收藏0 举报
笑心 发表于 2019-3-16 10:20 P30 = 1;
/*---------------------------------------------------------------------------------------------------------*/ /* */ /* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved. */ /* */ /*---------------------------------------------------------------------------------------------------------*/ //*********************************************************************************************************** // Nuvoton Technoledge Corp. // Website: http://www.nuvoton.com // E-Mail : MicroC-8bit@nuvoton.com // Date : Apr/21/2017 //*********************************************************************************************************** //*********************************************************************************************************** // File Function: N76E003 I/O Interrupt demo code //*********************************************************************************************************** #include "N76E003.h" #include "SFR_Macro.h" #include "Function_define.h" #include "Common.h" #include "Delay.h" #if 0 //Following setting in Function_define.h ///**************************************************************************** // Enable INT port 0~3 //***************************************************************************/ //#define Enable_INT_Port0 PICON &= 0xFB; //#define Enable_INT_Port1 PICON |= 0x01; //#define Enable_INT_Port2 PICON |= 0x02; //#define Enable_INT_Port3 PICON |= 0x03; ///***************************************************************************** // Enable each bit low level trig mode //*****************************************************************************/ //#define Enable_BIT7_LowLevel_Trig PICON&=0x7F;PINEN|=0x80;PIPEN&=0x7F //#define Enable_BIT6_LowLevel_Trig PICON&=0x7F;PINEN|=0x40;PIPEN&=0xBF //#define Enable_BIT5_LowLevel_Trig PICON&=0xBF;PINEN|=0x20;PIPEN&=0xDF //#define Enable_BIT4_LowLevel_Trig PICON&=0xBF;PINEN|=0x10;PIPEN&=0xEF //#define Enable_BIT3_LowLevel_Trig PICON&=0xDF;PINEN|=0x08;PIPEN&=0xF7 //#define Enable_BIT2_LowLevel_Trig PICON&=0xEF;PINEN|=0x04;PIPEN&=0xFB //#define Enable_BIT1_LowLevel_Trig PICON&=0xF7;PINEN|=0x02;PIPEN&=0xFD //#define Enable_BIT0_LowLevel_Trig PICON&=0xFD;PINEN|=0x01;PIPEN&=0xFE ///***************************************************************************** // Enable each bit high level trig mode //*****************************************************************************/ //#define Enable_BIT7_HighLevel_Trig PICON&=0x7F;PINEN&=0x7F;PIPEN|=0x80 //#define Enable_BIT6_HighLevel_Trig PICON&=0x7F;PINEN&=0xBF;PIPEN|=0x40 //#define Enable_BIT5_HighLevel_Trig PICON&=0xBF;PINEN&=0xDF;PIPEN|=0x20 //#define Enable_BIT4_HighLevel_Trig PICON&=0xBF;PINEN&=0xEF;PIPEN|=0x10 //#define Enable_BIT3_HighLevel_Trig PICON&=0xDF;PINEN&=0xF7;PIPEN|=0x08 //#define Enable_BIT2_HighLevel_Trig PICON&=0xEF;PINEN&=0xFB;PIPEN|=0x04 //#define Enable_BIT1_HighLevel_Trig PICON&=0xF7;PINEN&=0xFD;PIPEN|=0x02 //#define Enable_BIT0_HighLevel_Trig PICON&=0xFD;PINEN&=0xFE;PIPEN|=0x01 ///***************************************************************************** // Enable each bit falling edge trig mode //*****************************************************************************/ //#define Enable_BIT7_FallEdge_Trig PICON|=0x80;PINEN|=0x80;PIPEN&=0x7F //#define Enable_BIT6_FallEdge_Trig PICON|=0x80;PINEN|=0x40;PIPEN&=0xBF //#define Enable_BIT5_FallEdge_Trig PICON|=0x40;PINEN|=0x20;PIPEN&=0xDF //#define Enable_BIT4_FallEdge_Trig PICON|=0x40;PINEN|=0x10;PIPEN&=0xEF //#define Enable_BIT3_FallEdge_Trig PICON|=0x20;PINEN|=0x08;PIPEN&=0xF7 //#define Enable_BIT2_FallEdge_Trig PICON|=0x10;PINEN|=0x04;PIPEN&=0xFB //#define Enable_BIT1_FallEdge_Trig PICON|=0x08;PINEN|=0x02;PIPEN&=0xFD //#define Enable_BIT0_FallEdge_Trig PICON|=0x04;PINEN|=0x01;PIPEN&=0xFE ///***************************************************************************** // Enable each bit rasing edge trig mode //*****************************************************************************/ //#define Enable_BIT7_RasingEdge_Trig PICON|=0x80;PINEN&=0x7F;PIPEN|=0x80 //#define Enable_BIT6_RasingEdge_Trig PICON|=0x80;PINEN&=0xBF;PIPEN|=0x40 //#define Enable_BIT5_RasingEdge_Trig PICON|=0x40;PINEN&=0xDF;PIPEN|=0x20 //#define Enable_BIT4_RasingEdge_Trig PICON|=0x40;PINEN&=0xEF;PIPEN|=0x10 //#define Enable_BIT3_RasingEdge_Trig PICON|=0x20;PINEN&=0xF7;PIPEN|=0x08 //#define Enable_BIT2_RasingEdge_Trig PICON|=0x10;PINEN&=0xFB;PIPEN|=0x04 //#define Enable_BIT1_RasingEdge_Trig PICON|=0x08;PINEN|=0xFD;PIPEN&=0x02 //#define Enable_BIT0_RasingEdge_Trig PICON|=0x04;PINEN|=0xFE;PIPEN&=0x01 #endif /****************************************************************************** * FUNCTION_PURPOSE: I/O Pin interrupt Service Routine ******************************************************************************/ void EXT_INT0(void) interrupt 0 { clr_GPIO1; Timer0_Delay1ms(100); set_GPIO1; Timer0_Delay1ms(100); clr_GPIO1; Timer0_Delay1ms(100); set_GPIO1; Timer0_Delay1ms(100); clr_GPIO1; Timer0_Delay1ms(100); set_GPIO1; Timer0_Delay1ms(100); clr_GPIO1; Timer0_Delay1ms(100); set_GPIO1; Timer0_Delay1ms(100); clr_GPIO1; Timer0_Delay1ms(100); set_GPIO1; Timer0_Delay1ms(100); clr_GPIO1; Timer0_Delay1ms(100); set_GPIO1; Timer0_Delay1ms(100); clr_GPIO1; Timer0_Delay1ms(100); set_GPIO1; Timer0_Delay1ms(100); clr_GPIO1; Timer0_Delay1ms(100); set_GPIO1; Timer0_Delay1ms(100); } void PinInterrupt_ISR (void) interrupt 7 { if(PIF == 0x01) { PIF = 0x00; //clear interrupt flag clr_GPIO1; Timer1_Delay10ms(10); set_GPIO1; Timer1_Delay10ms(10); clr_GPIO1; Timer1_Delay10ms(10); set_GPIO1; Timer1_Delay10ms(10); } else if (PIF == 0x80) { clr_GPIO1; Timer1_Delay10ms(10); set_GPIO1; Timer1_Delay10ms(10); clr_GPIO1; Timer1_Delay10ms(10); set_GPIO1; Timer1_Delay10ms(10); clr_GPIO1; Timer1_Delay10ms(10); set_GPIO1; Timer1_Delay10ms(10); clr_GPIO1; Timer1_Delay10ms(10); set_GPIO1; Timer1_Delay10ms(10); } } /****************************************************************************** The main C function. Program execution starts here after stack initialization. ******************************************************************************/ void main (void) { P07_Input_Mode; set_P0S_7; P00_Input_Mode; P01_Input_Mode; set_P0S_1; P12_PushPull_Mode; P30_PushPull_Mode; P05_PushPull_Mode; //---------------------------------------------------- // P0.5 set as highlevel trig pin interrupt function // Keep P0.5 connect to VDD LED will tickle // otherwise, MCU into power down mode. //---------------------------------------------------- Enable_INT_Port2; // Enable_BIT7_LowLevel_Trig; Enable_BIT0_LowLevel_Trig; P30 =1; P05 = 0; set_EPI; // Enable pin interrupt set_EX0; set_EA; // global enable bit while(1) { P01=0; P30=0; P01=1; P30=1; } }
hfei 发表于 2019-3-17 12:10 作为弱上拉吗?我的电路做了外部上拉,端口电平跳变也正常,就是不进入中断,谢谢你,我设为内部上拉试试 ...
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
人才类勋章
时间类勋章
15
94
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
