[应用相关] 在C#中实现矩阵运算
1248|2
 楼主| 观海 发表于 2018-10-11 13:01 | 显示全部楼层 |阅读模式
本文博客链接:http://blog.csdn.net/jdh99,作者:jdh.
环境:
主机:XP
开发环境:VS2008
功能:
在C#中实现矩阵运算
 楼主| 观海 发表于 2018-10-11 13:03 | 显示全部楼层
源代码:using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
//二维矩阵
class _Matrix
    public int m;
    public int n;
    public float[] arr;
    //初始化
    public _Matrix()
        m = 0;
        n = 0;
    public _Matrix(int mm,int nn)
        m = mm;
        n = nn;
    //设置m
    public void set_mn(int mm,int nn)
        m = mm;
        n = nn;
    //设置m
    public void set_m(int mm)
        m = mm;
    //设置n
    public void set_n(int nn)
        n = nn;
    //初始化
    public void init_matrix()
        arr = new float[m * n];
    //释放
    public void free_matrix()
        //delete [] arr;
    //读取i,j坐标的数据
    //失败返回-31415,成功返回值
    public float read(int i,int j)
        if (i >= m || j >= n)
            return -31415;
        //return *(arr + i * n + j);
        return arr[i * n + j];
    //写入i,j坐标的数据
    //失败返回-1,成功返回1
    public int write(int i,int j,float val)
            return -1;
        arr[i * n + j] = val;
        return 1;
//二维运算类
class _Matrix_Calc
    //初始化
    public  _Matrix_Calc()
    //成功返回1,失败返回-1
    public  int add(ref _Matrix A,ref _Matrix B,ref _Matrix C)
        int i = 0;
        int j = 0;
        //判断是否可以运算
        if (A.m != B.m || A.n != B.n ||
            A.m != C.m || A.n != C.n)
            return -1;
        //运算
        for (i = 0;i < C.m;i++)
            for (j = 0;j < C.n;j++)
                C.write(i,j,A.read(i,j) + B.read(i,j));
        return 1;
    //成功返回1,失败返回-1
    public  int subtract(ref _Matrix A,ref _Matrix B, ref _Matrix C)
        int i = 0;
        int j = 0;
        //判断是否可以运算
            return -1;
        //运算
                C.write(i,j,A.read(i,j) - B.read(i,j));
        return 1;
    //C = A * B
    //成功返回1,失败返回-1
    public int multiply(ref _Matrix A, ref _Matrix B, ref _Matrix C)
        int i = 0;
        int j = 0;
        int k = 0;
        float temp = 0;
        //判断是否可以运算
        if (A.m != C.m || B.n != C.n ||
            A.n != B.m)
            return -1;
        //运算
                temp = 0;
                for (k = 0;k < A.n;k++)
                    temp += A.read(i,k) * B.read(k,j);
                C.write(i,j,temp);
        return 1;
    //行列式的值,只能计算2 * 2,3 * 3
    //失败返回-31415,成功返回值
    public float det(ref _Matrix A)
        float value = 0;
        //判断是否可以运算
        if (A.m != A.n || (A.m != 2 && A.m != 3))
            return -31415;
        //运算
        if (A.m == 2)
            value = A.read(0,0) * A.read(1,1) - A.read(0,1) * A.read(1,0);
        else
            value = A.read(0,0) * A.read(1,1) * A.read(2,2) +
                    A.read(0,1) * A.read(1,2) * A.read(2,0) +
                    A.read(0,2) * A.read(1,0) * A.read(2,1) -
                    A.read(0,0) * A.read(1,2) * A.read(2,1) -
                    A.read(0,1) * A.read(1,0) * A.read(2,2) -
                    A.read(0,2) * A.read(1,1) * A.read(2,0);
        return value;
    //求转置矩阵,B = AT
    //成功返回1,失败返回-1
    public int transpos(ref _Matrix A,ref _Matrix B)
        int i = 0;
        int j = 0;
        //判断是否可以运算
        if (A.m != B.n || A.n != B.m)
            return -1;
        //运算
        for (i = 0;i < B.m;i++)
            for (j = 0;j < B.n;j++)
                B.write(i,j,A.read(j,i));
        return 1;
    //求逆矩阵,B = A^(-1)
    //成功返回1,失败返回-1
    public int inverse(ref _Matrix A, ref _Matrix B)
        int i = 0;
        int j = 0;
        int k = 0;
        _Matrix m = new _Matrix(A.m,2 * A.m);
        float temp = 0;
        float b = 0;
        //判断是否可以运算
        if (A.m != A.n || B.m != B.n || A.m != B.m)
            return -1;
        //如果是2维或者3维求行列式判断是否可逆
        if (A.m == 2 || A.m == 3)
            if (det(A) == 0)
                return -1;
        //增广矩阵m = A | B初始化
        m.init_matrix();
        for (i = 0;i < m.m;i++)
            for (j = 0;j < m.n;j++)
                if (j <= A.n - 1)
                    m.write(i,j,A.read(i,j));
                else
                    if (i == j - A.n)
                        m.write(i,j,1);
                    else
                        m.write(i,j,0);
        //高斯消元
        //变换下三角
        for (k = 0;k < m.m - 1;k++)
            //如果坐标为k,k的数为0,则行变换
            if (m.read(k,k) == 0)
                for (i = k + 1;i < m.m;i++)
                    if (m.read(i,k) != 0)
                        break;
                if (i >= m.m)
                    return -1;
                else
                    //交换行
                        temp = m.read(k,j);
                        m.write(k,j,m.read(k + 1,j));
                        m.write(k + 1,j,temp);
            //消元
                //获得倍数
                b = m.read(i,k) / m.read(k,k);
                //行变换
                    temp = m.read(i,j) - b * m.read(k,j);
                    m.write(i,j,temp);
        //变换上三角
        for (k = m.m - 1;k > 0;k--)
            //如果坐标为k,k的数为0,则行变换
                        break;
                if (i >= m.m)
                    return -1;
                else
                    //交换行
                        temp = m.read(k,j);
            //消元
            for (i = k - 1;i >= 0;i--)
                //获得倍数
                //行变换
                    m.write(i,j,temp);
        //将左边方阵化为单位矩阵
            if (m.read(i,i) != 1)
                //获得倍数
                b = 1 / m.read(i,i);
                //行变换
                    temp = m.read(i,j) * b;
                    m.write(i,j,temp);
        //求得逆矩阵
            for (j = 0;j < B.m;j++)
                B.write(i,j,m.read(i,j + m.m));
        //释放增广矩阵
        m.free_matrix();
        return 1;
 楼主| 观海 发表于 2018-10-11 13:04 | 显示全部楼层
namespace test
    public partial class Form1 : Form
        double zk;
        double xkg, pkg, kk, xk, pk, q, r;
        public Form1()
            InitializeComponent();
            xk = 0;
            pk = 0;
            q = 0.00001;
            r = 0.0001;
            int i = 0;
            int j = 0;
            int k = 0;
            _Matrix_Calc m_c = new _Matrix_Calc();
            _Matrix m1 = new _Matrix(2, 2);
            _Matrix m2 = new _Matrix(2, 2);
            _Matrix m3 = new _Matrix(2, 2);
            //初始化内存
            m1.init_matrix();
            m2.init_matrix();
            m3.init_matrix();
            //初始化数据
            k = 1;
            for (i = 0;i < m1.m;i++)
                for (j = 0;j < m1.n;j++)
                    m1.write(i,j,k++);
            for (i = 0;i < m2.m;i++)
                for (j = 0;j < m2.n;j++)
                    m2.write(i,j,k++);
            m_c.multiply(ref m1,ref  m2, ref m3);
            //output.Text = Convert.ToString(m3.read(1,1));
            output.Text = Convert.ToString(m_c.det(ref m1));
        private void button1_Click(object sender, EventArgs e)
            zk = Convert.ToDouble(input.Text);
            //时间方程
            xkg = xk;
            pkg = pk + q;
            //状态方程
            kk = pkg / (pkg + r);
            xk = xkg + kk * (zk - xkg);
            pk = (1 - kk) * pkg;
            //输出
            output.Text = Convert.ToString(xk);
        private void textBox1_TextChanged(object sender, EventArgs e)
