[FPGA] Xilinx XC7K410T SPI flash 无法擦除以及烧写
3404|3
 楼主| dong1412 发表于 2018-10-19 10:57 | 显示全部楼层 |阅读模式
flash型号是S25FL256SAGMFIR01
参考如下log:
INFO:iMPACT - Current time: 2018/10/18 17:25:24
PROGRESS_START - Starting Operation.
Maximum TCK operating frequency for this device chain: 66000000.
Validating chain...
Boundary-scan chain validated successfully.
1: Device Temperature: Current Reading: -273.00 C
1: VCCINT Supply: Current Reading:   0.000 V
1: VCCAUX Supply: Current Reading:   0.000 V
Unprotect sectors: FALSE
SPI SLAVE TYPE in Cse_Operate.c is 99
Core is not loaded.
INFO:iMPACT - Downloading D:\Xilinx\14.7\ISE_DS\ISE\data\cse\cseflash\kintex7\xc7k410t_xsdbspi.cor core file.
INFO:iMPACT - Creating XC7K410T device.
'1': Programming device...
Match_cycle = NoWait.
Match cycle: NoWait
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
INFO:Cse - Status register values:
INFO:Cse - 0011 1111 1001 1110 0000 1000 0000 0010
INFO:Cse - '1': Completed downloading bit file to device.
INFO:Cse - '1': Programming completed successfully.
PROGRESS_END - End Operation.
Elapsed time =      6 sec.
key: period_frc, value: 0
key: dclk_has_reset, value: 0
key: period_int, value: 10
Found Slave on Bus Index.
Slave Int Type is 99, slave Index is 0 , SPI_SLAVE is 99
Slave Type is 99, slave Index is 0
SPI core clock speed value = 0xA801.
'1': IDCODE is '010219' (in hex).
'1': ID Check passed.
'1': Erasing Device.
'1': Using Sector Erase.
ERROR:Cse - '1': Device has exceeded the allocated time.
'1': Programming Flash.
Elapsed time =     19 sec.
'1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and mode settings.
mode settings如图,将上拉电阻短接后仍然无法擦除和烧写,芯片没有问题,因为这块芯片是从另一块电路构造相同的板子上拆下来的,它在之前的板子上是可以擦除以及烧写的
 楼主| dong1412 发表于 2018-10-19 14:32 | 显示全部楼层
换了芯片后好了,此贴终结
zhangmangui 发表于 2018-10-20 20:40 | 显示全部楼层
好的    解决了就好     用的是QSPI X4是吧
 楼主| dong1412 发表于 2018-11-7 20:02 | 显示全部楼层
是的
