High-performance Low RDSON nFET & pFET MOSFETs
• From as low as 4 mΩ • Internal Protection Features:
• Built-in Supply Undervoltage Lockout Protection
• Fixed and Capacitor/Resistor-adjustable Inrush Current Control
• Fixed and Resistor-adjustable Current Limit Protection
• Built-in Short-circuit Current Protection
• Built-in Thermal Shutdown Protection with Auto Restart
• Reverse-current Blocking using Bulk Switch or Back-to-Back FETs
• Reverse-voltage Detection (selected part numbers)
• Fast VOUT Discharge (VOUT Discharge delete options available)
• Active HIGH ON-OFF Control (Active-LOW ON-OFF control available)
• Open-drain Signaling (selected part numbers)
• Open-drain Power Good Signaling (selected part numbers)
• Wafer-level Chip-scale Packaging (selected part numbers)
• UL2367 Certified (selected part numbers)
