ADC1);
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
  /* Start ADC1 Software Conversion */
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);
其他四个通道PC口的都正常 ,就是这个怎么都不对 明明电压过去了 ,求教啊
谢谢
 楼主| ql1007 发表于 2011-8-15 17:45 | 显示全部楼层
我找到了 是自己的原因 是5个 不是6个 错写成6了 哎
huanben 发表于 2011-8-15 20:01 | 显示全部楼层
哥们 话都让你说完了
hsbjb 发表于 2011-8-16 09:17 | 显示全部楼层
楼主的自我发现错误的能力还是挺强的
12812ty 发表于 2011-8-16 09:57 | 显示全部楼层
请问LZ 为什么DMA_InitStructure.DMA_BufferSize = 100;
DMA的缓存数设置为100
lyy8611 发表于 2011-9-7 10:01 | 显示全部楼层
请问楼主,我刚开始学STM32,我怎样在开发板上实现多通道的AD采样呢?我实在是太菜了,很多东西都搞不清楚,还请楼主指点啊
yinyangdianzi 发表于 2011-9-7 11:15 | 显示全部楼层
明天会更好
