[ARM入门] 关于天嵌E9卡片电脑与TQIMX6Q开发平台声卡驱动移植
1202|0
 楼主| Margaple 发表于 2018-12-17 14:14 | 显示全部楼层 |阅读模式
  经过前面的移植,tqimx6q已经可以正常驱动触摸屏了,本文我们来移植声卡驱动。
  DTS编写
  由于tqimx6q搭载的声卡是sgtl5000芯片,因此,参考dts目录下其它开发板的相应信息,我们可以在DTS中添加如下内容:
  1. / {
  2.
  3.     ...
  4.
  5.     regulators {
  6.
  7.         ...
  8.
  9.         reg_3p3v: 3p3v {
  10.             compatible = "regulator-fixed";
  11.             regulator-name = "3P3V";
  12.             regulator-min-microvolt = <3300000>;
  13.             regulator-max-microvolt = <3300000>;
  14.             regulator-always-on;
  15.         };
  16.     };
  17.
  18.     ...
  19.
  20.     sound {
  21.         compatible = "fsl,imx-audio-sgtl5000";
  22.         model = "imx6q-sgtl5000";
  23.         ssi-controller = <&ssi1>;
  24.         audio-codec = <&codec>;
  25.         audio-routing =
  26.             "MIC_IN", "Mic Jack",
  27.             "Mic Jack", "Mic Bias",
  28.             "Headphone Jack", "HP_OUT";
  29.         mux-int-port = <1>;
  30.         mux-ext-port = <3>;
  31.     };
  32. };
  33.
  34. ...
  35.
  36. &i2c2 {
  37.     clock-frequency = <100000>;
  38.     pinctrl-names = "default";
  39.     pinctrl-0 = <&pinctrl_i2c2_2>;
  40.     status = "okay";
  41.
  42.     codec: sgtl5000@0a {
  43.         compatible = "fsl,sgtl5000";
  44.         reg = <0x0a>;
  45.         clocks = <&clks 201>;
  46.         VDDA-supply = <®_3p3v>;
  47.         VDDIO-supply = <®_3p3v>;
  48.         VDDD-supply = <®_1p2v>;
  49.     };
  50. };
  51.
  52. &ssi1 {
  53.     fsl,mode = "i2s-slave";
  54.     status = "okay";
  55. };
  56.
  57. &audmux {
  58.     pinctrl-names = "default";
  59.     pinctrl-0 = <&pinctrl_audmux_2>;
  60.     status = "okay";
  61. };
  62.
  63. &iomuxc {
  64.     pinctrl-names = "default";
  65.     pinctrl-0 = <&pinctrl_hog>;
  66.
  67.     ...
  68.
  69.     hog {
  70.         pinctrl_hog: hoggrp-1 {
  71.             fsl,pins = <
  72.                 MX6QDL_PAD_GPIO_0__CCM_CLKO1    0x80000000
  73.             >;
  74.         };
  75.     };
  76. };
  添加以上内容后重新编译并烧写DTB即可。
  测试方法
  测试方法当然还是使用alsa-lib和alsa-utils。相关工具的移植方法如下:
  Step1. 获取并交叉编译alsa-lib:
  1. wget ftp://ftp.alsa-project.org/pub/lib/alsa-lib-1.0.29.tar.bz2
  2. tar jxf alsa-lib-1.0.29.tar.bz2
  3. cd alsa-lib-1.0.29
  4. /configure --host=arm-linux-gnueabi --prefix=/mnt/usr/lib/alsa-lib
  5. make
  6. sudo make install
  Step2. 获取并交叉编译alsa-utils:
  1. wget ftp://ftp.alsa-project.org/pub/utils/alsa-utils-1.0.29.tar.bz2
  2. tar jxf alsa-utils-1.0.29.tar.bz2
  3. cd alsa-utils-1.0.29
  4. ./configure --host=arm-linux-gnueabi --prefix=/usr/share/arm-alsa --with-alsa-inc-prefix=/usr/share/arm-alsa/include --with-alsa-prefix=/usr/share/arm-alsa/lib --disable-alsamixer --disable-xmlto
  5. make
  Step3. 检测交叉编译是否成功:
  1. file aplay
  如果显示内容大致如下:
  • aplay: ELF 32-bit LSB  executable, ARM, EABI5 version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.32, BuildID[sha1]=280644397dc85eaf1f1dc26b03be754ac4777cff, not stripped
  则表示交叉编译成功,关键词是ARM。
  Step4. 将交叉编译好的alsa拷贝到根文件系统:
  1. sudo cp /usr/share/arm-alsa/ /mnt/usr/share/ -rfa
  2. sudo cp /usr/share/arm-alsa/* /mnt/ -rfa
  3. sync
  接下来就可以用新的跟文件系统启动开发板了。
  Step5. 测试录音:
  1. aplay test.wav
  如果按照以上步骤正确的进行了移植,就可以听到录音时自己说的话了。
  启动Log
  完整的启动Log如下:
  1. U-Boot 2013.04-04987-g98fdbdc-dirty (May 03 2015 - 11:46:24)
  2.
  3. CPU:   Freescale i.MX6Q rev1.2 at 792 MHz
  4. CPU:   Temperature 26 C, calibration data: 0x54e4bb69
  5. Reset cause: POR
  6. Board: MX6Q/SDL-SabreSD
  7. I2C:   ready
  8. DRAM:  1 GiB
  9. MMC:   FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
  10. No panel detected: default to Hannstar-XGA
  11. Display: Hannstar-XGA (1024x768)
  12. In:    serial
  13. Out:   serial
  14. Err:   serial
  15. mmc0 is current device
  16. Net:   Phy not found
  17. PHY reset timed out
  18. FEC [PRIME]
  19. Warning: failed to set MAC address
  20.
  21. Normal Boot
  22. Hit any key to stop autoboot:  0
  23. mmc0 is current device
  24.
  25. MMC read: dev # 0, block # 2048, count 12288 ... 12288 blocks read: OK
  26.
  27. MMC read: dev # 0, block # 20480, count 2048 ... 2048 blocks read: OK
  28. ## Booting kernel from Legacy Image at 11ffffc0 ...
  29.    Image Name:   Linux-3.10.17-80739-g33597e3-dir
  30.    Image Type:   ARM Linux Kernel Image (uncompressed)
  31.    Data Size:    5289360 Bytes = 5 MiB
  32.    Load Address: 12000000
  33.    Entry Point:  12000000
  34.    Verifying Checksum ... OK
  35. ## Flattened Device Tree blob at 18000000
  36.    Booting using the fdt blob at 0x18000000
  37.    XIP Kernel Image ... OK
  38. OK
  39.    Using Device Tree in place at 18000000, end 1800d14d
  40.
  41. Starting kernel ...
  42.
  43. Booting Linux on physical CPU 0x0
  44. Linux version 3.10.17-80739-g33597e3-dirty (lilianrong@lenovo) (gcc version 4.7.3 (Ubuntu/Linaro 4.7.3-12ubuntu1) ) #3 SMP PREEMPT Wed May 13 00:16:49 CST 2015
  45. CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
  46. CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
  47. Machine: Freescale i.MX6 Quad/DualLite (Device Tree), model: Freescale i.MX6 Quad TQIMX6Q Smart Device Board
  48. cma: CMA: reserved 320 MiB at 3c000000
  49. Memory policy: ECC disabled, Data cache writealloc
  50. PERCPU: Embedded 8 pages/cpu @814fa000 s8896 r8192 d15680 u32768
  51. Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096
  52. Kernel command line: noinitrd console=ttymxc0,115200 root=/dev/mmcblk0p1 rw rootfstype=ext4 init=/linuxrc
  53. PID hash table entries: 4096 (order: 2, 16384 bytes)
  54. Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
  55. Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
  56. Memory: 1024MB = 1024MB total
  57. Memory: 697784k/697784k available, 350792k reserved, 0K highmem
  58. Virtual kernel memory layout:
  59.     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
  60.     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
  61.     vmalloc : 0xc0800000 - 0xff000000   (1000 MB)
  62.     lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
  63.     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
  64.     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
  65.       .text : 0x80008000 - 0x80be704c   (12157 kB)
  66.       .init : 0x80be8000 - 0x80c2a2c0   ( 265 kB)
  67.       .data : 0x80c2c000 - 0x80c7c260   ( 321 kB)
  68.        .bss : 0x80c7c260 - 0x80ce5434   ( 421 kB)
  69. SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  70. Preemptible hierarchical RCU implementation.
  71. NR_IRQS:16 nr_irqs:16 16
  72. L310 cache controller enabled
  73. l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1048576 B
  74. sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
  75. CPU identified as i.MX6Q, silicon rev 1.2
  76. Console: colour dummy device 80x30
  77. Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
  78. pid_max: default: 32768 minimum: 301
  79. Mount-cache hash table entries: 512
  80. CPU: Testing write buffer coherency: ok
  81. CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
  82. Setting up static identity map for 0x806106a8 - 0x80610700
  83. CPU1: Booted secondary processor
  84. CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
  85. CPU2: Booted secondary processor
  86. CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
  87. CPU3: Booted secondary processor
  88. CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
  89. Brought up 4 CPUs
  90. SMP: Total of 4 processors activated (6324.22 BogoMIPS).
  91. CPU: All CPU(s) started in SVC mode.
  92. devtmpfs: initialized
  93. pinctrl core: initialized pinctrl subsystem
  94. regulator-dummy: no parameters
  95. NET: Registered protocol family 16
  96. DMA: preallocated 256 KiB pool for atomic coherent allocations
  97. Use WDOG1 as reset source
  98. syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
  99. vdd1p1: 800 <--> 1375 mV at 1125 mV
  100. vdd3p0: 2800 <--> 3150 mV at 3000 mV
  101. vdd2p5: 2000 <--> 2750 mV at 2425 mV
  102. cpu: 725 <--> 1450 mV at 1150 mV
  103. vddpu: 725 <--> 1450 mV
  104. vddsoc: 725 <--> 1450 mV at 1200 mV
  105. syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
  106. syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
  107. hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
  108. hw-breakpoint: maximum watchpoint size is 4 bytes.
  109. imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
  110. bio: create slab <bio-0> at 0
  111. mxs-dma 110000.dma-apbh: initialized
  112. usb_otg_vbus: 5000 mV
  113. mipi_dsi_pwr_on: no parameters
  114. 3P3V: 3300 mV
  115. 1P2V: 1200 mV
  116. i2c-core: driver [max17135] using legacy suspend method
  117. i2c-core: driver [max17135] using legacy resume method
  118. SCSI subsystem initialized
  119. usbcore: registered new interface driver usbfs
  120. usbcore: registered new interface driver hub
  121. usbcore: registered new device driver usb
  122. i2c i2c-0: IMX I2C adapter registered
  123. i2c i2c-1: IMX I2C adapter registered
  124. Linux video capture interface: v2.00
  125. pps_core: LinuxPPS API ver. 1 registered
  126. pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  127. PTP clock support registered
  128. imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
  129. imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
  130. MIPI CSI2 driver module loaded
  131. Advanced Linux Sound Architecture Driver Initialized.
  132. cfg80211: Calling CRDA to update world regulatory domain
  133. Switching to clocksource mxc_timer1
  134. NET: Registered protocol family 2
  135. TCP established hash table entries: 8192 (order: 4, 65536 bytes)
  136. TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
  137. TCP: Hash tables configured (established 8192 bind 8192)
  138. TCP: reno registered
  139. UDP hash table entries: 512 (order: 2, 16384 bytes)
  140. UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
  141. NET: Registered protocol family 1
  142. RPC: Registered named UNIX socket transport module.
  143. RPC: Registered udp transport module.
  144. RPC: Registered tcp transport module.
  145. RPC: Registered tcp NFSv4.1 backchannel transport module.
  146. hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
  147. pureg-dummy: no parameters
  148. imx6_busfreq busfreq.15: DDR medium rate not supported.
  149. Bus freq driver module loaded
  150. VFS: Disk quotas dquot_6.5.2
  151. Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
  152. NFS: Registering the id_resolver key type
  153. Key type id_resolver registered
  154. Key type id_legacy registered
  155. jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
  156. fuse init (API version 7.22)
  157. msgmni has been set to 2002
  158. io scheduler noop registered
  159. io scheduler deadline registered
  160. io scheduler cfq registered (default)
  161. imx-weim 21b8000.weim: WEIM driver registered.
  162. mxc_mipi_dsi 21e0000.mipi: i.MX MIPI DSI driver probed
  163. MIPI DSI driver module loaded
  164. mxc_sdc_fb fb.26: register mxc display driver lcd
  165. Console: switching to colour frame buffer device 100x30
  166. imx-sdma 20ec000.sdma: no iram assigned, using external mem
  167. imx-sdma 20ec000.sdma: loaded firmware 1.1
  168. imx-sdma 20ec000.sdma: initialized
  169. Serial: IMX driver
  170. 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
  171. console [ttymxc0] enabled
  172. 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
  173. 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
  174. 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
  175. 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 62) is a IMX
  176. serial: Freescale lpuart driver
  177. [drm] Initialized drm 1.1.0 20060810
  178. [drm] Initialized vivante 1.0.0 20120216 on minor 0
  179. brd: module loaded
  180. loop: module loaded
  181. CAN device driver interface
  182. flexcan 2090000.can: device registered (reg_base=c0a38000, irq=142)
  183. fec 2188000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
  184. fec 2188000.ethernet (unregistered net_device): Using random MAC address: c2:9c:30:14:aa:25
  185. libphy: fec_enet_mii_bus: probed
  186. fec 2188000.ethernet eth0: registered PHC device 0
  187. ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  188. usbcore: registered new interface driver usb-storage
  189. ci_hdrc ci_hdrc.1: doesn't support gadget
  190. ci_hdrc ci_hdrc.1: EHCI Host Controller
  191. ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
  192. ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
  193. hub 1-0:1.0: USB hub found
  194. hub 1-0:1.0: 1 port detected
  195. mousedev: PS/2 mouse device common for all mice
  196. i2c-core: driver [isl29023] using legacy suspend method
  197. i2c-core: driver [isl29023] using legacy resume method
  198. snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
  199. i2c /dev entries driver
  200. i2c-core: driver [mag3110] using legacy suspend method
  201. i2c-core: driver [mag3110] using legacy resume method
  202. imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
  203. cpuidle: using governor ladder
  204. cpuidle: using governor menu
  205. sdhci: Secure Digital Host Controller Interface driver
  206. sdhci: Copyright(c) Pierre Ossman
  207. sdhci-pltfm: SDHCI platform and OF driver helper
  208. mmc0: no vqmmc regulator found
  209. mmc0: no vmmc regulator found
  210. mmc0: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
  211. mmc1: no vqmmc regulator found
  212. mmc1: no vmmc regulator found
  213. mmc1: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
  214. mmc0: new high speed SDHC card at address e624
  215. mmcblk0: mmc0:e624 SS08G 7.40 GiB
  216. mmcblk0: p1
  217. mmc1: BKOPS_EN bit is not set
  218. usb 1-1: new high-speed USB device number 2 using ci_hdrc
  219. mmc1: new high speed DDR MMC card at address 0001
  220. mmcblk1: mmc1:0001 008G92 7.28 GiB
  221. mmcblk1boot0: mmc1:0001 008G92 partition 1 4.00 MiB
  222. mmcblk1boot1: mmc1:0001 008G92 partition 2 4.00 MiB
  223. mmcblk1rpmb: mmc1:0001 008G92 partition 3 512 KiB
  224. mmcblk1: p1
  225. mmcblk1boot1: unknown partition table
  226. mmcblk1boot0: unknown partition table
  227. hub 1-1:1.0: USB hub found
  228. hub 1-1:1.0: 4 ports detected
  229. Galcore version 4.6.9.9754
  230. mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
  231. mxc_asrc 2034000.asrc: mxc_asrc registered
  232. mxc_vpu 2040000.vpu: VPU initialized
  233. leds-gpio gpio-leds.22: pins are not configured from the driver
  234. caam 2100000.caam: device ID = 0x0a16010000000000 (Era -524)
  235. caam 2100000.caam: job rings = 2, qi = 0
  236. caam 2100000.caam: authenc-hmac-md5-cbc-aes-caam
  237. caam 2100000.caam: authencesn-hmac-md5-cbc-aes-caam
  238. caam 2100000.caam: authenc-hmac-sha1-cbc-aes-caam
  239. caam 2100000.caam: authencesn-hmac-sha1-cbc-aes-caam
  240. caam 2100000.caam: authenc-hmac-sha224-cbc-aes-caam
  241. caam 2100000.caam: authencesn-hmac-sha224-cbc-aes-caam
  242. caam 2100000.caam: authenc-hmac-sha256-cbc-aes-caam
  243. caam 2100000.caam: authencesn-hmac-sha256-cbc-aes-caam
  244. caam 2100000.caam: authenc-hmac-md5-cbc-des3_ede-caam
  245. caam 2100000.caam: authencesn-hmac-md5-cbc-des3_ede-caam
  246. caam 2100000.caam: authenc-hmac-sha1-cbc-des3_ede-caam
  247. caam 2100000.caam: authencesn-hmac-sha1-cbc-des3_ede-caam
  248. caam 2100000.caam: authenc-hmac-sha224-cbc-des3_ede-caam
  249. caam 2100000.caam: authencesn-hmac-sha224-cbc-des3_ede-caam
  250. caam 2100000.caam: authenc-hmac-sha256-cbc-des3_ede-caam
  251. caam 2100000.caam: authencesn-hmac-sha256-cbc-des3_ede-caam
  252. caam 2100000.caam: authenc-hmac-md5-cbc-des-caam
  253. caam 2100000.caam: authencesn-hmac-md5-cbc-des-caam
  254. caam 2100000.caam: authenc-hmac-sha1-cbc-des-caam
  255. caam 2100000.caam: authencesn-hmac-sha1-cbc-des-caam
  256. caam 2100000.caam: authenc-hmac-sha224-cbc-des-caam
  257. caam 2100000.caam: authencesn-hmac-sha224-cbc-des-caam
  258. caam 2100000.caam: authenc-hmac-sha256-cbc-des-caam
  259. caam 2100000.caam: authencesn-hmac-sha256-cbc-des-caam
  260. caam 2100000.caam: ecb-des-caam
  261. caam 2100000.caam: ecb-arc4-caam
  262. caam 2100000.caam: ecb-aes-caam
  263. caam 2100000.caam: ctr-aes-caam
  264. caam 2100000.caam: cbc-aes-caam
  265. caam 2100000.caam: ecb-des3-caam
  266. caam 2100000.caam: cbc-3des-caam
  267. caam 2100000.caam: cbc-des-caam
  268. caam 2100000.caam: fsl,sec-v4.0 algorithms registered in /proc/crypto
  269. platform 2101000.jr0: registering rng-caam
  270. platform caam_sm: caam_sm_test: 8-byte key test match OK
  271. platform caam_sm: caam_sm_test: 16-byte key test match OK
  272. platform caam_sm: caam_sm_test: 32-byte key test match OK
  273. platform caam_secvio.28: security violation service handlers armed
  274. usbcore: registered new interface driver usbhid
  275. usbhid: USB HID core driver
  276. i2c-core: driver [cs42888] using legacy suspend method
  277. i2c-core: driver [cs42888] using legacy resume method
  278. sgtl5000 1-000a: sgtl5000 revision 0x11
  279. 1-000a: 1200 mV normal
  280. sgtl5000 1-000a: Using internal LDO instead of VDDD
  281. imx-sgtl5000 sound.27:  sgtl5000 <-> 2028000.ssi mapping ok
  282. TCP: cubic registered
  283. NET: Registered protocol family 10
  284. sit: IPv6 over IPv4 tunneling driver
  285. NET: Registered protocol family 17
  286. can: controller area network core (rev 20120528 abi 9)
  287. NET: Registered protocol family 29
  288. can: raw protocol (rev 20120528)
  289. can: broadcast manager protocol (rev 20120528 t)
  290. can: netlink gateway (rev 20130117) max_hops=1
  291. 8021q: 802.1Q VLAN Support v1.8
  292. Key type dns_resolver registered
  293. VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
  294. input: gpio-keys.21 as /devices/soc0/gpio-keys.21/input/input0
  295. snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-01 00:00:00 UTC (0)
  296. ALSA device list:
  297.   #0: imx6q-sgtl5000
  298. EXT4-fs (mmcblk0p1): recovery complete
  299. EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
  300. VFS: Mounted root (ext4 filesystem) on device 179:1.
  301. devtmpfs: mounted
  302. Freeing unused kernel memory: 264K (80be8000 - 80c2a000)
  303. ----------mount all..........
  304. ----------Starting mdev......
  305.
  306. Please press Enter to activate this console.
  307. @tqimx6q #
  至此,就完成了tqimx6q的声卡驱动移植,有任何疑问欢迎留言讨论。
