mspg2553的ccs中自带程序ta.21c不能运行
1066|6
 楼主| Thorald 发表于 2018-10-24 20:53 | 显示全部楼层 |阅读模式
ccs, se, ge, TI, IO
CCSmsp430g2553自带程序ta.21c。在launch pad上我把p1.1和p2.1连接后跑程序。一直进不了中断。后来看了下程序发现他的自带程序有两行有错。我用//////////////标记了出来。这两行应该是P1DIR &= ~BIT1;P1SEL |= BIT1,他程序是BIT2。但是修改之后还是一直进不了中断。我后来又用函数发生器作为捕获信号接到p1.1,仍然进不了中断。以前没有朋友运行过ta.21c这个程序吗?难道能正常运行?
#include <msp430.h>
unsigned char Count, First_Time;
unsigned int REdge1, REdge2, FEdge;
int main(void)
unsigned int Period, ON_Period;
unsigned char DutyCycle;
WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
// P1SEL |= BIT0;
P1DIR |= BIT0; // P1.0/LED Output
P1OUT &= ~BIT0; // LED off
if (CALBC1_8MHZ==0xFF) // If calibration constant erased
while(1); // do not load, trap CPU!!
DCOCTL = 0; // Select lowest DCOx and MODx settings
BCSCTL1 = CALBC1_8MHZ; // Set DCO to 8MHz
DCOCTL = CALDCO_8MHZ;
// Configure Port Pins
P2DIR |= BIT1; // P2.1/TA1.1 Output
P2SEL |= BIT1; // TA1.1 Option select
P1DIR &= ~BIT2; // P1.1/TA0.1 Input Capture///////////////////////////////////////////////////////////////////////////////////////////////////////
P1SEL |= BIT2; // TA0.1 option select////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
// Configure TA1.1 to output PWM signal
// Period = 82/32khz = 2.5ms ~ 400Hz Freq
TA1CCR0 = 82-1; // Period Register
TA1CCR1 = 21; // TA1.1 25% dutycycle
TA1CCTL1 |= OUTMOD_7; // TA1CCR1, Reset/Set
TA1CTL = TASSEL_1 + MC_1 + TACLR; // ACLK, upmode, clear TAR
// Configure the TA0CCR1 to do input capture
TA0CCTL1 = CAP + CM_3 + CCIE + SCS + CCIS_0;
// TA0CCR1 Capture mode; CCI1A; Both
// Rising and Falling Edge; interrupt enable
TA0CTL |= TASSEL_2 + MC_2 + TACLR; // SMCLK, Cont Mode; start timer
// Variable Initialization
Count = 0x0;
First_Time = 0x01;
while(1)
__bis_SR_register(LPM0_bits + GIE); // Enter LPM0
__no_operation(); // For debugger
// On exiting LPM0
if (TA0CCTL1 & COV) // Check for Capture Overflow
while(1); // Loop Forever
Period = REdge2 - REdge1; // Calculate Period
ON_Period = FEdge-REdge1; // On period
DutyCycle = ((unsigned long)ON_Period*100/Period);
if(DutyCycle!= 25)
P1OUT |= BIT0;
else
P1OUT &= ~BIT0;
// TA0_A1 Interrupt vector
#pragma vector = TIMER0_A1_VECTOR
__interrupt void TIMER0_A1_ISR (void)
switch(__even_in_range(TA0IV,0x0A))
case TA0IV_NONE: break; // Vector 0: No interrupt
case TA0IV_TACCR1: // Vector 2: TACCR1 CCIFG
if (TA0CCTL1 & CCI) // Capture Input Pin Status
// Rising Edge was captured
if (!Count)
REdge1 = TA0CCR1;
Count++;
else
REdge2 = TA0CCR1;
Count=0x0;
__bic_SR_register_on_exit(LPM0_bits + GIE); // Exit LPM0 on return to main
if (First_Time)
First_Time = 0x0;
else
// Falling Edge was captured
if(!First_Time)
FEdge = TA0CCR1;
break;
case TA0IV_TACCR2: break; // Vector 4: TACCR2 CCIFG
case TA0IV_6: break; // Vector 6: Reserved CCIFG
case TA0IV_8: break; // Vector 8: Reserved CCIFG
case TA0IV_TAIFG: break; // Vector 10: TAIFG
default: break;
Bjorn 发表于 2018-10-24 21:15 | 显示全部楼层
例程错的可能性及小,ti毕竟是大厂家
Rollo 发表于 2018-10-24 21:23 | 显示全部楼层
之前做过flash的擦写实验没??
dirtwillfly 发表于 2018-10-24 21:28 | 显示全部楼层
我测试了例程,并没有发现什么问题。有没有可能是硬件连接问题?
Rangar 发表于 2018-10-24 21:32 | 显示全部楼层
说的是P1.2和P2.1啊。哪来的P1.1
Stannis 发表于 2018-10-24 21:43 | 显示全部楼层
P1DIR &= ~BIT2; // P1.1/TA0.1 Input ,BIT2不是P1.2吗,他注释后面写P1.1
Brand2 发表于 2018-10-24 21:57 | 显示全部楼层
你的根源在于“在launch pad上我把p1.1和p2.1连接后跑程序。一直进不了中断。”这句话,你一开始就认定P1.1了,实际是P1.2
